Old 09-12-2004, 08:27 AM   #1 (permalink)
kmonto's Avatar
Transmission Fluid
Ok, I did a search and didn't see my answer... Has anyone changed their transmission fluid to something other than Nissan's fluid? What about the castrol one? If the fluid meets the specs of the Nissan's fluid, why are they being so specific with the use of their oil?
Arkansas "Go Hogs"
2004 Nissan Armada SE OFFROAD 4x4
Mods: Tinted Windows, Volant, Airaid TBS, FilterMag, Flowtech Terminator Muffler
Future: Intake
Oil: MOTOR: Amsoil 0w-30 with Amsoil Filter DIFF: AMSOIL 80w-90
Tires: LT33/12.5/R17 Cooper Discoverer S/T
2004 Nissan Sentra 1.8S
Mods: Tinted Windows, FilterMag, PopCharger Air Intake, Flowtech Raptor Muffler
Tires: 205/60/R15 Goodyear Assurance TripleTred
2005 Toyota Echo
Mods: Don't need them, 43-44mpg average
kmonto is offline   Reply With Quote
Old 09-12-2004, 12:47 PM   #2 (permalink)
I'm 99 percent sure no one has done enough miles to want to change it and no one has used another kind because of the potential to lose the warranty. the castrol J fluid will work but where can you find it? if you live in canada you can use regular dexron/mercon. otherwise, they want you to buy the nissan fluid because they make 9.50 on every quart they sell you. juma
Old 09-23-2004, 11:55 PM   #3 (permalink)
I went to 2 dealers, and so far have scored 2 quarts. There seems to be more in my transmission than on all the dealer's shelves.
2004 Titan LE 4x4 King Cab - Radiant Silver
Navigation/Off-Road/Big-Tow
2002 Yamaha FZ1 - Silver
2001 KTM 520EXC
Tom Roper is offline   Reply With Quote
Old 09-24-2004, 05:17 AM   #4 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
Im not sure how crucial it is to use Nissan's own fluid. But being a former Dodge owner and hearing the horror storiers of what was happening in some of the dodge models by just using a premium ATF vs. thier specific fluids sacres me into using only what Nissan recomends. I wouldn't belive it myself (or thought that a manufacturer would build such strange stuff) but it seems to be the case. Dodge made clutch plates in the automatics of some minivan and car models that would be eaten away by regular tranny fluid and just mess everything up (just search "dodge tranny" in seach engine, it'll pop up all over). Not that Nissan would do such a thing, but better a few bucks poorer now than than a tow hook home later.
Old 10-09-2004, 08:35 PM   #5 (permalink)
Amsoil Synthetic ATF is what I'm using in my 2k2 Maxima and my 2k1 Dodge Durango. I've had no problems whatsoever. I plan on using it in the Titan as well.
virus is offline   Reply With Quote
Old 10-13-2004, 12:07 AM   #6 (permalink)
NorCal 4x4's Avatar
Type "J" please.
Better wait until Amsoil comes out with a type "J" fluid. Otherwise you will be buying your Titan a new transmission. Can't be cheap. Even the Amsoil website recommends Nissan "J" ATF.
Old 10-13-2004, 12:43 PM   #7 (permalink)
xsive11's Avatar
what does the "J" stand for?
xsive11 is offline   Reply With Quote
Old 10-13-2004, 02:48 PM   #8 (permalink)
IMADOGMAN's Avatar
J is for JACK up the price....
IMADOGMAN
2004 NISSAN TITAN KC SE
4x4 Offroad (E-locker)
Big Tow Pkg
RF/Power Captains
Utility Bed Pkg
White Q10
LEER 100XQ
Old 10-13-2004, 03:06 PM   #9 (permalink)
For those of you running Amsoil in the engine and diff., did you get any MPG increase? I am planning on putting the Amsoil in on Saturday.
mickeysfan is offline   Reply With Quote
Old 10-17-2004, 09:56 AM   #10 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
How do you guys replace the transmission fluid without going to the dealership?
We don't even have a dip stick for the transmission and how do we know how much to put in?
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 10-17-2004, 03:44 PM   #11 (permalink)
phillipyang;
WE do have a dip stick for the transmission. It is the one with the bolt holding it on. It is about 2 inches to the left of the engine oil fill tube.
2007 Tundra Limited DC 4X4
5.7L,NAV,TRD,TOW
Xlerator Exhaust
aFe Stage 2 CAI
Desert Sand Mica
skyhammer is offline   Reply With Quote
Old 10-17-2004, 04:13 PM   #12 (permalink)
drain out 4 quarts from the pan cold and then replace with the same amount. it will drain a little more than 4 so be sure to stop it at 4 to avoid guessing how much to put in. mark a couple of one gallon milk jugs at the 2 quart line and use them to catch the old fluid. do this change of 4 quarts about every 10k miles and the tranny will last 100k plus. juma
Old 10-17-2004, 05:21 PM   #13 (permalink)
Originally Posted by skyhammer
phillipyang;
Bolt requires 10mm socket.
From a 'Everyone PLEASE READ!!!' (really good reading - to read!) post by Austin http://www.titantalk.com/forums/show...2&postcount=28
Take note in above link: REVERSE gauge/stick when taking fluid level readings!
billaku is offline   Reply With Quote
Old 10-17-2004, 07:55 PM   #14 (permalink)
where can we purchase the special j fluid? does nissan have it readily available for purchase? Or can an equal substitute be found elsewhere?
Purchased: Feb 2004
Old 11-16-2004, 05:30 PM   #15 (permalink)
kmonto's Avatar
Well, I went ahead and got it changed out...
I have reached the mighty 20K on the odometer and after my discussion with the Nissan customer service department, I chose to go with the Nissan trans oil. Apparently when they say, "Only use Nissan transmission fluid" they really mean it. Warranty voided if failure and they test the oil and find something different. So I contacted my local dealership and made the appointment to have the trans fluid flushed using that pressure machine. 11+ quarts later, it's done. Frush trans fluid is now in my baby. Of course it's the mandatory Nissan trans fluid. Cost?!? They wanted 12.95 per quart, I told them no way and to call around. They did and price adjusted the quarts down to 9.15 a quart. However, overall cost of a transmission flush is incredible I feel better knowing I got the original oil replaced. To bad I couldn't use AMSOIL.
Arkansas "Go Hogs"
Future: Intake
2005 Toyota Echo
