Old 05-10-2004, 06:07 PM   #1 (permalink)
Drive line clunk
Chevy 4x4's had this same problem with a sticking prop shaft front slip yoke.They came out with a redesigned nichol plated slip yoke for the concern.THIS WAS FOR '01-'02 MODELS,but earlier models with the same symptons were fixed by just lubing the inside splines of the slip yoke.By the way I have not felt this clunk in my Titan.
smhinds is offline   Reply With Quote
Old 06-01-2004, 11:55 AM   #2 (permalink)
Thanks for the tip it fixed my titan
RedBrawn Titan
CC LE 4X4
Big Tow
Born 3/04
wolfox2004 is offline   Reply With Quote
Old 06-01-2004, 01:40 PM   #3 (permalink)
z3axv's Avatar
Are there grease fittings on the slip yoke? How did you lube the splines? thanks
z3axv is offline   Reply With Quote
