HELP tranny fluid check - Nissan Titan Forum
post #1 of 11 (permalink) Old 04-16-2012, 02:26 PM Thread Starter
Banned
iTrader Score: 4 reviews
Ok so I did what I always do when checking tranny fluid. parked somewhere as level as I could see, after driving the truck for about 20minutes to warm up the fluid, left truck running in Park, pulled the dip stick the first time, about 1/8'' of an inch of fluid. wiped it off, put back in, pulled back out and nothing on the dip stick. Is that the proper way of checking fluid on this truck?
LyferXB9S is offline
Advertisement
post #2 of 11 (permalink) Old 04-17-2012, 07:49 AM Thread Starter
Banned
Re: HELP tranny fluid check
Well since I couldn't get an answer here I took it to the dealer and had them check and fill to the proper levels. However that has not eliminated my torque converter shudder. Are there any additives that can help with this?
post #3 of 11 (permalink) Old 04-17-2012, 08:30 AM
TA CC TX's Avatar
Garage
iTrader Score: 5 reviews
That is how I check it , although I shift gears up and down to get fluid circulating in tranny. I would not add anything to trans but fluid.
[04 CC BT OFFROAD
TA CC TX is offline
post #4 of 11 (permalink) Old 04-17-2012, 03:41 PM Thread Starter
Banned
Man I hope this tranny isnt on its way out the door with only 80k miles
post #5 of 11 (permalink) Old 04-17-2012, 04:36 PM
AcidJake75's Avatar
iTrader Score: 17 reviews
Send a message via AIM to AcidJake75 Send a message via Yahoo to AcidJake75
^^^^This
and in case anyone else wants to know proper way..straight from FSM..
04 KC Smoke Titan 4X4
PRG, Hypertech, 08 Brake Upgrade, Black Rhino 18x9 +12, 305/65/18, Bilstein 5100's, Pro4x Springs, AAL's, CSF Rad, 2 Advance, Debadged, GoGrounding, Radiator Bypass Cooler, AIRaid MXP Intake, Axle Vent Mod, DDM 5k Lows & 3k Fogs, Blacked out Head lights, Stillen LT, BALLER PRT PIPES (BECAUSE I DONT LIKE BUYING SHIET TWICE), JBA Exhaust, Magnaflow Glasspack, Vibrant, Tech12, Volant LED Tails..
AcidJake75 is offline
The Following 2 Users Say Thank You to AcidJake75 For This Useful Post:
mrbubl (04-17-2012), TA CC TX (04-18-2012)
post #6 of 11 (permalink) Old 04-18-2012, 07:44 AM
TA CC TX's Avatar
Garage
Thanks Acidjake and that's Exactly what I do shift it thru the gears put it back in park and check it.
[04 CC BT OFFROAD
TA CC TX is offline
post #7 of 11 (permalink) Old 04-18-2012, 07:53 AM
vilim12's Avatar
We run Lucas in the superduty and the truck responds to it great, maybe try that
2008 Nissan Titan Pro-4x CC LWB Smoke
vilim12 is offline
post #8 of 11 (permalink) Old 04-18-2012, 08:16 AM
chadp82's Avatar
Have you tried having the fluid changed?
05 LE Crew w/ Offroad Package
Bilstein 5100's; 1" Rear Lift Block & 1.5" Strut Spacer
BDPP (2 Advance, WOT removed, Regular Tune)
JBA cat back, Cajun Catless B Pipes
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
A glass of beer shortens your life by one minute, a glass of wine by two minutes, and a day of work by 7 to 10 hours
America!!! (Designed by geniuses, run by idiots)
chadp82 is offline
post #9 of 11 (permalink) Old 04-18-2012, 08:25 AM Thread Starter
Banned
I tried but the dealer talked me out of it said if I'm having tranny concerns not to change the fluid cause
The varnish might be the only thing holding my tranny together
post #10 of 11 (permalink) Old 04-18-2012, 08:39 AM
chadp82's Avatar
Being at 80k miles, I assume you are out of warranty? If it were me, I would take it to a transmission shop for a diagnosis. The bad thing is unless they can pinpoint it, they may tell you you can drive it until it fails or pay them to drop teh tranny and look. It may at least be worth another opinion outside of the dealership.
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
chadp82 is offline
post #11 of 11 (permalink) Old 04-18-2012, 12:08 PM Thread Starter
Banned
Thats my plan, I'm going to have nissan do a diagnostic early next month, and then depending on what they find ill take it to a tranmission shop. and yes I am out of warranty.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Tranny fluid EVERYWHERE KING_Polaris Titan Problems & Dealer Service 20 11-21-2011 10:54 AM
Tranny Fluid CVTitan05 Titan Problems & Dealer Service 13 09-23-2011 07:21 PM
What tranny fluid is compatible with stock fluid? rynomx785 Titan Engine, Transmission & Drivetrain 2 05-11-2011 06:52 PM
More tranny fluid everywhere! bills1974 Titan General Discussion 7 01-31-2011 02:35 PM
Tranny fluid? ridgeracing Titan Engine, Transmission & Drivetrain 2 10-24-2005 06:05 AM
You may post new threads
You may post replies
