Go Back   Nissan Titan Forum > Supporting Vendors > Sparkplugs.com
Sparkplugs.com Sparkplugs.com
Old 07-18-2006, 06:07 PM   #1 (permalink)
Supporting Vendor (Gold)
sparkplugs.com's Avatar
What is Indexing?
Used by racing tuners only, indexing refers to a process whereby auxiliary washers of varying thickness are placed under the spark plug's shoulder so that when the spark plug is tightened, the gap will point in the desired direction.
However, without running an engine on a dyno, it is impossible to gauge which type of indexing works best in your engine. While most engines like the spark plug's gap open to the intake valve, there are still other combinations that make more power with the gap pointed toward the exhaust valve.
In any case, engines with indexed spark plugs will typically make only a few more horsepower, typically less than 1% of total engine output. For a 500hp engine, you'd be lucky to get 5hp. While there are exceptions, the bottom line is that without a dyno, gauging success will be difficult.
sparkplugs.com is offline   Reply With Quote
Old 07-18-2006, 06:11 PM   #2 (permalink)
bbomar's Avatar
Re: What is Indexing?
Thanks for the info. I remember when I knew all this stuff, and now I'm just old!! But it's great when someone freshens my memory!!
2006 Titan SE
4X2 Crew Cab
Majestic Blue!
AKA: The Hijack King™
AKA: The Troll Hunter™
