Old 11-04-2009, 05:16 PM   #1 (permalink)
Question BT transmission temp sensor location?
I have a question, on the BT titans where is the trans temp gauge sending unit located? i am in the process of installing a after market trans temp gauge on my non BT titan. i was going to install the sending unit right in the pan/sump of the tranny but i figured a more acurate reading could be achived on the outlet line of the trans/ inlet line to the cooler. thanks for the help...
if it does not make you handel better or go faster why bother!!!!!
JET MECH is offline   Reply With Quote
Old 11-04-2009, 05:35 PM   #2 (permalink)
titanridinghigh's Avatar
Send a message via AIM to titanridinghigh
Re: BT transmission temp sensor location?
Here is a pic from another tt member Timbo4x4..Its a spot on the right side of the transmission.. Its a perfect spot for a probe..
  • 2006 NO FEAR Edition CC TITAN
  • PRO COMP Stage 2 with MX6 Shocks
  • CST Sway Bar Links
  • 35x12.50 PRO COMP Xtreme A/T
  • 20x10 KMC XD Series Monsters
  • Shaved & Pulled Rear Fenders
  • 2008 Rear Axle
  • 5% Tint
  • 6k HID
  • Alpine Indash
  • Alpine PDX 1.1000 & JL 300/4 AMPS
  • Infinity Kappa Components all around
  • 4 10" JL W3 v2 in a Fiber Glass Box
  • Odyssey PC1700 Deep Cycle Battery
  • Bully Dog GT Gauge and Programer
  • Gibson Exhaust with Throw Down Tip
  • Volant Intake
titanridinghigh is offline   Reply With Quote
Old 11-04-2009, 05:54 PM   #3 (permalink)
thank you so much!!!!
Oil Sensor Location?? Black05xe Titan Parts & Accessories 15 11-05-2008 09:29 AM
Transmission Temp sechrestmotorsports Titan Towing & Hauling 11 09-01-2008 02:09 PM
Fuel Temp. Sensor?? Bartek101 Titan Parts & Accessories 17 01-27-2007 05:35 PM
Tire pressure sensor location? John Harden Titan General Discussion 10 12-01-2005 01:46 PM
Transmission temp sensor blueskys Titan General Discussion 0 06-18-2005 09:07 AM
