Getting nervous about Tru Trac install... - Nissan Titan Forum
Old 02-12-2012, 06:20 AM   #1 (permalink)
timmy_g83's Avatar
iTrader Score: 0 reviews
I guess I'm just paranoid and broke, but I have the howling noise of my rear end going out...paid 250 for the rebuild kit and will end up going over 1000 on TT and install. Crossing my fingers and hoping the howl goes away and the tru trac install goes smooth.
Think I have been reading to far into the forums with people having troubles with blown rear ends lately and some people having failing TT with bolts coming loose and all that good stuff.
Really I just don't want to part with my truck and start over with payments.
Idk, just felt like ranting a little.
timmy_g83 is offline   Reply With Quote
Advertisement
Old 02-12-2012, 07:05 AM   #2 (permalink)
Kronos1965's Avatar
Re: Getting nervous about Tru Trac install...
I haven't heard of blown rearends lately.
Our early models had the issue which drove many to install TrueTrac but '08 and later have a redesigned rear axle.
$1000 includes the $250 for the install? That's a bit steep.
HippieWhore™
Be the kind of person your dog thinks you are.
Kronos1965 is offline   Reply With Quote
Old 02-12-2012, 07:31 AM   #3 (permalink)
timmy_g83's Avatar
Yeah the price is higher than what I want, but I dont have any buddy hook ups around Ft. Bragg and from what I have heard all the shops in the area are terrible...so I'm taking it to 4wheel parts in Raleigh. The price they told me was under 1000 but with time, gas, and a day with my wife it will come out to 1000.
Old 02-12-2012, 07:41 AM   #4 (permalink)
iTrader Score: 4 reviews
If the howling is from a bearing, it should go away with the rebuild kit install. If the R&P are worn, probably not.
How to Diagnose Differential & Driveline Noises - SummitRacing.com
The Following User Says Thank You to bestatchess For This Useful Post:
timmy_g83 (02-12-2012)
Old 02-12-2012, 08:33 AM   #5 (permalink)
gweasel77's Avatar
iTrader Score: 6 reviews
If you install a TruTrac you might want to consider backing out the bolts on it & Loctite them all! There's have been a few instances where TT members have had the factory tightened bolts come loose & destroy the ring & pinion gears!
2005 NISSAN TITAN SE KC
IRC VK56 TEAM MEMBER
performance:
UP/REV CUSTOM TUNED
4" Airaid MXP CAI w/ GW77 4" Ram-Air Mod / TB Bypass Mod / FT90 Kit / LS7 TB / '08 IM / CSF Race Rad. / Trans. Cooler / Nismo LT Header's / Berk Tech SS B-Pipes w/ Magnaflow Hi-Flows / 2.25"-3" Flowmaster Y-Pipe / Borla XR-1 Muffler / "Gatorback" Serp Belt / Relentless RPM Catch Can / Detriot TruTrac / ActiveTuning Grounding Kit / Burnout Mod / LP Mod / MT ET Street P295/45R/17 DR's / Mobil1 EP 5W30 / 75W140
exterior/suspension:
Ruff Racing R286 22"x9.5" Chromes w/ 305/45/22 Yokohama Parada Spec-X's / Slotted "cryo" Frozen Rotors / Hawk LTS Brake Pads / High Cap. Diff. Cover / Helwig RSB / Bilstein HD's / SpringTech 2" Drop Shackles / PRG camber bolts / Armada Air Dam / SolarGard Tint / Tow Hooks / Debadged
NEW PB: 1/4- 13.57 @ 98.51MPH w/ my BEST 60' EVER 1.88
New PB Dragtimes Page:http://www.dragtimes.com/Nissan-Tita...lip-25254.html
Need to install: PRG Street Traction Bars!!!
Next Mods: CAJUN PIPES!!!!
gweasel77 is offline   Reply With Quote
Old 02-12-2012, 09:33 AM   #6 (permalink)
timmy_g83's Avatar
I read a couple posts about the loctite...I'm not doing the install but will be reminding them to use it and probably do a spot check in a month or two when I get a bigger diff cover.
Old 02-12-2012, 10:09 PM   #7 (permalink)
KC4xSV's Avatar
iTrader Score: 2 reviews
Maybe a good idea to toss the mechanics a tube of thread-lock at the beginning of the project. It'll act as a constant reminder
Current: '11 KingCab4x4SV Red Alert
Previous: '79 K5 Blazer; heavy mod; crossing glaciers in Iceland ~~~~
KC4xSV is offline   Reply With Quote
The Following 2 Users Say Thank You to KC4xSV For This Useful Post:
gweasel77 (02-13-2012), timmy_g83 (02-13-2012)
Old 02-13-2012, 03:55 AM   #8 (permalink)
gweasel77's Avatar
I'm not going to name names, but this just happened to a member on here just in the last 2 weeks... I would buy some loctite!
performance:
UP/REV CUSTOM TUNED
Old 02-18-2012, 12:34 PM   #9 (permalink)
Tru Trac install completed about a week ago at 104k by a mechanic with 20 years experience at a respected 4x4 shop. Everything was OK except noticed passenger side seal leaking 2 days later. Replaced seal and aftermarket bearing. Started leaking again 2 days later, so today replaced another seal and this time $93 bearing from Nissan shop.
Mechanic said he drove 4-5 miles on side roads and while it drives OK, that there is a problem he has never encountered before. He checked temperature somewhere of axle on drivers side and it is 55 degree, but the temp on the passenger side is 102 degrees. He believes there is a problem with the shaft on the passenger side, and is concerned that at highway speed, the added heat will cook the seal or eventually the bearing.
When I picked up the new bearing this morning, the Nissan parts guy said that they replace and sell a large amount of seals and bearings on 04-05 Titans.
Anybody have similar experience with passenger side seals after Tru Trac install. Mechanic said there is not a shim available like many trucks have whatever that means.
hayjunk is offline   Reply With Quote
Old 02-18-2012, 12:56 PM   #10 (permalink)
Scan999's Avatar
Strange. Did you have an e-locker before the TT? The different length axles might be the issue. My shop had to shim the TT a bit to keep the longer axle from bottoming out.
05 LE CC 4x4 BT
Mods:
Injen Intake
Borla cat-back
Superchips
5100's all around (middle setting front)
08 coils
KMC XD SPY's
Cooper S/T Maxx
TrueTrac
CSF Radiator
bunch of other stuff thanks to this dam forum...
Scan999 is offline   Reply With Quote
Old 02-18-2012, 03:38 PM   #11 (permalink)
Did have e-locker before TT. Had discovered parts of spider gears on magnetic diff drain plug. Mechanic had actually ground off approx. 1/8" from end of each axle shaft to be sure they would not bottom out on TT. He spent 2 hours cleaning surface area again before using some kind of stuff in a tube before bolting axle back in. He said there was a lot of corrosion on the surfaces he needed to clean. He said that he has worked on axles with 250k that had far less corrosion/rust? than my Titan did at 104k.
Drove truck home 11 miles on side roads to keep speed down and not get the heat build up. I will check for oil leak tomorrow.
Advertisement
What's needed for Tru Trac install? Smoke05 Titan Engine, Transmission & Drivetrain 5 02-21-2010 05:05 PM
true trac install help blk04titan Titan Engine, Transmission & Drivetrain 9 10-24-2009 09:47 PM
Detroit Tru-Trac LSD Install ohiodish Titan General Discussion 2 04-10-2008 03:17 PM
True trac install dbolemiss Titan Performance Modifications 0 08-07-2007 06:02 PM
tru trac install myTtitan Florida Forum 0 01-09-2007 02:45 PM
SEO by vBSEO 3.3.2
