lost my four wheel dirve - Nissan Titan Forum
post #1 of 9 (permalink) Old 12-20-2009, 10:08 AM Thread Starter
iTrader Score: 0 reviews
If you have been watching the weather we just 20 inches of snow on saturday. This morning i was taking my daughter to work and turned the corner in snow that was about 8 inches deep and low and behold lost my four wheel drive. will not go into four wheel drive at all low or high. i also tried turning on the diff lock but the light on the dash just flashes. just a note the transfer case and tires light up on the dash and i can here the relays click under the dash.
Need help fast
2004 titan se with 66601 miles on it
Thanks
Jim Cav
jimcav is offline
Advertisement
post #2 of 9 (permalink) Old 12-20-2009, 10:25 AM
Re: lost my four wheel dirve
Need help fast
Thanks
Jim Cav
Sounds like you front differential has failed. Look under the front to see if the driver side axel is hanging out of the diff or if you are leaking any diff fluid.
Bilsteins 5100 fronts set at 1 inch. 1" rear drop shackles
Wet Okole Front seat covers.
New front differential at 60500 miles. [goodwill fix denied]
Detroit Truetrac at 61000 miles
Herbpov is offline
post #3 of 9 (permalink) Old 12-20-2009, 01:46 PM Thread Starter
turned the wheel all the way to the left the drive axle seemed fine and i am not leeking fluid. any other ideas? is there a gear motor that engauges the four wheel drive?
Jim Cav
jimcav is offline
post #4 of 9 (permalink) Old 12-21-2009, 12:08 AM
Smoke05's Avatar
Jim Cav
Get under the truck and pull on the axle. Simply turning the wheel won't do it. Mine did exactly what you are describing and it wound up needing the front axle replaced. Never noticed a leak until much later after the axle shaft movement caused the bearing to wear the hole in the housing oblong. My fluid leaked from around the bearing not out the axle shaft. I think the axle shaft went first.
Smoke05 is offline
post #5 of 9 (permalink) Old 12-21-2009, 07:58 AM Thread Starter
what did you do to fix the problem?
jimcav is offline
post #6 of 9 (permalink) Old 12-21-2009, 08:21 AM
I may be way off base here happens all the time . . .
Start the Beast up, with foot on brake shift to 'N'. What does the 'wheel indicator lights' do? How about the '4Lo' light, what is that doing? (on, off, or flashing)
If the front tire lights are flashing, then turn the 4WD selector back to '2WD'. Now shift into a forward or reverse gear, move the truck a few feet. Now select the opposite direction. Place the shifter back in Park. The front tire lights should now be off. Now turn the selector to '4Hi' and put the Beast back in gear. Does it go into 4WD now?
I know yer thinking you know how to put the Beast in 4WD. But I'm thinking that you don't do it too often. If you accidently attempted to put it in 4Lo without being in 'N' things wont work correctly. Similarly, if you had the wheel turned or were on good traction, it won't always respond immediatly even trying to put it in 4Hi.
Let us know what you have and what you tried.
Jimbo
TheRealJimbo is offline
post #7 of 9 (permalink) Old 12-21-2009, 09:50 AM Thread Starter
Thanks for the reply i will try after work to night, it lost 4 wheel when i was using it thought. I will still try.
Thanks
jimcav is offline
post #8 of 9 (permalink) Old 12-21-2009, 01:48 PM
Any sensors with a bad code (wheel speed sensor, ABS, VDC) or melted wires (when tail pipe busts off the exhaust exiting the pipe likes to burn the wires) the Beast will NOT go into 4WD.
Put a code reader on it and see what you get.
post #9 of 9 (permalink) Old 12-29-2009, 07:24 AM
The same thing happened with mine, the problem was the ABS sensors in all 4 wheels.
(2005 Nissan Titan)
glensmachine is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Lost... d4vid Titan Suspension 8 11-10-2009 06:17 PM
Lost and need help Jennifer507 Titan Wheels, Tires & Brakes 4 10-02-2006 02:17 PM
Lost 30 HP coolwil86 Titan General Discussion 11 03-29-2006 01:49 PM
"Lost" just lost a viewer. Jamesn Off-Topic Discussion 10 10-02-2005 03:57 PM
Lost TV sully0919 Titan General Discussion 16 09-09-2004 12:00 PM
You may post new threads
You may post replies
