2010 Rear differential noise(whine) - Nissan Titan Forum
post #1 of 102 (permalink) Old 02-15-2011, 04:06 PM Thread Starter
iTrader Score: 0 reviews
Thumbs down 2010 Rear differential noise(whine)
My 2010 Nissan titan has a noise(whine) that begans at 45mph and goes up to 72mph. Nissan will not replace the rear differential because the replacement part will have the same noise. They are avoiding the problem. Two 2010 Titans on the dealership lot have the same noise. They are telling me this a common problem with 2010 Titans.
MOTS is offline
Advertisement
post #2 of 102 (permalink) Old 02-15-2011, 04:16 PM
jimmy120's Avatar
iTrader Score: 5 reviews
Re: 2010 Rear differential noise(whine)
Hmm. Must be a common problem in the 2004 as well. Mine is a whinny baby. I would take it to another dealer, you are still under warranty. Did they say what was actually causing the whine?
Truck:
2004 Nissan Titan Crew Cab 4x4
Mods:
Superchips, aFe Magnum Force Stage 2 CAI, Dual Exhaust (thrush mufflers), Walker B-pipes, Hankook DynaPro ATM RF10 tires, Aluminum rear diff cover, Rear axle vent mod, Bushwacker Fender Flares, Keystone Good Hood (RAM AIR), Spec-D Altezza Head lights and Tail Lights.
jimmy120 is offline
post #3 of 102 (permalink) Old 02-15-2011, 09:42 PM
AZPRO4X's Avatar
iTrader Score: 8 reviews
I personally wouldn't worry about It. My Navigator has a whine also, your going to get some noise regardless. Put a Magnaflow/ Flowmaster on it and that will take care of it.
08 Pro-4x moonroof,Tow,DVD,SWB,Banks Monster Exahust, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,285/65R18 Cooper ATP,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline
The Following User Says Thank You to AZPRO4X For This Useful Post:
Titanite (01-26-2013)
post #4 of 102 (permalink) Old 02-15-2011, 10:08 PM
VK56DEHAN's Avatar
thats weird because i dont have a whine at 45+....and anyone that has read any of my posts or knows me knows how OCD i am about noises. i have banks now so i def wouldnt be able to hear it. the only whine or whistle i have is coming from my transmission when it gets warm after driving for a while. figured it was normal since i have no tranny issues or fluid issues.
VK56DEHAN is offline
post #5 of 102 (permalink) Old 02-15-2011, 11:25 PM
sudden urge's Avatar
iTrader Score: 4 reviews
There should be no whine at 10,30,50, or 80+.
Chicago area 05 KC SE 4x2 FFV, smoke, 2.94 gearing. Mods: Hypertech Max Energy, JBA catback, Airaid 4" MXP CAI, Hellwig HD traction springs, 08 rear shackles, Nasta nerf bars, Kenwood KSC-SW1 powered sub. Best full street trim (5120#) 1/4 mile track time of 14.632 running Bully Dog 87+2 and S&B CAI. 1/8 mile 9.30@74.49 with a 2.11 60'.
sudden urge is offline
post #6 of 102 (permalink) Old 02-16-2011, 12:23 AM
jimmy120's Avatar
This is what mine sounds like.
I was doing some searching and it appears it may be the ring and pinion that is causing the noise. I also read that it does NOT mean impending DOOM...
Truck:
Mods:
jimmy120 is offline
The Following User Says Thank You to jimmy120 For This Useful Post:
TCinGH (12-17-2013)
post #7 of 102 (permalink) Old 02-16-2011, 09:03 PM
jimmy120's Avatar
Anyone else sound like the video posted in the above link?
Truck:
Mods:
jimmy120 is offline
post #8 of 102 (permalink) Old 02-16-2011, 09:08 PM
I would be thinking rebuild if mine sounded like that.
bestatchess is offline
post #9 of 102 (permalink) Old 02-17-2011, 09:53 AM
El Equis's Avatar
Mine has a whine if throttle is OFF
Especially noticeable between 35-55 - I remove my foot from the gas and let it engine break, there is a very loud whine/grinding noise that reverberates through the drivetrain. I have not figured out what it is yet, I suspect failing rear differential (2006 with 84K) since it is so common but I haven't ruled out some other issue.
I have not found a good thread on "differential symptoms" that would tell me what a rear diff pending failure sounds or behaves like.
El Equis is offline
post #10 of 102 (permalink) Old 02-17-2011, 12:01 PM
jimmy120's Avatar
I am glad mine is not grinding. I am thinking about going with TruTrac eventually.
Truck:
Mods:
jimmy120 is offline
post #11 of 102 (permalink) Old 02-17-2011, 12:27 PM
It is extremely annoying that you can't buy new ring & pinion sets for the rear axle in the OEM axle ratios.
You can buy an OEM gear set for the front diff for 2004-2007, yet not for the rear.
post #12 of 102 (permalink) Old 02-17-2011, 12:35 PM
El Equis's Avatar
With the number of failures I am surprised there isn't an aftermarket ring and pinion option.
El Equis is offline
post #13 of 102 (permalink) Old 02-17-2011, 12:40 PM
You can buy aftermarket R&P gear sets, but not in the OEM ratios. So you are looking at getting big tires to offset for the 4.10 or 4.56 gears, and of course to run big tires, you need new wheels, a lift, and you're gonna want some expensive coilovers, shocks and UCAs, and some traction bars, and probably gonna wanna some upgraded CVs when those come out. . . . .
post #14 of 102 (permalink) Old 02-17-2011, 12:54 PM
El Equis's Avatar
And, since I have 4WD, I have to change the front gearing too. Kind of ridiculous.
I am going to pull the differential cover to see the damage, and I am flat scared to do so. If the axle gears are shot I am screwed. TrueTrac+PML Cover seems like a bargain comparatively.
El Equis is offline
post #15 of 102 (permalink) Old 02-17-2011, 02:46 PM
Most likely the spider gears, not the ring and pinion gears
Bilsteins 5100 fronts set at 1 inch. 1" rear drop shackles
Wet Okole Front seat covers.
New front differential at 60500 miles. [goodwill fix denied]
Detroit Truetrac at 61000 miles
Herbpov is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
**FREE** 2010 Titan Dana 44 Rear Differential **FREE** CrazyHorse89 Buy/Sell 31 11-24-2010 09:23 PM
**WOW** 2010 Titan Dana 44 Rear Differential $150 **PRICED for Quick SALE** CrazyHorse89 Buy/Sell 39 09-01-2010 09:20 AM
2010 Titan Rear Differential $600 OBO Like NEW CrazyHorse89 Buy/Sell 18 08-02-2010 08:36 AM
2010 Titan Dana 44 Rear Differential $500 CrazyHorse89 Buy/Sell 27 03-08-2010 07:50 AM
STRANGE NOISE(engine whine) Demondw3 Titan Problems & Dealer Service 13 09-14-2008 11:46 AM
You may post new threads
You may post replies
