White smoke at start up and using oil...help!!! - Nissan Titan Forum
post #1 of 21 (permalink) Old 07-18-2012, 07:12 PM Thread Starter
iTrader Score: 1 reviews
Just bought a '07 Titan. Truck is a clean one owner truck with 90k on it. Carfax shows routine oil changes at Nissan dealer...no issues. At start up, I'm getting a big puff of white smoke, then it doesn't do it again unless you sit at idle for several minutes than hit the gas. Oil looks super although level has dropped a quart or two over the last 500 miles or so. No signs of coolant in oil. I read on this forum to start with replacing both PCV's so I did yesterday...same issue remains. The old PCV's and underneath the oil add cap had sludge on them. Truck isn't putting out any codes and doesn't have any engine lights on...doesn't miss a beat! I spent a good amount of pocket change on this truck and can't afford to be replacing an engine already! I'll take the darn thing back to the dealer if I have to. Any ideas to what is going on and might be my issue???
silverbulletrr is offline
Advertisement
post #2 of 21 (permalink) Old 07-18-2012, 07:26 PM
chadp82's Avatar
iTrader Score: 4 reviews
If there is no noticable leak and you are burning oil, probably a cylinder issue? May need to take this one in to the shop to diagnose.
05 LE Crew w/ Offroad Package
Bilstein 5100's; 1" Rear Lift Block & 1.5" Strut Spacer
BDPP (2° Advance, WOT removed, Regular Tune)
JBA cat back, Cajun Catless B Pipes
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
A glass of beer shortens your life by one minute, a glass of wine by two minutes, and a day of work by 7 to 10 hours
America!!! (Designed by geniuses, run by idiots)
chadp82 is offline
post #3 of 21 (permalink) Old 07-18-2012, 08:34 PM
iTrader Score: 5 reviews
Re: White smoke at start up and using oil...help!!!
take it back to the dealer if your within the time frame to return the truck
2014 Silver Ram Laramie 4x4 w/ leather and Alpine sound
2008 Red Brawn Titan SE 4x4 Popular package
ArmyAviation is offline
post #4 of 21 (permalink) Old 07-19-2012, 03:29 AM Thread Starter
If it's a cylider issue, what's the likelyhood that it can be fixed and the engine will be right again?
post #5 of 21 (permalink) Old 07-19-2012, 04:31 AM
chadp82's Avatar
I have no idea on that.
Did you buy at a dealership? Also how long ago timewise and mileage did you buy it? If it was a dealership, may want to look into lemon laws.
Under 100k shouldn't burn oil like that on any vehicle. Hopefully you didn't buy a bum Titan, but lemons exist in every make and model.
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
chadp82 is offline
post #6 of 21 (permalink) Old 07-19-2012, 12:59 PM
Steamguy's Avatar
Garage
iTrader Score: 0 reviews
Originally Posted by silverbulletrr View Post
Just bought a '07 Titan. ... getting a big puff of white smoke...Oil ... level has dropped a quart or two over the last 500 miles or so....I'll take the darn thing back
Blown head gasket (most likely) or cracked head (worst case). Disaster-ville: cracked block. Could be any of these.
TAKE IT BACK and get your money back.
NOW.
Somebody has abused the living sh!t out of the truck and it's going to be nothing but trouble.
Steamguy
Deepwater Blue, when it's not Dirt Brown. Yes, this truck is used as a TRUCK. If I wanted something to sit in the driveway and look pretty, I'd have bought another motorcycle.
Trailer-puller, meadow work truck, thrill ride for a rescued Aussie.
Born 11/11/03, first one sold in the county, still the original owner.
Steamguy is offline
post #7 of 21 (permalink) Old 07-19-2012, 01:43 PM
Quartz's Avatar
iTrader Score: 8 reviews
Valve seals. Oil leaks into the cylinder when the engine is not running. When you start the engine the oil burns and you get the puff of smoke. While the engine is running oil slowly leaks in to the cylinders. You don't get the smoke while it's running but it uses oil. A valve job on a 32 valve engine is going to be expensive.
GingerWhore™ BayWhore™
2011 Blue Steel SL, 2WD, BT, CC, Mods: Go Rhino Dominator II Nerf Bars, OEM Bug Deflector, 15% tint, Nav System Hack,
OEM Ipod Interface, Armada Front Spoiler, Leveled, Firestone Air Bags, Extang Solid Fold Tonneau Cover, Bully Dog GT,
LED Interior Lights, CSF 3328 Radiator, Brake Performance Drilled & Slotted Rotors, Wagner ThermoQuiet Pads,
Grounding Kit, Rogue Key, Bilstein 5100's on All Four Corners
Science flies you to the moon. Religion flies you into buildings.
Quartz is offline
The Following User Says Thank You to Quartz For This Useful Post:
pcg_k25 (08-08-2012)
post #8 of 21 (permalink) Old 07-19-2012, 05:32 PM Thread Starter
Makes sense Quartz! Dealer is in the process of replacing valve seals and doing a valve job. They're taking care of the bill and reassure me no matter what it costs to get it right they will back it up. Guess we'll see if that does the trick!
post #9 of 21 (permalink) Old 07-19-2012, 05:41 PM
mcginkleschmidt's Avatar
Let me see if I understand this correctly, you purchased a used '07 vehicle with 90k miles on it and the dealer has agreed to repair whatever is causing the truck to burn oil. I'm impressed! I expect that most dealers would laugh you out the door if you asked them to repair a used vehicle that you bought.
mcginkleschmidt is offline
post #10 of 21 (permalink) Old 07-19-2012, 07:13 PM
Scan999's Avatar
That isn't all that unusual. I purchased a used SUV that was 4 yrs old and got a 30 day warranty no charge. If the vehicle was certified pre-owned it would have been 12 months/12,000 miles.
05 LE CC 4x4 BT
Mods:
lots of stuff
Scan999 is offline
post #11 of 21 (permalink) Old 07-19-2012, 07:17 PM
chadp82's Avatar
Good to hear things are getting taken care of!
Airaid MXP Intake
Legit LED's
GO BRONCOS!!!
chadp82 is offline
post #12 of 21 (permalink) Old 07-20-2012, 01:05 PM Thread Starter
Latest update...the dealer is standing behind their word and having a complete valve job done. They are supplying the parts and having the shop my buddy owns do the work. Not sure what the new parts costs, but labor should be somewhere around $1500 to get the job done. We'll see if this fixes the issue. In the meantime, they gave me an '04 Titan crew cab on hand to rock for the next few days until truck is fixed. Can't complain too awful bad thus far. I'll keep you guys posted if this fixes the problem. Thanks for eveyone's input and help!
post #13 of 21 (permalink) Old 08-07-2012, 06:26 PM Thread Starter
Valve seals replaced and motor put back together...better, but still burning oil! New motor on the way!!!
post #14 of 21 (permalink) Old 08-07-2012, 08:17 PM
andys04titan's Avatar
iTrader Score: 10 reviews
Welcome to the new motor club
I had a similar issue with the burning oil and what not. But I never had white smoke. Good luck with the new engine!! So far I've had 1k worry free miles!! Plus the trucks so much peppier!!
-Andy
A.K.A. BIckBeaterWhore™
04 4x4 BT CC OR (locking diff)
Well I was keeping track of all my mods but it's beyond FUBAR now so... $crew it.... Its a truck with big tires and stuff. Who knows what's on here anymore...
andys04titan is offline
post #15 of 21 (permalink) Old 08-08-2012, 11:21 AM
HavaTITAN's Avatar
Might want to replace the exhaust manifolds also, cats in the manifolds can go bad and take out the motor. That may be what happened.
HavaTITAN is offline
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
white smoke scdude37 Titan Problems & Dealer Service 25 09-20-2012 09:27 PM
White Smoke Brutus20 Titan Engine, Transmission & Drivetrain 2 01-25-2011 02:53 PM
a couple ticks and some white smoke! cneary812 Titan Engine, Transmission & Drivetrain 0 09-10-2010 07:20 AM
White smoke at start up... travisd17 Titan Engine, Transmission & Drivetrain 5 03-06-2009 05:23 AM
04 Titan White Smoke on Start up toadstitan Titan Engine, Transmission & Drivetrain 8 04-25-2007 07:16 PM
You may post new threads
You may post replies
