I need a stock-like gear ratio for my bigger tires - Nissan Titan Forum
Old 12-02-2011, 09:50 AM   #1 (permalink)
claytonr24's Avatar
iTrader Score: 0 reviews
My titan was lifted 6" with 35s when i bbought it, so i have no idea what the stock tire size and gear ratio is for my model. 05 SE crew 4x4 big tow. It feels a little sluggish at times and im wanting the power and fuel economy of a stock tire. so basically i wanna mimic the stock tire/gearing configuration but with my 35" tires
claytonr24 is offline   Reply With Quote
Advertisement
Old 12-02-2011, 10:10 AM   #2 (permalink)
iTrader Score: 4 reviews
Re: I need a stock-like gear ratio for my bigger tires
You will never get the fuel economy of a stock truck with a stock tire with a 6" lift and 35s.
Original Tire Diameter 32.7 (285/70R17) / Original Axle Ratio (3.36 for Big Tow) = New Tire Diameter (35) / New Axle Ratio which the closest available ratio that works out to is 3.73
However, as a 4wd, I think you are limited by available gears for the front, AFAIK that is 4.10 or 4.56
Nissan Titan Front Gears, Installation Kits and Yokes are Now Available - Blog | Rugged Rocks Off Road - Nissan Off Road Parts and Accessories
Old 12-02-2011, 10:24 AM   #3 (permalink)
If I was regearing a stock 2005 rear axle, I would also have a TrueTrac installed at the same time.
Old 12-02-2011, 11:20 AM   #4 (permalink)
RyBo's Avatar
iTrader Score: 21 reviews
Send a message via AIM to RyBo
I'll second this, and suggest the 4.10's for your setup, being on 35's you really have no need for the 4.56's unless you want to burnout every time you give her a little love on the throttle
"No offense Titantalk, but I'd rather be on a beach..."
RyBo is offline   Reply With Quote
Old 12-02-2011, 06:40 PM   #5 (permalink)
claytonr24's Avatar
Thanks guys, great info, I'll def be checking into the 4.10s with a tru trac. Also does anyone know of a decent programmer for mild modding ie intake and exhaust thanks again
Old 12-02-2011, 07:42 PM   #6 (permalink)
RyBo's Avatar
Bullydog GT, Superchips Cortex...BDGT in my opinion
here's one for sale: F/S: Bully Dog GT Tuner & Multi-Trac Bed Extender
The Following User Says Thank You to RyBo For This Useful Post:
claytonr24 (04-22-2012)
Advertisement
WTB: Stock rims (18'' or bigger) with tires ApacheCrewChief Buy/Sell 7 03-29-2010 06:53 AM
stock 17s with bigger tires?? help? mandingotitan Titan Wheels, Tires & Brakes 1 01-18-2008 05:49 PM
Bigger Tires on Stock Suspension? Talent Titan Wheels, Tires & Brakes 18 12-07-2007 07:43 PM
35in tires final gear ratio JAWS Titan Engine, Transmission & Drivetrain 1 11-29-2006 07:51 PM
Gear ratio calculator for different size tires SOCALTITANKC4X4LE Titan Engine, Transmission & Drivetrain 4 09-27-2006 09:29 PM
SEO by vBSEO 3.3.2
