front diff hum noise between 40-50mph - Nissan Titan Forum
post #1 of 23 (permalink) Old 12-30-2011, 03:14 PM Thread Starter
iTrader Score: 0 reviews
Hi , my T front differential is doing a hum noise between 40 and 50 mph during acceleration and its worse with a load when I'm using the 4x4 , I would like to know if people here have the same noise coming from the front diff
vkeven is offline
Advertisement
post #2 of 23 (permalink) Old 12-30-2011, 03:19 PM
iTrader Score: 3 reviews
I have something like that... It's a humming noise with anything between 45-85 mph and everytime I touch the accelerator it humms.... And it doesn't even. Have to be speeding up just touching it does it if you find out what it is I'd love to know I have a 06 2wd KC
Sent from my ADR6400L using AutoGuide.Com Free
2006 2WD SE Galaxy Black|Bedlined Wheels|Legit 5k HID headlights|Legit Super Reverse Lights|Blacked Out Taillights|08+ coils|305/65/18 Flaken Rocky Mountain|Challenger Toolbox|All interior LED's|
"Special modifications" : DIY Cracked manifolds, Screaming rear end mod, Front Driver end cap zip tie edition and more to come!
Performance: Insynerator Exhaust DI/DO|DIY Airbox Mod|
Audio/Video: Kenwood touch screen deck|2 JL 10"w3v2| JL 1000/1|
PiNu Chapter
EAST CAROLINA PIRATES
tarheelmatthew1 is offline
post #3 of 23 (permalink) Old 12-31-2011, 12:21 AM Thread Starter
Anyone ??-
vkeven is offline
post #4 of 23 (permalink) Old 12-31-2011, 06:19 AM
Re: front diff hum noise between 40-50mph
Not being a 4WD I'd suggest what you're experiencing isn't related to the OP but more likely just tyre harmonics (or even engine noise)...
If you're running even a mildy aggressive tyre (such as an A/T) you may be getting feedback through the drivetrain when you apply very light load.
2006 Nissan Titan LE (Offroad 4x4 Crew Cab)
*20x9 (-12mm) Eagle Alloy 079's w/33x12.50 Kumho KL71 M/T's*
*Bully Dog GT Tuner & K&N Replacement Filter*
*Smoke Euro Style Taillights w/ Putco ION Chrome LED 3rd Brake Light*
*PlastiDip Rear Bumper*
*2" PRG Levelling Kit*
*RetraxPRO Bed Cover*
Windza is offline
post #5 of 23 (permalink) Old 12-31-2011, 06:27 AM
Based on information provided on this forum I think we can conclude a certain degree of "hum" is normal in 4WD Titans...
Unless it's a new development that you've never noticed before and you haven't changed anything (like tyres) then I'd relax and enjoy the ride
In case you're still nervous... here are some links where similar questions were asked and answered (including myself):
Answer to my question
Answer to someone elses questions
Hope this helps you relax
Windza is offline
post #6 of 23 (permalink) Old 01-02-2012, 03:31 PM
scoby41's Avatar
It could also be wheel bearings. Is there any vibration or just the noise?
scoby41 is offline
post #7 of 23 (permalink) Old 01-02-2012, 04:24 PM
timmy_g83's Avatar
I have the noise...can't figure it out.
timmy_g83 is offline
post #8 of 23 (permalink) Old 01-05-2012, 09:11 AM
PRJ
iTrader Score: 1 reviews
It's completely normal. Every 4x4 I have owned makes a humming noise when engaged.
PRJ is offline
post #9 of 23 (permalink) Old 01-12-2012, 01:52 PM
NOT NORMAL - in my opinion. hahaha. yes, in 4wd our trucks made a noise but I think I know exactly what you are talking about as I had the same issue on my truck. when you barely touch the pedal it makes the noise and then dissappears while you are under throttle. when you let off the throttle the same noise comes through faintly and then dissappears right? HIGHLY suggest you pull the front diff cover and replace the fluid. I guarantee you the fluid will be grayish with shavings. After draining my fluid and the shavings, i put in new fluid and it went away. Its probably a sign of the front diff going out but changing the fluid right now will prolong the failure. Add lucas and that will help prolong it further. If you call Jeff from Performance Lifts or Greg from PRG they will tell you to check the snap ring on the axle as it is common to pop out and that the noise in 2wd on the highway is not normal.
2004 Titan LE, PRG UCA, PRG Rear Shackles, PRG Drive Shaft Spacer, Bilstein 5100's - Middle Setting, 08 Pro-4x Springs, Fabtech Stage 1 6" Suspension, Deaver C30 Spring Pack, CST Flat Off-Set Pin 4" Rear Block, BFGoodrich All-Terrains 315/70/17, XD Hoss Wheels.
umedevelopment is offline
post #10 of 23 (permalink) Old 01-12-2012, 02:26 PM
+1
I just re-read Vkeven's first post and realised he's getting the noise while in 2WD...
The info I provided was under the incorrect assumption the noise only occurred while in 4WD.
Knowing this, I'd be a little more concerned and fully agree with the advice umedevelopment has provided...
Windza is offline
The Following User Says Thank You to Windza For This Useful Post:
umedevelopment (01-12-2012)
post #11 of 23 (permalink) Old 01-12-2012, 03:19 PM
timmy_g83's Avatar
I got a diagnostic done on my t and its the rearend. Something in there is toast and they say I need to replace the whole thing. Other members say a tru trac will fix the noise. Check your rear diff fluid and see if its messed up.
post #12 of 23 (permalink) Old 01-12-2012, 08:51 PM
Originally Posted by Windza View Post
+1
wow... someone agrees with me for once. haha.
post #13 of 23 (permalink) Old 01-12-2012, 09:08 PM
NBhunter80's Avatar
Check your front dif fluid and check the front U-joints. There is a TSB (NTB10-52) for noise or vibration caused by front u-joint. I had the TSB done on my truck (u-joint replaced) and it made the hum/vibration go away.
2005 Titan LE King Cab 4x4 Offroad Big Tow FFV.
Radiant Silver with charcoal leather interior, black Nissan OEM brush guard, LT315/70r17 Kelly Safari TSR tires on OEM OR 7-spoke 17" rims, Rough Country 3" lift, 1" rear block, Bilsteins 5100s front and rear, 2011 Pro4x rear end, Axle vent mod, 2 degree timing advance, NGK Iridium spark plugs, Stock Airbox mod with K&N filter, Magnaflow 14" SI/SO muffler on stock pipes with T304 stainless double-wall tip, Optima Yellow Top D34 battery, OEM Rockford Fosgate audio system, Protecta chrome tool box, 6000K HID headlights, TomTom GO 920 Navigation system.
2012 Nissan Rogue SV AWD - Wife's ride
NBhunter80 is offline
post #14 of 23 (permalink) Old 01-13-2012, 10:11 AM Thread Starter
Does this only apply when 4x4 is engaged ?
vkeven is offline
post #15 of 23 (permalink) Old 01-13-2012, 11:14 AM
No > it will apply in all applications as regardless of in 4WD or 2WD, the front is rotating. If it were me; I'd pull the front diff and look closely at the fluid that comes out. If nothing is wrong with it; there is no harm in changing out the fluid anyway. If clear; good chance its the front u-joint although with a u-joint application; i believe you would have constant vibration. Pull the cover bro.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Front Diff / Rear Diff / Tranny trh18 Titan Problems & Dealer Service 0 09-07-2010 01:14 PM
Noise-Impending Rear Diff. Failure? jmtitan Titan Engine, Transmission & Drivetrain 10 09-22-2009 09:27 AM
Diff Noise OK Park to Reverse to Drive? SirKeats Titan Engine, Transmission & Drivetrain 5 10-06-2007 08:25 PM
Rearend hop at 50mph? shaffer Titan General Discussion 17 11-04-2006 08:55 PM
rear diff making noise abmobil Titan Engine, Transmission & Drivetrain 0 03-21-2006 11:08 PM
You may post new threads
You may post replies
