Go Back   Nissan Titan Forum > Regional Forums > Pacific Northwest Forum
Old 11-09-2006, 12:39 PM   #1 (permalink)
Eric Warner's Avatar
Add A Leaf
I'm looking for a manufacture that makes an add a leaf spring for my 2004 Titan. I installed a Pro Comp stage 1 6" lift kit, the current stance is level but I still have room to raise up the front. I would like to do this to allow for more tire clearance but it would make the front higher than the back. I have the HD tow package. I know I can have them made but I was curious if anybody made them.
Eric Warner is offline   Reply With Quote
Old 11-09-2006, 12:42 PM   #2 (permalink)
weeser1's Avatar
Re: Add A Leaf
what size tires are you tryin' to fit?
weeser1 is offline   Reply With Quote
Old 11-09-2006, 01:53 PM   #3 (permalink)
Re: Add A Leaf
I'm running 35" x12.50 BFG Mud Terrains on 18" wheels. My front tires are rubbing when I turn.
Old 11-09-2006, 02:29 PM   #4 (permalink)
Re: Add A Leaf
Have used add a leaf's in the past. Do you really want to make the back end so stiff? I find they work best if used to level the truck for towing. They hinder articulation if you are 4 wheeling. I eventually had to buy the leaf springs with the proper lift.
slightlycrazy is offline   Reply With Quote
Old 11-09-2006, 02:32 PM   #5 (permalink)
CVTITAN's Avatar
Re: Add A Leaf
Give Greg a call heres is sight. I believe he sells spring packs from 1" to 5". And Im sure if he doesnt have it then he knows where to get it.
http://www.prgproducts.com/
BIG WHITE TRUCK...
CVTITAN is offline   Reply With Quote
Add-a-leaf? TexTitan04 Titan Suspension 8 01-12-2008 05:35 PM
rear leaf squeaking (again) Stomper4x4 Titan General Discussion 4 05-20-2006 08:34 AM
Add a leaf- Are they decent? Burly Titan Suspension 7 01-13-2006 02:41 AM
Clamping Leaf Springs. JHOOTITAN Titan Suspension 2 09-26-2005 02:43 PM
New Leaf Spring dckwsu Titan General Discussion 0 07-01-2005 08:52 PM
