Go Back   Nissan Titan Forums > Titan Technical Discussion Area > Titan Engine, Transmission & Drivetrain
User Name
Password
Oil filter question - being discussed at Nissan Titan Forums in the Titan Engine, Transmission & Drivetrain section.
Old 07-05-2004, 12:57 AM   #1
fklentz
Send a message via MSN to fklentz Send a message via Yahoo to fklentz
Oil filter question
I'm only at 1200 miles now BUT I was looking at the filter, it's size and location. It looks like the same one my Frontier had. The location makes changing it a little messy and I was wondering if the oil filter relocation kit that I put on the Frontier will also work on this truck. Anybody got any input?
fklentz is offline   Reply With Quote
Old 07-05-2004, 06:54 AM   #2
Nr1 Qualifier
If you have the Off-Road package just remove the little panel
on the skid plate and your have easy access to the filter. If
no Off-Road then remove the entire skid plate by loosening
the rear two bolts and removing the front two. It's a piece of
cake. Can't get any easier than that, everything it right there
including a little drip spout so you don't get filter oil all over
everything.
Nr1 Qualifier
2004 LE KC 4x4
Nr1 Qualifier is offline   Reply With Quote
Old 07-05-2004, 07:37 AM   #3
Bayou Titan
It's really easy to change oil in the Titan. I think the main thing you need to do make oil changes easier is to get a Honda Gold Wing oil filter wrench from a Honda motorcycle dealership or the kind that slips over the end of the filter like a giant socket. If you use the traditional metal strap type wrench it is somewhat difficult because you run out of room to unscrew the filter before the band starts to tighten up around the filter. There has been a zillion posts (maybe more) concerning oil changes and the Titan. You may want to start
with this post:
http://www.titantalk.com/showthread....ighlight=chute
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
