Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
oil filter - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 05-02-2004, 10:29 AM   #1
goathead
goathead's Avatar
oil filter
just changed the oil for the first time in my titan and noticed that the oil filter was on WAY to tight from the factory. anyone else notice this.
steve
Old 05-02-2004, 10:47 AM   #2
BigJoe_Titan
BigJoe_Titan's Avatar
Yeap, you almost have to be superman to get that little oil filter off the first time. There was thread on it. you may want to do a search on that thread, but, it looks like Bubba put on all the oil filter at factory
BigJoe
Toyota Tundra DC Limited 4x4
Red
06-21-2004
tow
bed liner
step bars
6 cd changer
DRL
BigJoe_Titan is offline   Reply With Quote
Old 05-02-2004, 05:51 PM   #3
Titan4UGA
Yeah mine was put on by the hulk, not to mention it is hard to get to with the off road package. It is a tiny little oil filter, I have seen bigger ones on 4cyl.s.
04 4x4 SE KC
Off Road
Big Tow
Popular Captain
Utility Bed
Window Tint
All Weather Mats
Born 01/04
Delivered 3/20/04
Titan4UGA is offline   Reply With Quote
Old 05-02-2004, 08:29 PM   #4
goathead
goathead's Avatar
i actually think i pulled a shoulder muscle trying to get that filter loose, but alas i did. i actually tried to tighten it a little to get it to "move" and then i was able to get it loose. btw, i used a oil filter wrench that is designed for honda goldwing cycles. it fit perfectly. cost:$12 not too bad, but not the cheapest.
and your right it is a pain getting that filter off w/ the off-road pkg.
steve
Old 05-03-2004, 08:22 PM   #5
bestatchess
I have an 18HP lawn tractor with the same size filter.
Old 05-04-2004, 05:40 AM   #6
JetWrench
Surfing the site looking for just this info. Went to the dealer and picked up my $7.95 p/n oil filter 15208-9e000. Wanted to double check since this thing is a puny little guy. Can this be right???? Does anyone know of a different oil filter non-oem. I read the Nissan manual and it said only replace with Nissan oil filter because of some built in check valve that keeps the oil in the filter? The filter is upside down...pure gravity I would think keeps oil in it???
Cheers!!!!!!!!!!!!!!!
Cold Beersssssssss!!!!!!!!!!!
2-4-04
CC Black
Big Tow, Off Road, UB
JetWrench is offline   Reply With Quote
Old 05-04-2004, 07:19 AM   #7
bestatchess
Yes, I would think gravity does the trick, unless the oil flowing to the sump on shut down creates a siphon effect. I have the same tiny little filter. When I bought it I made the gal at the parts counter bring back the head service guy to confirm. It should come with a copper crush washer for the drain plug. Torque on the drain plug is 25 ft-lbs. It took me 7 quarts to re-fill. (Manual says 6.5) I think K&N has an oil filter, but I don't know if it is any bigger.
http://www.knfilterchargers.com/sear...x?Prod=HP-1010
Old 05-04-2004, 11:21 AM   #8
mtbendo
mtbendo's Avatar
Shop around, I think mine was around $6 at the dealer, include a new drain plug washer. Internet prices are usually pretty good. Some dealers have a AAA discount as well.
04 Galaxy Black Crewcab LE/Big Tow/Off Road/Nav/DVD
Hood Protector/Gibson SS Extreme Duals/Leer XQ Shell/AEM Brute Force
KC Backup Lights/Stainless Steel Grille/Chrome Tailgate Trim/PRG Mini Lift
mtbendo is offline   Reply With Quote
Old 05-04-2004, 06:06 PM   #9
jeff7777
I changed my oil with a Purulator Pure One filter and it is about 1-2 inches longer than the stock filter... It also has the anti-drainback, but with the filter being inverted low on the engine, I am not sure of the benefits... The filter was full when I did the oil change...
jeff7777 is offline   Reply With Quote
Old 05-05-2004, 05:29 AM   #10
JetWrench
Thanks for the input guys! Good info. Will change oil this weekend with all the info noted.
Old 05-05-2004, 07:33 PM   #11
Titan4UGA
Someone asked for a non-oem filter number. I always use purolator with awesome results. They have a regular and a "pure one" both have the numbers are 14610 the pureone just has PL infront of it.
Old 05-06-2004, 06:29 AM   #12
goathead
goathead's Avatar
most nissan part depts charge for the copper washer.
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
