My engine is running extremely rough - Nissan Titan Forum
post #1 of 11 (permalink) Old 08-20-2011, 07:06 PM Thread Starter
iTrader Score: 0 reviews
I pulled up to a red light and the engine started to run extremely rough and was barely running. It acted like it was only hitting on 2-3 cylinders. I tried to give it some gas to pull off to the side of the road and it died. Tried to start it again and the same thing. I let it sit for about 2 minutes and it fired right up and ran like a top. I get to my dad's house to take a look around and could not find anything and it sits for about an hour and a half and then I start it up to go home and I make it about a half mile down the road and it does it again and this time it will not clear up. It will start up and run rough enough to power the steering and brakes but will not budge from it's tracks. Any help will be appreciated.
nonchalant is offline
Advertisement
post #2 of 11 (permalink) Old 08-20-2011, 09:35 PM
IGotLost's Avatar
Re: My engine is running extremely rough
What year, how many miles?
First guess........IPDM.
Why is there never enough time to do it right the first time,
But always enough time to do it again?
IGotLost is offline
The Following User Says Thank You to IGotLost For This Useful Post:
nonchalant (08-21-2011)
post #3 of 11 (permalink) Old 08-21-2011, 12:59 AM
honda250xtitan's Avatar
Garage
iTrader Score: 9 reviews
second guess... fuel pump.
clogged cats?
2011 White CC Pro4x
STOCK AF
Partout Thread\/\/\/
DIRT KING FABRICATION, FOX, TOYO, FUEL, PRG, GIBSON, BORA, AIRAIDhttp://www.titantalk.com/forums/buy-...od-prices.html
Traded In: 06 KingCab 4x4
honda250xtitan is online now
The Following User Says Thank You to honda250xtitan For This Useful Post:
post #4 of 11 (permalink) Old 08-21-2011, 04:28 AM Thread Starter
2005 with 87000miles. I undone the exhaust manifold from the cats to let it breathe and it still is the same. I tried it again this morning and it fired right up and ran fine for about 10 seconds and went back to running rough. While it is doing it the SES light,the 4WD light and the four wheel drive diagram are all three flashing very quickly.
post #5 of 11 (permalink) Old 08-21-2011, 05:58 AM
snorkel's Avatar
iTrader Score: 1 reviews
have you done the ipdm relay recall? i think its the ipdm relay, research here about ipdm relay.
snorkel is offline
The Following User Says Thank You to snorkel For This Useful Post:
post #6 of 11 (permalink) Old 08-21-2011, 06:15 AM
Kronos1965's Avatar
I would switch out the fog light relay with the IPDM first to test the theory.
I wouldn't rule out the MAF sensor going bad as well.
HippieWhore™
Be the kind of person your dog thinks you are.
Kronos1965 is offline
The Following User Says Thank You to Kronos1965 For This Useful Post:
post #7 of 11 (permalink) Old 08-21-2011, 07:05 AM
TitanBlue's Avatar
iTrader Score: 3 reviews
Some have had the fuel pump fail too. Get the codes read right away.
2006 XE CC Pref Pkg BT with AEM Brute Force CAI, PowerAid TB Spacer, TB Reversed Valve ByPass Mod, 2007+ Intake, JBA Headers, MagnaFlow 24" Muffler, 2008+ Rear Axle, Stillen: F & R Sway Bars, Black Diff Cover, Engine Dress Up Kit, 4 pc StreetScene SS Mesh Grille, PRG End Links, Street Traction Bars & Shackles, UpRev Osiris Tuner 93 Performance Tuned, 18" SE Rims, Functional Hood Scoop ...
TitanBlue is offline
The Following User Says Thank You to TitanBlue For This Useful Post:
post #8 of 11 (permalink) Old 08-21-2011, 09:11 AM
NBhunter80's Avatar
IPDM relay sounds likely, or even a bad battery. MAF sensor or fuel pumps are also possibilities. Also, are you sure that you didn't get some bad gas? But I agree to get codes read ASAP and park the truck until you resolve the issue. Good luck!
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
The Following User Says Thank You to NBhunter80 For This Useful Post:
post #9 of 11 (permalink) Old 08-21-2011, 12:24 PM Thread Starter
I have been researching it too and will try it(swapping the fog light relay) when I get home. I will keep you posted. Thanks for the help.
post #10 of 11 (permalink) Old 08-21-2011, 02:24 PM Thread Starter
Thumbs up Re: My engine is running extremely rough
I got home from work and changed relays and it fired right up and and continues to run. I will call my local Nissan dealer to talk about the recall. I am just not real confident about driving it there. Thanks again for all the help and pointing me in the right direction.
post #11 of 11 (permalink) Old 08-21-2011, 02:31 PM
TitanBlue's Avatar
The IPDM Relay recall was not active on my June 2006 build date. I went ahead and bought the new Relay they use anyway, but have not installed it. Due to it being a Recall item, they sell it for roughly $3. P/N 284B7-CW29E, I got mine for $2.64 at local dealer.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Service Engine Light - Rough Running slowrider Titan Problems & Dealer Service 8 06-29-2015 04:31 PM
Guys running the Rough Country level kit Corbin Titan Suspension 10 02-23-2011 12:53 PM
Cold EXTREMELY rough starts, then no problems... ddr698 Titan Engine, Transmission & Drivetrain 2 02-11-2011 05:57 PM
1st post, problems w/Titan running ROUGH rowdyr Titan General Discussion 7 03-01-2010 09:11 PM
Engine Running Rough oktex88 Titan Problems & Dealer Service 10 02-13-2005 12:43 AM
You may post new threads
You may post replies
