Originally Posted by rynomx785
Its gonna sit @ss end high with the 4" blocks that come with the lift. The kit actually only sits 6.5" higher than stock in the front with spacer and stock strut. the upper control arms are to add droop travel not heighth. The fox coilovers will work with the stock UCA but there are better options out there as far as coilovers. You should be able to get the install instructions at cstsuspension.com
Ya, i'm gonna go with the same setup as you and just run the 2.5" deaver pack in the rear
