Go Back   Nissan Titan Forum > Supporting Vendors > Sparkplugs.com
Sparkplugs.com Sparkplugs.com
Old 11-18-2005, 01:17 PM   #1 (permalink)
Supporting Vendor (Gold)
sparkplugs.com's Avatar
What is a Fine Wire Spark Plug?
Fine wire center electrodes come under a variety of names depending on manufacturer, IE - Tapered point, Ultra-Fine electrode, Taper cut electrode, Necked down electrode. Originally designed to improve starting and reduce fouling in two-stroke engines, this design was found to improve performance in four-stroke engines as well.
All operate on primarily the same principle, a spark plug with a fine wire electrode will perform better than a traditional plug. There are two reasons for this, first is because a smaller center electrode requires less voltage to jump the gap. This means fewer misfires, which should be seen in higher mileage and more horsepower. The second reason is smaller center electrodes reduce quenching. The smaller center electrodes have required exotic metals such as platinum or iridium so that they can still maintain (and usually surpass) the longevity of a traditional spark plug.
Currently the finest wire performance plugs available are made by Denso at 0.4mm diameter (image 1), by NGK at 0.7mm diameter (image 2), and by Champion at 1.1mm (image 3), a traditional center electrode is typically 2.0 to 2.5mm (image 4).
sparkplugs.com is offline   Reply With Quote
Old 11-19-2005, 02:33 PM   #2 (permalink)
got_titan's Avatar
Re: What is a Fine Wire Spark Plug?
good info!! thanks for the good explanations.
04 cc 4x4 w/big tow...........silver
volant cold air , oem sirius tuner, Zoomers exhaust, wade in channel visors, chrome tailgate piece ,05 finned diff cover,leather console lid, tailgate torsion bar,22 inch akuzu bounce, 305/45/22 nitto 420 extremes, mccullough hid's,05 active headrests , truxedo low profile,stillen front sway bar, painted lund interceptor, cr lawrence rear power slider,armada painted front spoiler, dr coilovers, t rex vertical billet grill, zoomers exhaust, prg traction bars, Stillen brake pros monster brake kit, prothane front swaybar bushings, volant vuelights(led), odyssey deep cycle battery, trutrac on order.....(INSTALLED)
STILLEN SUPERCHARGED 425rwhp 431rwtq (before headers)
Old 03-09-2006, 06:54 AM   #3 (permalink)
mnmsmith's Avatar
Any idea what plugs we currently have in our Titans? I'm debating whether or not it would be worth changing mine out now.
'05 SE 4x4 Crew Cab - Radiant Silver
Radflo 2.0 Coilovers :: Rear Bilstein Shocks :: Zoomer's Cat-Back Exhaust :: Active Tuning Ground Kit :: Line-X Bedliner :: N-Fab Nerf Bars :: Grillcraft MX Grill :: 17x8 Enkei's :: Nitto Terra Grappler 295/70 17's :: Alpine HU :: Focal Component Speakers :: JL Audio 10W3's :: JL Audio Amps
mnmsmith is offline   Reply With Quote
Old 03-09-2006, 07:03 PM   #4 (permalink)
I think its an NGK double platinum plug - PLFR5A-11
Old 03-09-2006, 07:15 PM   #5 (permalink)
mnmsmith's Avatar
OK, so not much point in changing them out until its time, sounds like if there is a difference, it would be negligible.
Spark Plug Information Directory sparkplugs.com Sparkplugs.com 1 10-24-2005 07:45 PM
Spark Plug Construction sparkplugs.com Sparkplugs.com 0 10-24-2005 07:39 PM
Spark plug info GETSOMZ28 Titan General Discussion 4 03-30-2005 09:07 AM
