Old 11-02-2009, 10:49 AM   #1 (permalink)
damerowalex's Avatar
Tired of my 4x1!!! Which diff should I get????
I cannot stand my 4x1 any longer. 6" lift 35" tires and with open diff I can do nothing on or off-road. Cannot believe they're still putting these in trucks...its a TRUCK!
I'm trying to decide on what differential I want to put in the rear of my 2009 T. I'm a newb when it comes to gears and axles so bear with me! I think that the TrueTrac sounds best for my use (intermediate off-road, looking for more traction, tired of 1 wheel peel) what do you guys think of the TrueTrac so far? I'm a college student so money's tight. Making sure I get it right before i pull the trigger!
Also, which axle is back there btw?
damerowalex is offline   Reply With Quote
Old 11-02-2009, 10:54 AM   #2 (permalink)
Juday's Avatar
Re: Tired of my 4x1!!! Which diff should I get????
What year is your truck to begin with? The TrueTrac is only available for 04-07 applications I believe (they went to a larger spline count in the newer models). The differential in the rear is a variant of the Dana 44, but stronger. It's known as the M226.
And yes, TrueTrac would be your best bet. There are only two option right now that I know of; TrueTrac or ARB locker. The ARB runs about $895 + the cost of the compressor, relays and other equipment.
35x12.5x17 Cooper Discoverer STTs
AEM Brute Force CAI
TomTom One XL Navigation
2* Timing Advance
PRG Shackles (Still need to install these...)
PowerSlot Cryo Rotors w/ Hawk LTS pads from Frozen Rotors
Superchips Cortex
Old 11-02-2009, 10:56 AM   #3 (permalink)
Yahooligan's Avatar
Technically, while in 4wd, it would be 4x2. You'll always have equal power going to one front and one rear tire.
The rear diff is a Nissan M226 (Dana 44 variant), I've heard nothing but good things about the TrueTrac. Totally spaced that you have an '09, though. I believe the only way to get the TrueTrac in there is to swap out the axle shafts for the CC29 version. There is a thread on here somewhere about getting the LSD/locker to work in '08+ Titans.
The dog: 2005 Titan SE CC 4x4 - Magnaflow 24" w/ 3" Y-back single pipe, Bully Dog GT, Roadmaster Active Suspension, SnugTop Sport shell, 5000k HIDs
The fish: 1984 Scarab 21SS - Marine Power 454 - FOR SALE
Yahooligan is offline   Reply With Quote
Old 11-02-2009, 11:02 AM   #4 (permalink)
Its a 2009, so thats bad news if that is the case..
Old 11-02-2009, 11:08 AM   #5 (permalink)
Juday's Avatar
Yep. Sorry to bring you the bad news...
AEM Brute Force CAI
2* Timing Advance
Superchips Cortex
Old 11-02-2009, 11:11 AM   #6 (permalink)
Steelyeyedone's Avatar
Are you 2wd or 4wd?
What are you trying to go through that your having issues? Ive had my truck stuck one time and that was because I had it resting on the frame with the stock tires/wheels and stock height. After I lifted it, and threw on the 35's, I cant seem to get it stuck. Most of the time whem Im in the GA clay, Im in 2wd trying to get it stuck. 4wd, I have no issues at all.
2008 Nissan Titan LE CC 4x4 LWB
Click Here For My Mods
You cannot legislate the poor into prosperity by legislating the wealthy out of prosperity. What one person receives without working for, another person must work for without receiving. The government cannot give to anybody anything that the government does not first take from somebody else. When half of the people get the idea that they do not have to work because the other half is going to take care of them, and when the other half gets the idea that it does no good to work because somebody else is going to get what they work for, that my dear friend, is the beginning of the end of any nation. You cannot multiply wealth by dividing it.
Steelyeyedone is offline   Reply With Quote
Old 11-02-2009, 11:43 AM   #7 (permalink)
Originally Posted by Steelyeyedone View Post
Are you 2wd or 4wd?
well i"m not a 4wd so I have no LSD either, its just an open differential. it doesnt happen often but after a good rain - i'm useless with 1 wheel.
nice looking LWB btw!
Old 11-02-2009, 12:20 PM   #8 (permalink)
vilim12's Avatar
None of the Titans come with an LSD. They all have an open rear diff unless you have a "Pro-4x" or an "Offroad Model" those come with a locker.
2008 Nissan Titan Pro-4X
Crew Cab Long Bed
Tech12 box ported with RE 10s
vilim12 is online now   Reply With Quote
Old 11-02-2009, 12:25 PM   #9 (permalink)
We have the ABLS
Old 11-02-2009, 12:42 PM   #10 (permalink)
vilim12's Avatar
We have the ABLS
I saw a video of it and it didnt seem to much at all, if anything.
Crew Cab Long Bed
Old 11-02-2009, 12:58 PM   #11 (permalink)
ABLS is a tiny bit better than a regular open diff, but nowhere close to a TT or locker.
Old 11-02-2009, 02:51 PM   #12 (permalink)
Anything's better than an open.
So what do you guys think I should do to find better traction? Any other differentials you'd recommend? I don't want a full time locker or anything too radical because the truck is mostly a pavement pounder.
Old 11-02-2009, 04:15 PM   #13 (permalink)
With the M226 you can install the ARB RD-149 locking differential, best make available and it's an on demand system; turns on/off at the flip of a switch.
LA RANA is offline   Reply With Quote
Old 11-02-2009, 04:27 PM   #14 (permalink)
Yahooligan's Avatar
Originally Posted by LA RANA View Post
If you have an M226 you can install the ARB RD-149 locking differential, best make available and it's an on demand system; turns on/off at the flip of a switch.
All Titans have the M226 (D44) rear, the issue is that there are two different M226 models; CC29 and CC33. The CC33 (All '08+ and '04+ with e-locker) has larger axle shafts than the CC29, so it's important to know which axle you have. If you have the CC33 and the ARB (Or Detroit) is not designed for the CC33 shafts then you'll be SOL.
Old 11-03-2009, 10:26 PM   #15 (permalink)
I saw the same video. Makes me wonder what the Nissan R&D guys were smoking when they programmed the ABLS.
'08.5 Pro-4x King Cab
AEM Intake
PRG UCA
SAW Coilover
PRG MT kit ordered
For Sale: OEM Nissan bedliner for King cab reg. bed. NEW
svtguy22 is offline   Reply With Quote
Are you tired baseballfanz Titan Performance Modifications 24 10-14-2009 01:08 PM
***I got tired Tired of this crap**** James Con Titan Towing & Hauling 35 04-06-2009 12:11 PM
Im about tired of Nissan Lunatic Titan Engine, Transmission & Drivetrain 3 07-02-2008 09:54 AM
Sick and Tired garo1 Titan Problems & Dealer Service 4 12-04-2004 07:56 PM
