Here's the deal...
I have a 2007 Titan XE with 85000 miles. At times, the cruise control works just fine. Other times, not.
This is what it does when it "acts up" :
Sometimes, the cruise will seem like it just is not going to turn on. Several presses of the on button is required for the dash indicator to light. Other times, it lights up with the first press.
Sometimes, it will work just fine until I have it disengaged (still turned on). Then it will flash the set light. When it does this, it will not set. Sometimes, the flashing starts as soon as I try to turn the cruise on.
It may go days or weeks working like it should, then act up this way all the time.
If I turn the truck off (while driving down the road) and re-start it, this will usually reset it to work, but it will stop working again when I an stopped at a light or otherwise stopped (not all the time - only sometime)
It does throw a Cruise Control error code. However, a mechanic I know said it could be something other than the cc module - then again, it could be the module.
Anyone else have this situation? Any ideas?
Thnx
