Old 01-01-2006, 05:53 PM   #256 (permalink)
Re: Drive train clunk
Thanks, I just installed mine. Left the spacer rivets out. They really do work great! I had a noticable bounce at exactly 45 mph. I thought it was just the way my tires were wearing. But it only bounced at 45 mph. Now, with the helper springs installed, no bounce! Smooth as it can be. Just this alone is worth the 25 bucks to me!
DD
dirtdobber is offline   Reply With Quote
Old 01-03-2006, 07:13 PM   #257 (permalink)
I installed the helper springs with the spacer rivets at "max" setting. No problems.I am not sure how much of a difference the spacers make... They (the springs) do seem to help with the "clunk"...
jeff7777 is offline   Reply With Quote
Old 01-15-2006, 07:32 AM   #258 (permalink)
Hey Guy's
About this helper spring instal... Im looking at the pic's and comparing to my 2005 K/C and I see I have 4 leaf springs and the pic shows 3 leaf springs with a real short spring on the bottom. My 4th leaf spring is much longer on mine and hings down about 1 1/2" lower than the next spring. Did they make a change in the rear springs for the 05s?
Thanks
Rocky
rocky2024 is offline   Reply With Quote
Old 01-15-2006, 08:11 AM   #259 (permalink)
here is a pic of the 4 leaf springs
Old 01-15-2006, 11:37 AM   #260 (permalink)
Same as the 04.
Bilsteins 5100 fronts set at 1 inch. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 01-15-2006, 12:08 PM   #261 (permalink)
thanks, here is my 05
Old 01-15-2006, 02:30 PM   #262 (permalink)
Removed my (JT) Helper springs and installed these. Will not lower the rear of the truck. Hellwig Traction Springs
Old 01-15-2006, 04:02 PM   #263 (permalink)
They look good! Here's my situation....I bought a weight dist. hitch to use with my 6300lb trailer. Works well so if I put those springs on will I have to re adjust the dist. hitch? It was a pain to adj. when I first put it on.
Rocky
Old 01-15-2006, 04:27 PM   #264 (permalink)
I wouldn't think so. Doesn't change the height in the rear
Old 02-04-2006, 08:25 AM   #265 (permalink)
Colorado_Titan's Avatar
Finally just got reading thru all these posts. I have the same kind of clunking movement when accelerating from a dead stop. Can't hear anything just feel a little clunk. How about using traction bars instead of these springs? Will the benifits be the same? Also for you guys that did this in 2004 (helper springs), that is when this post started, how is everything now? Still normal? Thanks for any input.
2006 Granite 4x4 LE Kingcab with Offroad package, Big Tow Package, and Power Captains.
Born: 9/05 Mine: 1/06
Colorado_Titan is offline   Reply With Quote
Old 02-06-2006, 08:19 PM   #266 (permalink)
Just had the same problem. Come to find out Rear transmission mounting bracket was broken in half on my titan. Part cost about a bill plus labor. You can check by putting your truck on a lift and prying the trans up from the mounting bracket. Hopes this helps.
sfd02 is offline   Reply With Quote
Old 03-12-2006, 09:13 PM   #267 (permalink)
triadpc's Avatar
Question Re: Drive train clunk
Just installed a set of NAPA leaf spring helpers today (after reviewing this 2 year old thread), but I still hear the clunking noise when accelerating from a dead stop (especially in the morning when leaving for work).
Maybe I don't have the bolts tight enough. Can someone who has installed this kit and successfully eliminated the clunking noise let everyone else know how much to torque the nuts on the U-bolt? Once the kit has been installed, should the factory leaf springs be totally compressed/flat? I believe that I have 6 threads visible on the bolts that secure the u-bolt to the leafs.
I am crossing my fingers that I don't have a broken rear transmission mounting bracket like the previous guy who posted his comments above.
Also, sometimes I hear a clicking noise, which seems to be originating from the center console shifter (don't have the column shifter). This seems more prevalent during "stop and go" situations (like in traffic or going through the drive-through at a fast food restaurant).
Does anyone know about this issue, and if so, is there a fix for this as well?
triadpc is offline   Reply With Quote
Old 03-13-2006, 06:18 AM   #268 (permalink)
travism's Avatar
Send a message via AIM to travism Send a message via Yahoo to travism
triadpc - are you sure the clunk from a stop isn't this?
Noise at 10mph
And your shifter problem might be this?
Click from the shifter
Hope this helps?
'04 Titan SE King Cab 2WD Deep Water
Popular Pkg w/ Captains, Big Tow
Added: OEM step rails & splash guards, leaf spring helpers, Line-X, TruXedo LoPro tonneau, Wade In-channel window visors
Born 6/3/04, Bought 7/5/04
travism is offline   Reply With Quote
Old 03-13-2006, 05:51 PM   #269 (permalink)
triadpc's Avatar
Hi travism,
This sounds exactly like the issues I'm experiencing.
I will pull the ABS fuse out this weekend to see if the clunking noise goes away. If not, I'm starting to get worried given the tranny and rear end issues that I've been seeing on this forum for the 04's and 05's.
Thanks again for this information!
triadpc
Old 03-13-2006, 06:03 PM   #270 (permalink)
I would think the traction bars would be the way to go. I have had the helpers on for a long time w/o problems. I am thinking about having traction bars + Deaver pack + TruTrac installed when they get the TruTrac perfected.
