TitanTalk.com is the premier Nissan Titan Forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 02-09-2010, 08:57 AM   #1 (permalink)
engine and tranny bad
I have a 2005 titan 4dr 4x4 that i have trbl with the engine and transmission.
the engine first two cylenders on drivers side leaks oil onto the piston and causes severe smoking at start up and while driving,I an=m pretty sure it is bad valve seals that are causing this.I have to add 2 or three qts of oil every 2 weeks to keep oil in the engine.trbl started at 46000 miles.I called the dealer (2 hr drive) and he said bring it in and have someone follow you because they would have to keep it to fix problem.I did as he said and drove two hours one way and had my wife follow me in another vehicle.The mileage was at 59000 when i finally got to take it to the dealer.I do all my oil changes myself,and when they asked for the oil records i said i didnt have any because i do it myself.they told me without oil records that the warranty would not cover the repairs,then i also told them that when the vehicle is in overdrive that it will shimmy and shake when it is at lower rpm.Ididnt get much of a response out of them on that.They just kept insisting that without maint records i would have to pay all out of pocket.I finally lost my temper with them and told them to shove the warranty where the sun doesnt shine because that is all its worth anyway.I now have 91000 miles on the vehicle and it is just barely getting us around.when it quits i am going to park it at a busy intersection and spray paint that nissan warranty sucks on it for everyone to see.Any advice on the engine or tranny would be appreciated.thanks
mega is offline   Reply With Quote
Advertisement
Old 02-09-2010, 09:07 AM   #2 (permalink)
Supporting Vendor
Scott@FontanaNissan's Avatar
Send a message via AIM to Scott@FontanaNissan
Re: engine and tranny bad
A fine example of why you should either keep records of your oil changes with receipts, or bring it in for service. Without these, there is no proof that you did your due diligence in properly maintaining the vehicle. Put yourself in their shoes. With their responsibility to warranty a vehicle within a period of time or miles, you have the responsibility to maintain the vehicle as well. Without proof, there is no way assure Nissan that you didn't abuse it.
It sucks that you're in the predicament that you're in and I'm glad I'm not in your shoes. I'd be happy to get you a great deal on a new motor and tranny when you're ready.
Scott VanderHeide
Fontana Nissan
Become a Fan on Facebook!
http://www.facebook.com/FontanaNissan
Scott@FontanaNissan is offline   Reply With Quote
Old 02-09-2010, 09:18 AM   #3 (permalink)
I agree that there is no proof that i maintained my vehicle correctly but they should have told me all of that on the phone before me waisting a day off and a lot of gas to go to the dealer.I think i will go back to dodge on my next vehicle.I bought a new dodge 1500 in 1995 and it now has 250000 miles on it and i change the oil the same in both vehicles and i dont have any trbl with it.hmmmm wierd huh but the nissan trbl is surely my fault i guess.
Old 02-09-2010, 10:41 AM   #4 (permalink)
2 or 3 quarts of oil every 2 weeks is probably something more than valve seals. Step 1 would be compression and leak down test.
Old 02-09-2010, 10:51 AM   #5 (permalink)
Supporting Vendor
P's Titan's Avatar
Welcome to the Site by the way
Old 02-09-2010, 10:52 AM   #6 (permalink)
NBhunter80's Avatar
I think this might be the problem
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV, Purchased used on 2008/11/30.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, 33" x 12.50" r17 Mickey Thompson Baja MTZ tires on OEM OR 7-spoke 17" rims, Hawk LTS brake pads, MOOG lower ball joints, Axle vent mod, 2 degree timing advance, Stock Airbox mod, Magnaflow 14" SI/SO muffler on stock pipes with 12" T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
'97 Civic EX sedan. 1.6 SOHC Bone stock with 14" rusty steel rims and one missing hubcap.
NBhunter80 is offline   Reply With Quote
Old 02-09-2010, 10:56 AM   #7 (permalink)
vipzach's Avatar
When that happens, leave the key and title in the glove box, I will come by and pick it up!
Why is there never enough time to do it right the first time,
But always enough time to do it again?
vipzach is online now   Reply With Quote
Old 02-09-2010, 01:11 PM   #8 (permalink)
thanks, just looking for a little help or advice
Old 02-09-2010, 02:04 PM   #9 (permalink)
dont feel bad mine is up tyo 4 quarts a week dealer pulled oil pan and said they found sludge on the oil pump screen and wouldnt warranty it gave them my receipts and denied them because vin # was not on the receipts from shop where i got it done NISSAN WARRANTY IS A JOKE!!!!
knighton is offline   Reply With Quote
Old 02-09-2010, 02:18 PM   #10 (permalink)
that is pretty much the same way they treated me.they also said that sludge would void the warranty.like i said earlier they can shove the warranty.if i cannot burn the tires off without something breaking in the engine i need a new brand.
Old 02-09-2010, 02:35 PM   #11 (permalink)
The trolls are lurking...
2008 CC XE w/Pref Package. Red.
Mods:
Autodim mirror w/comp/temp/homelink from a GM truck
Wheelskins Leather steering wheel cover
1.5" PRG Mini-Lift
Auxillary backup lights mounted under rear bumper
Stillen Exhaust
Factory side step bars
XM Radio
Toolbox with extra tiedowns
Future mods:
Intake, Fog Lights, Bullbar, Tow Hooks, Steering wheel radio controls, side moldings
Other rides:
1983 Porsche 944- Gaurds Red- On going project car.- Sold
1990 Wrangler- Black, Rebuilt 4cyl, 4" lift, more stuff
paper1122 is offline   Reply With Quote
The Following User Says Thank You to paper1122 For This Useful Post:
NBhunter80 (02-09-2010)
Old 02-10-2010, 01:41 PM   #12 (permalink)
I thought i might just get a head off of another engine and put it on where the trbl is,what do ya think?
Old 02-10-2010, 02:09 PM   #13 (permalink)
Sounds like a good learning experience. Then you can deal with any bad rings and scored cylinders later.
Torque Converter or bad tranny? TitanTotaleration Titan Engine, Transmission & Drivetrain 19 01-23-2010 08:14 AM
2004 titan engine and tranny problems Teardropcamper Titan Engine, Transmission & Drivetrain 5 01-09-2007 08:57 PM
Engine/Tranny Trouble oktex88 Titan Problems & Dealer Service 12 10-20-2005 09:20 PM
