Go Back   Nissan Titan Forum > Regional Forums > Texas Forum
Old 03-08-2008, 03:09 AM   #1 (permalink)
SFCIngrum's Avatar
Send a message via Yahoo to SFCIngrum
Tailgate Power Locks
Tailgate Power Lock
Anyone try this yet?
I am interested in it but not sure if I can pull it off on my own.
IRC VK56 Member "Special Operations Crew Chief"
2008 Red Alert CC LE - Nismo CAI, Advance Cover quad-folding tonneau, 2* Advance, Keypad, Third Barke Light Billet, Black Altezza Tail Lights, Banks Exhaust, Powder Black Grill Gaurd, Billet Grill, Xenon Headlights, Tailgate Mod, PRG Shackles, **BULLYDOG TUNED**, Tech12volt under front seat subs
Current:
http://s285.photobucket.com/albums/l...E%20Build%202/
Gone but not forgotten:
http://s285.photobucket.com/albums/l...LE%20-%20Gone/
Wife's Ride:
http://s285.photobucket.com/albums/l...%20Versa%20SL/
SFCIngrum is online now   Reply With Quote
Old 03-08-2008, 04:03 PM   #2 (permalink)
baseballfanz's Avatar
Re: Tailgate Power Locks
Its pretty easy to do.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 03-08-2008, 07:21 PM   #3 (permalink)
SFCIngrum's Avatar
I am not the best when it comes to this kind of stuff, how long did it take you to do it?
Current:
Wife's Ride:
Old 03-10-2008, 07:51 AM   #4 (permalink)
Send a message via ICQ to PuvMan Send a message via AIM to PuvMan Send a message via MSN to PuvMan Send a message via Yahoo to PuvMan
I've been wanting to do this since i bought my truck, just been laaaaaaaaaazy
I have power steps to install soon, and will have to break into the wiring then, so i'll probably run the wires back into the tailgate and do this at the same thing. Supposed to be super easy to do
Born on: 4/11/2005
Signed: 5/21/2005
Delivery: 5/23/2005
05 LE Crew Cab 4X4 SMOKE
Off Road, Big Tow, Navi, DVD, XM, Sunroof, Underseat Storage, Bed Divider, Bed Extender
Aftermarket:
Husky Liners, ActiveTuning Grounding Kit, JetTech Spring Helpers (currently removed), Undercover Tonneau, Lund Interceptor, Wade Window Visors, Fram Boost, Bushwacker Fender Flares, CompuStar 2W900FM-AS, 2* Timing Advance, Siemens HKW-700 Bluetooth Car Kit, Two 11.Kv.2s running of an eD NINe.1 in custom BWR boxes coated with bedliner, 4" PRG Perf Package (SAWs, PRG Arms, 1" Deaver Pack, Bilsteins), 20" Axis Titan rims w/ 33" Nitto Terra Grapplers
Coming Soon:
another new rear end.. haha
trutrac
trac bars
power steps
custom 12" fiberglass sub-box (thanks rcantu!)
Exhaust
PuvMan is offline   Reply With Quote
Old 05-14-2008, 06:37 PM   #5 (permalink)
BrianCMM's Avatar
Lightbulb Re: Tailgate Power Locks
The only difficult parts of the mod are mounting the lock actuator perfectly so it works smoothly and making the connection between the lock actuator and the tailgate lock latch arm.
I just did this Tailgate Power lock mod and found a much easier way to mount the actuator and to make the linkage work.
I had a hell of time trying to make the linkages work as shown in the pics...it would never pull smoothly on the tailgate lock lever. I also could not see how the actuator could mount as shown, since it would interfere with the right side tailgate latch rod??
I eventually found a much easier way to do this.
You just use the actuator rod that comes with the power lock unit and bend it as shown in my pics below. It works very smoothly and mounts very solid with no interference of other parts.
I drilled three holes in the lock latch arm, but you only need one. I made three so I could find the one which would allow the smoothest operation. The lock latch arm is easily removed and replaced by sliding an E-Clip on and off...just don't lose it.
Then you just mount the actuator directly to the tailgate. No strapping needed. Just take your time aligning the holes before drilling. I held my lock actuator in place with a large spring clamp and operated it before I drilled any holes.
Thanks to the original posters of this mod...It's a very convenient thing to have!!
tailgate-power-locks-bend-actuator-rod-like-.jpg  tailgate-power-locks-lock-latch-arm.jpg  tailgate-power-locks-hold-spring-clamp-try-before-drilling.jpg  tailgate-power-locks-mount-actuator-directly-tailgate.jpg  tailgate-power-locks-my-wiring-method.jpg
BrianCMM is offline   Reply With Quote
Old 06-13-2008, 07:00 AM   #6 (permalink)
now if you lock your truck while you already have the tailgate open and it locks the tailgate, can the tailgate still close?
only reason i am asking is because i am interested in doing this mod but i am away from my truck (for a while) and cannot physically play with it.
asher is offline   Reply With Quote
Old 06-13-2008, 07:58 AM   #7 (permalink)
BrianCMM's Avatar
Yes, you can still close the tailgate even if it's locked.
Old 06-13-2008, 06:14 PM   #8 (permalink)
thanks!
they say there's no such thing as a stupid question, but i was a bit tired after working a 16 hour day...and now re-reading my post after a little bit of rest...i think it was a stupid question.
Old 06-14-2008, 05:45 AM   #9 (permalink)
BrianCMM's Avatar
Lol...Stupid questions are fine...it's stupid answers that are annoying.
2004 Titan KC SE 4x4 OR BT
Have: Nismo Exhaust, 2* Timing Adv, Truxedo Deuce Tonneau, Tailgate PowerLock & Spring Assist, Rear Axle Breather, Parrot 3200LS Bluetooth, 2007 6CD/MP3/WMA Radio
Want: Bilstein Adj Frt shocks, Bilstein rears, CAI, Black Bull Bar, Black mesh grill inserts
Old 07-18-2008, 03:04 PM   #10 (permalink)
pycckupod's Avatar
Good Info BrianCMM. Looking to do this on my 08. Your pics will help.
pycckupod is offline   Reply With Quote
Old 07-18-2008, 04:16 PM   #11 (permalink)
BrianCMM's Avatar
Thanks. This mod is great and I have never had a problem with it.
I recommend tapping for the power lock on the passenger side so the tailgate lock only works when you press the unlock button twice.
power locks and power windows for XE player428 Titan Parts & Accessories 24 01-26-2008 04:49 PM
power locks scubadave Titan Parts & Accessories 4 04-27-2007 04:47 PM
Power windows and locks? pImpNaTitaN Titan General Discussion 9 10-17-2005 12:52 PM
Power locks and windows for an xe beaver Titan General Discussion 3 08-16-2005 03:21 PM
Power locks EPTITAN Titan General Discussion 0 06-08-2004 12:35 PM
