Go Back   Nissan Titan Forum > Regional Forums > Texas Forum
Old 01-27-2007, 11:37 PM   #1 (permalink)
LpLove's Avatar
Cst Question?
Hey guys whats up? Ive got a 06 cc with 33" tires with the prg 2.5" leveling kit. I want to get the 4" spindle lift and so im lookin at 6.5" in front. What would i need for the rear? And what else would i need along the lines of shocks and alingment? im tryin to not put a huge dent in my pocket. And what would be a rough estimate on installtion from a shop. So basically id like to get yalls input on everything i need to do to pull this off.
LpLove is offline   Reply With Quote
Old 01-29-2007, 07:04 AM   #2 (permalink)
WhiteTitanSe's Avatar
Re: Cst Question?
I just did this lift to my truck 2 weeks ago, First you will need a drop down bracket for the drive shaft. Depending on whai one you go with for the Pro Comp- 50. 00 for the CsT - 150.00 highly rec. the CST Then for the rear you will need a 4'' block and u bolts. and shocks. These are all you need with the spindles and brake lines priced through PRG the cheapest way was 830.00 shipped! thats with the pro comp bracket for the Cst add 100.00 and like 20.00 extra for the better pro comp shocks. If you live somewhere around DFW then I could do the install for a good price. You will need a alignment afterwards another 60ish.$$$
WhiteTitanSe is offline   Reply With Quote
Permanent brake fix question, rotor question. SWTXTITAN Titan General Discussion 4 08-06-2005 06:44 AM
