Old 10-31-2009, 09:43 AM   #1 (permalink)
TitanicDJ's Avatar
Send a message via MSN to TitanicDJ
D@MN power steering hose!
So my IPDM went out last month but they (the dealership) fixed it under warrantee. Unfortunately they found my power steering hose leaking and it wasn't under warrantee. They gave me a price of over $450.00 to fix it. I'm assuming it's the pressurized hose but d@amn.
I think since my warrantee is done with I'll take it somewhere else to get fix. What do you think the cost will be from a non-Nissan service dept? I also need brakes so I'm trying to get it done right but save a little cash for my brakes too!
Anyone in San Diego know a good shop?
'04 White SE, CC, BT, Off Road 4x4
• Banks Monster Exhaust • Pro Comp 6" Stage II • PRG Radflo External Reservoir Coilovers w/King Springs
• PRG OR Traction Bars • American Racing Chamber w/Teflon 17" • BFG T/A KO 315/70 17 • Active Tuning Grounding Kit
• FramBoost Air Intake • XM Satellite Radio • Hoppy Assist Tailgate • Grillcraft Black Mesh Grille • 2° Timing Advance
________________________
TitanicDJ is offline   Reply With Quote
Old 10-31-2009, 10:05 AM   #2 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Re: D@MN power steering hose!
How bad is it leaking?....and how much fluid have you added to the reservoir?.......My SM told me the same thing but I got some power steering stop leak and added a few ounces....that was almost 2 years ago and I haven't added any fluid since. Yes it makes a small amount of oil on the hose from top to bottom over time but I don't see the need to replace it. I would consider grinding/cutting a slit in the hydraulic fitting at the upper hose and putting a hose clamp on it. The hose must weaken/rot from the inside and the hydraulic fitting can't be tightened so that's probably the problem. Cheap inner hose material.
Good luck.
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra L B, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and 75-90 in Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
JFK http://www.youtube.com/watch?v=J8dLHZ6jKFc
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
The Following User Says Thank You to honeykeeper For This Useful Post:
TitanicDJ (11-06-2009)
Old 10-31-2009, 10:28 AM   #3 (permalink)
TitanBlue's Avatar
I am not sure of on the Titan, but usually it is just a hose with 2 ends. Buy the Hose from Nissan parts or take your old hose to a Hydraulic Shop for a better hose. Take off and put on new one yourself. It is usually just a 30-45 minute job. Could be one of the easiest jobs you ever did. You may need a Flare Nut Wrench Set though. But get the facts first!
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG Street Traction Bars and Mini Lift Kit, UpRev Osiris Tuner 93 Performance Tuned, MB Razor Rims, Functional Hood Scoop, Custom Graphics ...
Old 11-01-2009, 04:48 PM   #4 (permalink)
Shane06fl's Avatar
I do all hydraulic hose repairs at a place called Amazon Hose and Rubber co. I think They are national but they are located here in Orlando and they do ship. But I found this place in your neck of the woods.
Western Hose and Gasket Company- Westflex
A lot of these places can you build you a better hose while you wait and 1/4 the cost of a factory part.
2005 Titan KC SE
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
2004 Keystone 24RS
2008 with Leaky Power Steering Hose Exocet Titan General Discussion 0 10-12-2009 07:06 PM
Power steering hose MKTitan Titan Problems & Dealer Service 15 09-19-2009 07:14 AM
Power steering pressure hose Antihero Titan Problems & Dealer Service 15 01-17-2008 01:58 PM
Power steering hose leak jeeptug Titan Problems & Dealer Service 1 01-28-2005 08:58 AM
power steering hose... citrusgirl Titan General Discussion 2 04-12-2004 02:58 PM
