Go Back   Nissan Titan Forum > Regional Forums > South Western Forum
View Poll Results: Which kit is better?
CST L/T 6 42.86%
PRG M/T 8 57.14%
Voters: 14. You may not vote on this poll
Old 10-31-2009, 11:44 AM   #31 (permalink)
Re: CST L/T or PRG M/T???
Thanks A.I.I., I've got to sleep on it I guess. I need to put a number on how much i'm willing to spend on a kit and get whatever is in that range. I'm all about doing things right the first time, but I've been so anxious to get out in the desert that i've been looking into cheaper kits. I might just have to wait and get the Camburg kit. I'll be coming into money in January so I'll be able to go all out then. Still leaves some time for desert season.
MrStevie is offline   Reply With Quote
Old 10-31-2009, 07:06 PM   #32 (permalink)
CL 8 2WD's Avatar
Originally Posted by A.I.I.Raciing View Post
So dont worry about what Greg has on the shelf, he can make adjustments later regardless of what kit you go with, because you can pay him to come out the dezert and set up your truck.
I just ran my truck, then reported back to Greg.
He made some valving adjustments on the front and went with a bigger shock in the rear. I am very happy with the way my truck performs now, I don't bottom out too easily and can go faster It's all in the tuning cant wait for O.W.
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
Old 10-31-2009, 11:13 PM   #33 (permalink)
Maybe i'll be lucky and break something at o.w. That way i'll be forced to upgrade...
Old 11-01-2009, 02:18 AM   #34 (permalink)
rynomx785's Avatar
What shock were you running and what shock are you running now?
Old 11-01-2009, 09:56 AM   #35 (permalink)
CL 8 2WD's Avatar
I have custom tuned Radflo's up front
In the rear I had 2.0 Radflo piggy backs but swapped them out to 2.5 emulsion's.
So far this set up works really really well, so much better in the whoop's Next test will be the jumps at OW
Old 11-01-2009, 12:17 PM   #36 (permalink)
rynomx785's Avatar
I think that I'm just gonna save for by passes and the Giant kit. The 2.0's work well enough for now. I'm gonna order the rebuild kit for them tomorrow.
Old 11-01-2009, 01:27 PM   #37 (permalink)
can't wait to see how your truck does out there. so the 2.5 emulsions are Radflo's also?
Old 11-01-2009, 01:40 PM   #38 (permalink)
rynomx785's Avatar
Yes sir. . . Radflo Suspension Technology - Non-Coil Shock Absorber Applications
Old 11-01-2009, 01:49 PM   #39 (permalink)
Any pics of what the shocks look like? I have no idea what emulsion means...
Old 11-01-2009, 01:52 PM   #40 (permalink)
m1key's Avatar
Looks like a tall -can with no piggy back thing is beefy
http://i612.photobucket.com/albums/tt203/m1key808/pics006-1.jpg
m1key is online now   Reply With Quote
Old 11-01-2009, 02:12 PM   #41 (permalink)
rynomx785's Avatar
It looks just like the external reservoir shock but with no reservoir. My question is, whats the difference between a emulsion shock and a internal reservoir shock? Is there a difference?
Old 11-01-2009, 03:09 PM   #42 (permalink)
CL 8 2WD's Avatar
I won't have the green light to do my rear suspension for a year or two So I will make due with what I have, and fyi the 2.5's emulsion Radflo's dampen 100X better than the 2.0 piggy backs
New Rear Shocks From Radflo
SIZE: The diameter of the shock absorber body must be matched to the vehicle weight and intended use. Larger diameter shocks contain more oil for greater operating efficiency, as well as larger internal components and mounting hardware for strength.
2.0" Shocks are recommended for light weight vehicles (up to 5,000 lbs) and street applications. Multiple shocks per corner must be installed for heavier vehicles.
2.5" Shocks are recommended for medium weight vehicles (5,000 – 7,500 lbs) and recreational or racing applications. A single 2.5" shock is comparable in performance to dual 2.0" shocks.
3.0" Shocks are recommended for heavy weight vehicles (over 7,500 lbs) and professional racing applications. A single 3.0" shock is comparable in performance to dual 2.5" shocks
Old 11-01-2009, 04:10 PM   #43 (permalink)
NorCal 4x4's Avatar
Yes, the internal reservoirs have a piston that separates the oil and nitrogen, but I found this link ...
No room for a remote reservoir? Emulsion shocks are a great option. Just like a monotube shock with a remote or piggyback reservoir, you'll find oil and nitrogen inside. The difference is that the emulsion shock does not divide the nitrogen and oil. It mingles and emulsifies inside the shock. Since nitrogen expands very little when heated, the mixture provides great performance.
Here Radflo describes the internal reservoir as well as the other types:
Internal floating piston shocks are identical to emulsion shocks with one exception. A floating piston located within the shock body keeps the oil and Nitrogen gas separated. This allows the shock to be mounted at an angle, and to perform more efficiently than emulsion shocks.
The 2.5" rear Radflo can now also be purchased from PRGproducts with an external reservoir, and for not that much more.
NorCal 4x4 is online now   Reply With Quote
The Following User Says Thank You to NorCal 4x4 For This Useful Post:
rynomx785 (11-01-2009)
Old 11-01-2009, 07:55 PM   #44 (permalink)
rynomx785's Avatar
Does anybody have a price yet? On Radflos website it looks like $275 a piece.
Old 11-01-2009, 08:17 PM   #45 (permalink)
motorvisions's Avatar
i asked greg about the 2.5 radlos w/ the remote resi and he said they would be between 600-700 bucks i believe
motorvisions is offline   Reply With Quote
cst/prg spindle lift 2wd mr abstract Titan Suspension 9 09-17-2008 12:24 AM
WTB CST rear blocks, CST/PRG Swaybar endlinks, Traction bars Aquaholic Buy/Sell 1 10-20-2007 08:52 PM
CST 4" with 2.5 inch PRG Spacers welded Titan Pictures & Media Post 23 06-26-2006 01:08 PM
PRG / CST / DR...that's right DR! Jason13 Titan Suspension 6 12-13-2005 08:34 AM
PRG coilovers and CST 8" kit ??'s Titanian Titan Suspension 3 09-20-2005 11:03 AM
