Old 08-25-2004, 09:41 PM   #1 (permalink)
HVACman's Avatar
Question Cleaning MAF Sensors
I have read several comments here hinting that MAF sensors can be cleaned. How? Would removing it and diping it in alcohol be ok?
Titan CC LE 4x4 Radiant Silver * Born 4/16/04 * Big Tow / Offroad Package * Kenwood DVD/NAV ent. system * Infinity 6000cs Component Speakers * Infinity 7540A Power Amp * SPL Sub Power Amp * 2 10" PowerBass Subs * Tsunami 1-Farad Capacitor * JBA Ceramic Coated Headers * Flowmaster 40 Series Catback System * Sirius Satelite Radio * K&N 77 Series FIPK Intake System * Airaid Throttle Body Spacer * Really Loud Air Horns * Weld Racing Cheyenne Rims * Carbon fiber dash kit * Black billet grille * Truxedo Tonneau Cover * CST 7" Lift * ProComp XTerrain 35/12.5/17 Tires * Procomp Traction Bars * Stainless Steel Brake Lines
Wherever you go, there you are
HVACman is offline   Reply With Quote
Old 08-25-2004, 09:47 PM   #2 (permalink)
electrical contact cleaner is best. You can pick it up at radio shack, frys electronics, or the like.
Old 08-26-2004, 12:16 PM   #3 (permalink)
Titan420's Avatar
Whats a MAF sensor?
[IMG]SE KC 4X4
SMOKE
BIG TOW
BORN ON 06/04
Titan420 is offline   Reply With Quote
Old 08-26-2004, 12:29 PM   #4 (permalink)
GETSOMZ28's Avatar
I've always used throttle body cleaner with no adverse affect. Can be found at your local auto parts store.
Scott
Old 08-26-2004, 12:30 PM   #5 (permalink)
Titan420's Avatar
Originally Posted by Titan420
Whats a MAF sensor?
Never mind, found out myself.
[IMG]SE KC 4X4
SMOKE
BIG TOW
BORN ON 06/04
Old 09-12-2004, 06:00 PM   #6 (permalink)
if your MAf sensor needs cleaned you either have a very dirty air filer or none at all. You guys are getting carried away a bit!
malonega is offline   Reply With Quote
Old 09-12-2004, 06:04 PM   #7 (permalink)
Truck41's Avatar
you got that right.
06 titan 4x2. LE. Granite.
zoomers exhaust tip.
factory chrome wheels.
hellwig swaybar.
carriage works grill.
armada spoiler.
trueflow intake
Goodyear eagle GTll
Truck41 is offline   Reply With Quote
Old 09-12-2004, 09:18 PM   #8 (permalink)
SUBTITAN's Avatar
I believe this is stemming from the high flow air filters and the oil to lubricate them. It seems to be effecting the MAF sensor.
2004 Titan CC 4X2 LE Canteen
"SUB out going sinker"
SUBTITAN is offline   Reply With Quote
Old 09-12-2004, 11:06 PM   #9 (permalink)
scsTiTan's Avatar
If a MAF sensor can be cleaned with no ill effects why is it such a big deal when they get oil on them from the K&N type filters? If you did install the K&N CAI and got a little carried away with the oil, couldnt you just clean the MAF and solve the problem?
Thanks,
Steve
4x4 KC LE (BT/OF)
Super Fast Silver
Born: 1 June 2004
Kenwood DDX-7015 w/ BU Cam
DR's in front
Deavers & Bilstein in Rear
AFE CAI
scsTiTan is offline   Reply With Quote
Old 09-12-2004, 11:12 PM   #10 (permalink)
usually you can clean it... but it can be damaged and no amount of cleaning will fix a damaged maf.
