Go Back   Nissan Titan Forum > Regional Forums > South Western Forum
Old 02-04-2007, 03:12 PM   #1 (permalink)
Mars's Avatar
Catalytic Converter Question
I just took my truck to install the Volant cat-back exhaust yersterday at a muffler shop. The mechanic looked inside my cats and noticed they were empty. No ceramic inside at all. It just looks like an empty soda can, so to speak. He said it's supposed to have ceramic in there or it won't pass smog. Has anyone else noticed this on their truck? I'm just wondering if it's normal or should I take my truck to the dealership? I just don't want to deal with them. Damn!
Mars
Mars is offline   Reply With Quote
Old 02-04-2007, 03:15 PM   #2 (permalink)
Flippin Pips's Avatar
Re: Catalytic Converter Question
Take it to the dealer.
4x4LE:SUPERCHARGED:HEADERS:CUSTOM INTAKE:CUSTOM RACE EXHAUST:LIFT KIT:&HIGH PERFORMANCE MODS TO BE RELEASED SOON',STAY TUNED!!!
Flippin Pips is offline   Reply With Quote
Old 07-10-2007, 10:15 PM   #3 (permalink)
My uncle had the same situation with you. Nissan catalytic converter has no mechanical working parts inside, it is designed to help the flow of harmful gases. There are many reasons a catalytic converter would fail.
There is no choice but dealership
mickey is offline   Reply With Quote
Old 07-11-2007, 01:48 AM   #4 (permalink)
hooligan's Avatar
there's got to be something inside. i had my driver's side have the internals go to sh!t and it sounded like an acorn rattling around inside a coffee can. suffice it to say, whatever it was in the cat, got sucked back into the engine, no more rattle but the engine was blown! got a brand new engine around 52,000 miles. oh and two new cats.
born 12/3, purchased 1/4 '04 Smoke SE KC PRG MT kit, CST spindles, PRG Spec'd SAWs 2.5" C/Os w/Eibachs, SAW Airbumps, Deaver 3" springpack, PRG 1" billet blocks, Radflo 2.0 remote res shocks, PRG shackles, CST carrier bearing, PRG Offroad traction bars, 37x12.5x17 BFG All-Terrains, American Racing Mojave Teflons, 35w DDM HID low beams, SpinTech Pro Street custom exhaust, AEM CAI w/DryFlow Filter, IonicDynamics FRP prerunner fenders, front windshield tinted, Optima Yellow Top, Pioneer AVH-4100DVD w/ipod adapter connected to 160gb iPod, Sirius, HD radio tuner, Hertz 6.5" Components front, Boston 6.5" rear, Boston G1 10" subs, tech12 sub enclosure, Alpine amps, Eclipse BEC106 backup camera, TrueTrac, regeared from 2.94s to 4.11s...
>>>>>>>> Lucerne Valley offroad HD videos: http://vimeo.com/groups/h00ligan/videos
>>>>>>>> Lucerne Valley offroad PICS at: www.liftedimports.com
Old 07-13-2007, 06:01 AM   #5 (permalink)
garyk211's Avatar
Lost my engine same way.
2006 Titan LE CC Off Road
Nav DVD Tow White
Truxedo Tonneau
40 Flowmaster
On Board Air
Firestone Air Bags
2007 Harley Ultra Classic
garyk211 is offline   Reply With Quote
Old 07-13-2007, 07:29 AM   #6 (permalink)
Sammy Sandbag's Avatar
Sounds like you have a 2WD. If so, that "mechanic" wasn't looking at your cats, but your resonators.
Ummmm.... No catalytic converters have "mechanical working parts." And Nissan's cats are no different than normal cats, still have the honeycomb of catalysts covered ceramic through them.
-Counsel Yourself
2009 Blizzard Pro-4X
Old 08-13-2007, 10:55 PM   #7 (permalink)
BassTow's Avatar
The mechanic was definitely looking at the resonators, I replaced mine with 2.5" straight pipes since they restrict the exhaust down to something like 2.125" and are empty.
The two reported blown engines due to cat failures were caused by improper assembly of the honeycomb into the steel cat 'can'. We're talking about the cats right after the exhaust manifold. Nissan cats are supposed to have a honeycomb with a blanket of sorts wrapped around and then pressed into the 'can'. If the blanket is damaged or missing the honeycomb rattles around in the can and as it disintegrates into a fine sand it is sucked back through EGR into engine and sand blasts the internals. Result; blown engine. How long this takes depends on the degree of blanket damage. Many vehicles have 2 sets of cats and the set just past the exhaust manifold are the only ones that I know of that have caused this problem for Nissans. While this is a rare occurance I know that Nissan and other OEM's have taken a lot of measures to prevent this from happening, either in their vendor's or their own assembly processes.
BassTow
'04 Copper Titan LE Crew Cab 4x2 (born 12/03)
...towing bass in a '00 Nitro 911 CDC w/Merc 225 EFI
BassTow is offline   Reply With Quote
Old 08-13-2007, 11:53 PM   #8 (permalink)
hooligan's Avatar
great info BassTow, as i will save this post to show others i wasn't joking when i said, my honeycomb blew, rattled and the miniscule shrapnel got sucked back into the engine completely destroying it! had my engine replaced with a complete new crate motor from nissan. they fit the bill and my cost was $0... got new cats as well, but i'm still leery... any recommendations on possibly replacing them with some aftermarket high-flow cats? good idea or bad idea?
Old 08-14-2007, 12:33 AM   #9 (permalink)
gabriel c.'s Avatar
reading about cat failure and engine replacement because of it makes me just want to take them off. i dont worry about inspection since theres always a way around it. i did this on my silverado and had no problems. will the titan throw any codes if i remove the cats later down the road? at the pace im going, 06 with 6500 miles, ill be out of warranty if the cats fail. thoughts?
third coast titans
gabriel c. is offline   Reply With Quote
Old 08-14-2007, 01:06 AM   #10 (permalink)
hooligan's Avatar
yes, it will throw a code. stillen's longtube headers eliminates one of the sets of cats and to compensate they include some 02 emulators to trick the ecu.
As they eliminate catalytic converters, these are for OFF ROAD USE only. Shipped with an O2 signal emulator to defeat check engine lights.
http://www.stillen.com/product.asp?i...AN&model=TITAN
Old 08-14-2007, 02:38 PM   #11 (permalink)
gabriel c.'s Avatar
how can it throw a code if you are just removing the cat and not the 02 sensors. just wondering how the titan works since i kept the 02 sensor on the silverado and just removed the cat and had no check engine light come on still to this day.
third coast titans
Old 08-14-2007, 04:09 PM   #12 (permalink)
Nuke's Avatar
... is sucked back through EGR into engine and sand blasts the internals
Whoa! Thanks Bass! I could never figure out how the heck they could get sucked back into the engine.
Unless you were running the engine backwards...
Nuke is offline   Reply With Quote
Old 08-14-2007, 09:48 PM   #13 (permalink)
BassTow's Avatar
Thumbs up Re: Catalytic Converter Question
I'm not sure about the ECU logic concerning the range the O2 sensor considers acceptable during initial warm-up. My understanding is the set of cats just after the exhaust manifold were mandated by EPA to reduce emissions during initial cold start by warming up much quicker than the more conventional cats you see on the aftermarket that are only designed to be used further away from the engine. I'd have to agree that to eliminate them would require an O2 simulator be installed, to the first set of o2 sensors, similar to the Stillen set-up, to prevent codes. I don't have to pass emissions testing where I live so I'm not sure if this would pass or not. Seems like if the test didn't require cold start-up and you had another set of quality cats downstream you would pass emissions testing, barring any other problems that could cause you to fail.
On the other hand, for peace of mind, and if you aren't planning on headers, just unbolt the 1st set of cats from your exhaust and check the honeycomb for any movement in the 'can'. If you can move the honeycomb around at all it means it was loose to start with and you've already started sucking the disintegrated 'grit' back into the engine. If you're still less than the 8yr/80K cat related warranty then I'd have the dealer to do the inspection otherwise they could say maybe you did something and would have to pay for it even if a problem exists. Only downside by having dealer do the inspection is that if they don't find a problem you have to pay the cost for the cat inspection. In reality, even though there have been several that have had this problem here on this forum, as long as you check your oil on a regular normal basis and don't have any of the other symptoms (rattling noise, black soot in tailpipe,etc...), odds are very, very good your cats will never be a problem and not worth the trouble. Hope this helps.
BassTow
Old 08-15-2007, 07:20 PM   #14 (permalink)
gabriel c.'s Avatar
i would just hate if this happens while out of warranty. when checking the oil what exactly are you looking for? sludge like material, or something that resembles sand? all this cat talk is getting me worried now. lol.
third coast titans
Old 08-15-2007, 08:19 PM   #15 (permalink)
Oil consumption mostly. Meaning check to see if there is any oil on the stick period, like in my case due to internal damage from the cats. I had to add 4 qts. after driving 300 miles. That is what I call a little concerning!
05 Titan KC SE - Smoke, BT
Nismo CAI, FlowMaster 40 SI/SO 3", Timing Advance, TB Bypass, 5% tint, Smoked Tails, Armada Lip, De-badged, Silverstar Ultra's.
Best ET 15.32@90.8 2/8/08
Wife's Car: 02 Altima 3.5 SE 5MT - Mystic Emerald Nismo CAI, VIAS Plate Removed, Royal Purple Fluids, Jim Wolf Clutch/Flywheel, Dual Magnaflow w/ OEM Resonator Removed, Nitto NT555 245/45/17, De-badged
Best ET 14.16@100.4 2/8/08
Titan5683 is offline   Reply With Quote
Torque converter lock up question? QWIKWHIP Titan Towing & Hauling 26 08-18-2006 06:22 PM
Torque converter lockup/unlock question exit395 Titan Engine, Transmission & Drivetrain 14 07-12-2006 02:05 PM
Catalytic Converter PrinceKheldar27 Titan Performance Modifications 1 03-13-2006 06:08 PM
Catalytic Converters required? brentburgess171 Titan Performance Modifications 11 10-22-2005 10:39 PM
Romoving the catalytic converters ..... BigPete Titan Performance Modifications 19 07-05-2004 12:55 PM
