Re: Axle
If I had my choice, I'd go with a ford 9" over the Dana 60...only because ove the unsprung weight factor, the 9" being lighter....I don't know of anyone doing a 9" and adding some sort of ABS tone rings to keep the "Christmas Tree Effect" out of the the dash...
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
