ECU reset - Nissan Titan Forum
post #1 of 11 (permalink) Old 04-15-2012, 12:29 PM Thread Starter
iTrader Score: 0 reviews
ECU reset
? bought my truck recently with 2000 miles but dont like the way the truck drives. I was wondering if i do a ECU reset will be bad since is almost a brand new truck. any suggestion plz help.
porky1989 is offline
Advertisement
post #2 of 11 (permalink) Old 04-15-2012, 01:17 PM
salstats's Avatar
iTrader Score: 11 reviews
Talking Re: ECU reset
Well it will take longer for your ECU to get used to you since it already got use to someone else. Just unplug your battery over night for around 10 hours and you should be set.
2008 SE 2WD:
Maxtrac 4" Spindles Lift with 2" Blocks
PRG UCA
PRG Shackles
PRG Endlinks
PRG Cam-bolts
PRG Driveshaft Spacer
Nitto Trail Grapplers 35x-12.5-17
ProComp Alloy Series 6005 rims
AirAid MXP CAI
CSF Rad Cap (Yellow)
Cajun Catless Bpipes
Gibson 2.5 Y pipe
TAP MidPipe Kit
Borla XR1 CatBack
BullyDogGT
Window Roll up Mod
salstats is offline
post #3 of 11 (permalink) Old 04-15-2012, 01:26 PM
m1key's Avatar
iTrader Score: 8 reviews
Re: ECU reset
ECU reset is better.
m1key is offline
post #4 of 11 (permalink) Old 04-15-2012, 01:38 PM Thread Starter
Re: ECU reset
i did the complete ECU reset on it today but i was wondering if its safe since is a new truck i dont want to mess anything up.
post #5 of 11 (permalink) Old 04-15-2012, 01:47 PM
m1key's Avatar
Re: ECU reset
It's not going to hurt anything. do all the reset's tho
m1key is offline
post #6 of 11 (permalink) Old 04-15-2012, 01:57 PM Thread Starter
Re: ECU reset
ok thanks i did the ECU reset on friday and the others today does it matter? or do i have to do them all at the same time?
post #7 of 11 (permalink) Old 04-15-2012, 02:10 PM
Carbeaux's Avatar
iTrader Score: 12 reviews
Re: ECU reset
It won't matter.
Hook 'Em!
AKA TroubleWhore™AKA HitAndMissWhore™AKA RockyWhore™AKA SigPicNaziWhore™
"Be polite, be professional, but have a plan to kill everybody you meet." - Gen. James 'Mad Dog' Mattis
2016 Super Crew, Platinum, 4WD FX4 Bought by me on 01/05/16
Carbeaux is offline
post #8 of 11 (permalink) Old 04-15-2012, 02:13 PM Thread Starter
Re: ECU reset
ok thanks.
post #9 of 11 (permalink) Old 04-15-2012, 06:30 PM Thread Starter
Re: ECU reset
how should my RPM needle look at Idle speed = 650 ± 50
post #10 of 11 (permalink) Old 04-15-2012, 07:09 PM Thread Starter
Re: ECU reset
also how can i check my ignition timing to see if everyting is fine after doing all resets? thanks
post #11 of 11 (permalink) Old 04-17-2012, 05:02 AM
Carbeaux's Avatar
Re: ECU reset
That's about right for idle. As for the timing I think a BDGT will check it. The Uprev Osiris will check it, your dealer can check it...just about anybody who can hook the proper diagnostic tool into your OBD II can check.
Hook 'Em!
Carbeaux is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Reset my ECU deerslayer Titan Performance Modifications 14 05-26-2009 04:12 PM
ECU reset the_kernel Titan Performance Modifications 0 04-14-2007 06:45 AM
Ecu reset pthomas21 Titan Performance Modifications 3 04-14-2007 03:22 AM
ECU reset Colorado_Titan Titan FAQ & How to Area 10 03-11-2006 09:43 AM
K&N ECU Reset 1BadTitan Titan Performance Modifications 6 04-16-2004 04:17 AM
You may post new threads
You may post replies
