Gear ratio??? - Nissan Titan Forum
post #1 of 28 (permalink) Old 08-12-2011, 08:10 PM Thread Starter
iTrader Score: 1 reviews
Gear ratio???
I'm looking at buying a new 20111 Titan.
The book says "Final gear ratio (2.94:1 similar to a 4 speed automatic 3:73:1) and Lower final gear ratio (3:36:1 similar to a 4 speed automatic 4:10)
WTF does the automatic trans have to do with the rear differential gear ratio????
Can somebody explain this? I plan on towing maybe up to 4000lbs with this.
Which do I need?
donedirty is offline
Advertisement
post #2 of 28 (permalink) Old 08-12-2011, 08:24 PM
IGotLost's Avatar
iTrader Score: 0 reviews
Re: Gear ratio???
The Titan transmission is a 5 speed.
Alot of people are used to having a 4 speed tranny, so the 2.94 and 3.36 ratio can seem off to them.
If you will only haul 4K pounds, the 2.94 will be just fine. I can't think of anybody that regrets having the BT(3.36) gears though.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
IGotLost is offline
post #3 of 28 (permalink) Old 08-12-2011, 08:38 PM Thread Starter
Re: Gear ratio???
How can a 2:94 be similar to a 3:73? It either is or it isn't...!
post #4 of 28 (permalink) Old 08-12-2011, 08:43 PM
IGotLost's Avatar
Re: Gear ratio???
It has to do with the tranny gearing.
Hopefully somebody smarter than me can explain this in an easy to understand way.
IGotLost is offline
post #5 of 28 (permalink) Old 08-12-2011, 08:45 PM
Scan999's Avatar
Re: Gear ratio???
I asked that same question last year. Here is the answer I was given. Bottom line get the BT package at the very least.
gearing confusion (NorCal, anyone?)
05 LE CC 4x4 BT
Mods:
lots of stuff
Scan999 is online now
post #6 of 28 (permalink) Old 08-12-2011, 09:22 PM Thread Starter
Re: Gear ratio???
Would putting it into the Tow Haul mode keep it in 4th gear and be better for highway use while towing?
post #7 of 28 (permalink) Old 08-12-2011, 09:25 PM
IGotLost's Avatar
Re: Gear ratio???
No. Tow Haul only raises the shift points 1-3 gear.
You will have to put it in 4th to keep it out of 5th.
IGotLost is offline
post #8 of 28 (permalink) Old 08-12-2011, 09:29 PM Thread Starter
Re: Gear ratio???
If you put the trans into "D," wouldn't the trans pick it's own optimum gear while towing on the highway?
post #9 of 28 (permalink) Old 08-12-2011, 09:35 PM
IGotLost's Avatar
Re: Gear ratio???
Not really. It will sometimes stay in 5th and lock/unlock the torque converter.
Since you are buying a 2011, it will have the tranny temp gauge. Keep an eye on the gauge, if it climbs, pull it down a gear. Don't worry though, the Titan revs just fine and can run all day at the higher RPM.
IGotLost is offline
post #10 of 28 (permalink) Old 08-12-2011, 09:41 PM
Scan999's Avatar
Re: Gear ratio???
I THINK and don't know for sure because I'm no expert you want to manually put the trans in 4th gear on the highway towing. This will give you the 3.36 ratio and more power going up hills and dealing with gradual inclines. The misleading part of Nissan website is saying it is like 4.10 gears when that is totally not true in 4th gear.
05 LE CC 4x4 BT
Mods:
lots of stuff
post #11 of 28 (permalink) Old 08-12-2011, 09:55 PM Thread Starter
Re: Gear ratio???
I'll be honest...
I'm starting to feel less comfortable about buying this Titan.
I currently have a 2005 Explorer with a 4.0 V six and the 3:73 gears and it tows just fine.
I wanted to upgrade, is the Titan really an upgrade?
post #12 of 28 (permalink) Old 08-12-2011, 10:00 PM
Scan999's Avatar
Re: Gear ratio???
That is a loaded question. I love my T and wouldn't trade it for the world. Maybe some of the Titan owners that tow a lot can give you more insight and feedback of the Titan towing.
05 LE CC 4x4 BT
Mods:
lots of stuff
post #13 of 28 (permalink) Old 08-12-2011, 10:01 PM
Learjet's Avatar
Re: Gear ratio???
I'll be honest...
LOL...yes, it will be a BIG up grade from that V6
SOLD, after 122,000 great miles:
2006 SE, CC, Big Tow, white
Born 5/06
Timbrens added
Learjet is offline
The Following User Says Thank You to Learjet For This Useful Post:
OneQuick06 (08-14-2011)
post #14 of 28 (permalink) Old 08-12-2011, 10:06 PM Thread Starter
Re: Gear ratio???
Am I really going to have to deal with the 4th gear stuff every time I tow?
post #15 of 28 (permalink) Old 08-12-2011, 10:14 PM
IGotLost's Avatar
Re: Gear ratio???
It is not really an issue.
Just keep an eye on your tranny temp gauge.
When I am on long flat roads, I leave it in OD. If coming into an area with hills, I push it into 4th. No big deal!
I guess I don't get your worry. My previous tow vehicle was an explorer also and I would do the same thing.
For me, the Titan is leaps and bounds above the Explorer.
IGotLost is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
gear ratio RANDY Titan Engine, Transmission & Drivetrain 26 02-25-2011 09:06 AM
New Gear Ratio 4.88 CL 8 2WD Titan Engine, Transmission & Drivetrain 13 07-01-2009 09:52 AM
gear ratio w/ big tow randyt Titan Towing & Hauling 36 09-06-2008 09:17 AM
Gear Ratio hondarider227 Titan Engine, Transmission & Drivetrain 14 12-14-2006 03:40 PM
gear ratio Skeeter Titan General Discussion 8 02-24-2005 01:48 PM
You may post new threads
You may post replies
