Old 11-04-2009, 05:47 PM   #1 (permalink)
SirKeats's Avatar
Under 50k - Need Axle Bearings?
So I'm getting ready to order up my truetrac. I have around 47k on my 2004 XE (2wd).
I'm getting the carrier races and bearings and rear axle seals for sure.
The rear axle bearings aren't cheap though and with only 47k... I'm pretty sure they're fine.
Why are most folks I see posting here suggesting you replace the bearings during a truetrac install? Do you damage them during the installation?
I don't mind spending the money, but don't want to fix something that isn't broken. I'm not doing the install myself, having my long time mechanic do it. He's great and said no problem. He too doesn't seem to think I'll need the bearings, but perhaps there's something y'all know that I don't.
Courtesy Nissan can beat the prices on the bearings vs. what the local dealer wants, so if I need to order them along with the seals I will. Just thought I'd check first.
Thanks for the input!
SirKeats is offline   Reply With Quote
Old 11-06-2009, 07:41 AM   #2 (permalink)
CL 8 2WD's Avatar
Re: Under 50k - Need Axle Bearings?
I have had Hoopers change the gear ratio 2X with the TrueTrac and have had my diff torn down, the axle housing modified and reassembled with nothing replaced but the gear fluid. no leaks , no problems, all is well .
http://liftedimports.com/index.html
http://www.youtube.com/user/LiftedImports
06 SMOKE SE KC 2WD TITAN /AEM INTAKE/FLOWMASTER 40/CST 4" LIFT SPINDLES/2.5 X 8" TRAVEL RADFLO COILOVERS W/ REMOTE RESERVOIR / PRG DELIUXE MID-TRAVEL KIT /DEAVER 2.5 MINI PACK/2.5 X 10" TRAVEL RADFLO REAR SHOCKS /PRG OFF ROAD TRACTION BARS/ CST CARRIER DROP/PRG HD SHACKELS/ULTRA ROUGE 17X8 WHEELS/37X12.50R17 HANKOOK DYNAPRO MT/HOOPERS CUSTOM 4.56 GEAR INSTALL W/TRUETRAC AND MAG-HYTECH DIFF.COVER/ALLIED MOTORSPORTS PRG MID TRAVEL SET UP CUSTOM FAB FRONT & REAR BUMPERS/BULLY DOG HIGH OCTANE TUNE +2* DISABLE WIDE OPEN THROTTLE GOVERNOR
CL 8 2WD is offline   Reply With Quote
Old 11-06-2009, 07:57 AM   #3 (permalink)
You can't change the axle seals w/o changing the axle bearings.
Who makes custom axle bearings? MilenkoGT Titan Performance Modifications 3 10-02-2009 07:47 PM
wheel bearings huffhuff Titan General Discussion 0 09-01-2009 02:02 PM
50K milestone it is not.... Titan1080 Titan Engine, Transmission & Drivetrain 4 03-19-2008 09:12 PM
Wheel Bearings onelowmini Titan General Discussion 6 02-21-2008 11:30 PM
Axle Bearings are they the same pgthe1 Titan Engine, Transmission & Drivetrain 1 07-15-2007 10:04 AM
