Front axle CV seal leaking - Nissan Titan Forum
post #1 of 7 (permalink) Old 09-20-2011, 07:19 AM Thread Starter
iTrader Score: 0 reviews
I noticed today that i am leaking right behind the cv axle where it goes into the differential.
is this a big deal?just keep topping the fluid off? im have to replace the cv axle anyway for a cracked boot..
im assuming pull the old cv axle and the seal will be right there? should i do both sides? the other side it the side with the cracked boot. 120,000 04 titan. might as well do suspension,cv axles, that seal from above, I did front wheel bearings a couple months ago. wish i would of had a cracked boot then or leaking fluid..
parts are pretty cheap i think seal is something like 30 bucks, cv axle are 75,
if thats right? does anyone have part numbers for this stuff
Thank you
Chris
dckiteboards is offline
Advertisement
post #2 of 7 (permalink) Old 09-20-2011, 07:21 AM Thread Starter
Re: Front axle CV seal leaking
im thinking this is it?
gonna ask some mechanic buddies today.. have them crawl under her!
Nissan Parts, NISMO and Nissan Accessories - Courtesyparts.com
post #3 of 7 (permalink) Old 09-20-2011, 07:56 AM
honda250xtitan's Avatar
Garage
iTrader Score: 9 reviews
it might be leaking because the boot is cracked. mine did that on my 06. bestatchess seems to know all the axle stuff and what not on these trucks, maybe pm him.
2011 White CC Pro4x
STOCK AF
Partout Thread\/\/\/
DIRT KING FABRICATION, FOX, TOYO, FUEL, PRG, GIBSON, BORA, AIRAIDhttp://www.titantalk.com/forums/buy-...od-prices.html
Traded In: 06 KingCab 4x4
honda250xtitan is offline
post #4 of 7 (permalink) Old 09-20-2011, 11:07 AM
NBhunter80's Avatar
Sounds like your axle might have popped out of the dif. The cv axle has a flange that bolts up to the dif itself, so if you are leaking on the inside of the flange (towards the center of the truck), that would be your dif leaking. I'm not aware that you can leak fluid from the u-joint on the cv axle. If it is just the half-shaft, it should be an easy fix. If it is your dif, you can try popping it back into the dif, but if the c-clip is broken or damage to the dif, you might be in for a new front dif. Post some pics and we can help more.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #5 of 7 (permalink) Old 10-04-2011, 01:32 AM
slice07's Avatar
iTrader Score: 5 reviews
if you are going to replace the boot then go to carquest and purchase it from there. their cv joints have a larger boot. mine kept cracking and tearing due to my lift and tires. i went throught 2 before i came across carquest's boot. i've had both on for a year now no troubles.
bushwhacker pocket style fender flares
Spray bed liner billet grille
aem brute force cai prg c10 pack & UCA's
Hypertech inline speedo correction
pro comp 6'' lift 4'' rear block 3'' body lift
Driveshaft spacer Prg shackles
saw coilovers (front) with 1.5'' spacer
radflos 2.5 (rear) uprev/osiris
motometal 959 prg axle vent mod
toyo open country m/t 37x13.5x20
Hawk big brake kit frozen rotors
4.10 gears front & back Amp research steps
Detroit trutrac diff long tru cool 4588
magtech diff cover metal works traction bars
jba exhaust borla muffler swap jba long tube headers
COMING SOON-Transgo shift kit, pml transmission pan
slice07 is offline
post #6 of 7 (permalink) Old 10-04-2011, 03:54 AM
iTrader Score: 3 reviews
I am almost willing to bet if there is fluid leaking out that the axle pulled out a little bit. Is this an older Titan? I would just push it back in and see if it leaks anymore. I had this issue when I did my level kit and new shocks. It was just the crap clip they put in the inside of the axle that's supposed to keep it from popping out. It generally won't do this unless you have taken the front end apart and you didn't notice that it pulled out a little. By a little I mean like 1/8", that is enough to cause the leak.
cayers1122 is offline
post #7 of 7 (permalink) Old 12-27-2011, 12:31 PM
slwilson6's Avatar
mine is a '07 with 108k miles and newly replaced pinion seal about 15k miles ago. just started leaking where the axle meets the diff. can't really see where from, but the fluid is spraying back towards my oil pan drain plug. i first thought that the oil plug wasn't tightened well enough after my oil change. any suggestions?
ASK ME ABOUT THE ANNUAL TEXAS NISSAN TRUCK MEET.
EMAIL: texastitanmeet@gmail.com
CURRENT: 2012 TITAN PRO 4X CREW CAB, PRO COMP STAGE 1 LIFT. AIRAID MXP COLD AIR INTAKE. PRT PERF CATLESS BPIPES. CAJUN YPIPE KIT. BORLA 40349 DUMPED. UPREV TUNED. 18X9 CUSTOM RIMS, MICHELIN LTX A/T 2 TIRES, STEP BARS, ROADMASTER ACTIVE SUSPENSION SPRINGS. FRONT BULL BAR WITH 13" LED LIGHT BAR. LSAL HID'S LOW/HIGH. RIDGID DUALLY D2 FOGS.
RETIRED: 07 TITAN CREW CAB LE 4X4 BT, MINI LIFT, 18X9 CUSTOM RIMS, MICHELIN LTX A/T 2 TIRES, DOUG THORLEY LT HEADERS, CAJUN BPIPES, MAGNAFLOW 12588 MUFFLER, DUALED EXHAUST, VIBRANT UQ RESONATORS, K & N COLD AIR INTAKE, UPREV TUNED, WESTIN DRIVING LIGHTS, BULL BAR WITH OFF-ROAD LIGHTS, STEP BARS, ROADMASTER ACTIVE SUSPENSION SPRINGS, STILLEN HIGH PERFORMANCE DUAL-CORE ALL ALLUMINUM RADIATOR, AND BILSTEIN 5125 SHOCKS.
STEREO: KICKER COMPONENTS IN ALL FACTORY LOCATIONS ON KICKER 4 CH AMP, 2 RE AUDIO 10SEXD2'S PORTED PUSHED BY KICKER MONOBLOCK AMP, ALL CONTROLLED BY A PIONEER 5900 HEADUNIT AND PHEONIX GOLD WIRING.
THE RIG: 2009 JAYCO, JAY FLIGHT, 25BHS WITH A PROPRIDE 3P-1000# HITCH, AND A TEKONSHA PRODIGY BRAKE CONTROLLER.
slwilson6 is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Leaking front axle seal Giles333 Titan Problems & Dealer Service 3 04-05-2011 12:55 AM
Axle seal leaking?? W/ Pic NorCal Scot Titan Problems & Dealer Service 7 07-06-2010 04:01 PM
Axle Seal Leaking....again!!! 54warrior Titan Engine, Transmission & Drivetrain 13 04-01-2008 08:10 PM
How do you tell if a axle seal is leaking Wiscdave Titan Problems & Dealer Service 10 11-16-2005 03:34 PM
Another leaking Axle Seal?? 54warrior Titan Problems & Dealer Service 7 11-14-2005 04:20 PM
You may post new threads
You may post replies
