Old 05-08-2004, 12:16 AM   #1 (permalink)
Send a message via AIM to MaxPowers
gears
I know the ratio for a Titan without tow package is 2.94 which is like a 3.73 four speed automatic. Do the Titans come with Dana 44, cuz i thought i heard that somewhere? I was just wondering in case i wanted to change them because of bigger tires.
MaxPowers is offline   Reply With Quote
Old 05-08-2004, 05:16 AM   #2 (permalink)
BigJoe_Titan's Avatar
Maxpowers,
Can't say it is an actual Dana 44, but is based on a DANA 44. Spec's below
and the service manual is listing as a M 226 2-pinion.
Engine and Driveline
• Nissan Endurance 5.6-liter DOHC V8 producing over 305 horsepower @ 4,800 rpm and more than 379 lb-ft of torque @ 3,200 rpm
• Aluminum block with cast iron cylinder liners, forged steel crankshaft, microfinished crankshaft and camshaft, molybdenum-coated pistons, 6-bolt main bearing caps, Super Silent single-stage timing chain)
• Standard 5-speed electronically controlled automatic transmission with tow/haul modes for enhanced fuel economy and towing capacity
• Available Vehicle Dynamic Control (VDC) with Brake Activated Limited Slip Traction Control (includes deactivation switch)*
• Rear axle based on the Dana 44 model
• Tire Pressure Monitor System
BigJoe
Toyota Tundra DC Limited 4x4
Red
06-21-2004
tow
bed liner
step bars
6 cd changer
DRL
BigJoe_Titan is offline   Reply With Quote
Old 05-09-2004, 07:03 PM   #3 (permalink)
Austin's Avatar
MY04 SE King Cab 4X4 SOLD!
