Trans flush - Nissan Titan Forum
Old 01-23-2013, 11:33 AM   #1 (permalink)
GalaxyPro4X11's Avatar
iTrader Score: 0 reviews
Trans flush
Can someone please tell me what fluid to use in my tranny? I know it's covered somewhere but the search isn't working on my phone. Also not able to get the truck to a dealership because Sundays are my only day off. Will that hurt the warranty?, does anyone know. Like if I take it to lubex
Also if there's a specific filter that is better then another.
Thanks
Sent from AutoGuide.com App
GalaxyPro4X11 is online now   Reply With Quote
Advertisement
Old 01-23-2013, 11:56 AM   #2 (permalink)
Re: Trans flush
NissanMatic "S"
Part# 999MP-MTS00P
Plan on obtaining a case (12 qts.) of the ATF to fully flush & fill your tranny.
Worst case scenario, you might need the following additional parts:
01558-00451 - Hose Clamp (Qty: 2)
11026-JA00A - Copper Drain Washer (Qty: 1)
31361-1XJ0A - Drain Bolt for overflow tube (Qty: 1)
Note: There is no replaceable Filter in this transmission, so it is NOT necessary to remove the A/T Pan
2004 Titan SE Crew Cab (4X2)
Color: Blizzard White
Performance Mods: NISMO CAI
Exterior Mods: Armada Lower Front Chin Spoiler
Exterior Mods: Nissan Factory Fog Lamp Kit
Exterior Mods: '05 + Aluminum Differential Cover & 75W-140 Synthetic Lube
Exterior Mods: Rear Axle Housing Vent (Toyota) Tube
Exterior Mods: Tailgate Power Lock Actuator
Exterior Mods: 2" Front Leveling Spacers
Exterior Mods: '05 + Tailgate Assist Mod
In-process Mod: QX56 Power Folding, LED Turn Signal (non-Towing) Mirrors
PE 316 is offline   Reply With Quote
Old 01-23-2013, 12:01 PM   #3 (permalink)
StormTroopin's Avatar
iTrader Score: 16 reviews
Trans flush
Don't do a flush, it's not recommended by Nissan. Do a drain and fill, pull the plug, let it drain, and replace what came out. Usually 4-5 quarts, of Nissan Matic-S.
MeatBeaterWhore™
TwinTwit #1
"The Big O"
GO DUCKS!
StormTroopin is offline   Reply With Quote
Old 01-23-2013, 03:16 PM   #4 (permalink)
Trans flush
Thanks guys
Old 01-23-2013, 03:36 PM   #5 (permalink)
baseballfanz's Avatar
iTrader Score: 1 reviews
Re: Trans flush
Nissan's memo
Titan/Armada Part Numbers
Frequently asked fuse locations
305.5 WHP, 370.4 ft/lbs tq
The Following User Says Thank You to baseballfanz For This Useful Post:
GalaxyPro4X11 (01-23-2013)
Old 01-23-2013, 08:32 PM   #6 (permalink)
Trans flush
What's the next thing to Nissan matic S that I can use in the tranny? Thought I read something about amsoil?
Just can't make it to the dealer
Old 01-23-2013, 09:27 PM   #7 (permalink)
Trans flush
Buy 12 qts of Amsoil, Royal Purple, or Mobil 1. Take it to your shop and have them use their fluid exchange machine.
I have 185k on my transmission and am running Amsoil ATF. That fluid is good for a long time and much better than the Nissan fluid, which is pretty much the same as Castrol Import ATF.
Don't be scared to exchange (not flush) all the fluid. Your truck will thank you for it.
2005 CC SE 2*, K&N FIPK, Magnaflow exhaust. JBA Long Tubes, Cajun 2.25 B pipes, TAP Y pipe, Uprev
coachditka is online now   Reply With Quote
The Following 2 Users Say Thank You to coachditka For This Useful Post:
cleary996 (01-24-2013), GalaxyPro4X11 (01-24-2013)
Old 01-24-2013, 02:04 AM   #8 (permalink)
Frank N's Avatar
iTrader Score: 4 reviews
Re: Trans flush
Thanks
I hate when I lock the glove box and can't find the key to get the owner's manual.
StinkyFishFingerWhore™
"You fish - then you die - or you don't fish and die anyway - your choice"
"The Beach Buggy"
2008 SE 4x4 KC
Frank N is offline   Reply With Quote
The Following User Says Thank You to Frank N For This Useful Post:
37L1 (01-24-2013)
Old 01-24-2013, 05:24 AM   #9 (permalink)
Trans flush
I hate when I forget to the post I'm so helpfully commenting lol
Didn't know it had the equivalent to matic S in the manual? Should show me where, I stated I'm unable to get to a dealership. So I'm in need of knowing the equivalent. Thanks for being so helpful 😬
Anyways I believe someone answered so thanks people👍
Old 02-08-2013, 05:54 PM   #10 (permalink)
iTrader Score: 2 reviews
Re: Trans flush
I've been running valvoline max life dex/merc atf. It's matic-j and matic-s compatible. I think it's about $25 a gallon. I drain the pan and refill through the dipstick tube, then disconnect the return line from the transmission cooler back to the transmission. I get someone to turn the truck on and off for me while I drain a couple of quarts and refill the same amount.
JRW160 is offline   Reply With Quote
Old 02-10-2013, 08:02 AM   #11 (permalink)
Re: Trans flush
Why not just run the car until it stops pumping fluid out the cooler line, then start the refill process. This is the recommended method for other cars I've worked on.
By the way, hey, first post!
jbawden is offline   Reply With Quote
Old 02-10-2013, 05:35 PM   #12 (permalink)
AZPRO4X's Avatar
iTrader Score: 7 reviews
Re: Trans flush
Just take it to the dealer pay the $200 to let them do a complete exchange and go on your marry way. Its the easiest way to get all of the fluid replaced & then you won't have to worry about it for another 30k miles.
Just get it done when you have a chance to.
08 Pro-4x moonroof,Tow,DVD,SWB,BullyDog Pup,Banks Monster Exahust, Brute Force intake, Total Chaos UCA's,Tuff Country 1.5" leveling kit,1" rear blocks, PWM, Radiator ByPass Mod,Bilstein 5100's,Limo Tint,325/65R18 Goodyear Duratracs,Black 18x9 5.71", +18mm, Rims,
AZPRO4X is offline   Reply With Quote
Old 02-10-2013, 05:58 PM   #13 (permalink)
Re: Trans flush
OP stated that Sunday is his only day off, and can't get it to a Dealer.
2011 Titan KC, 4 X 4, (part time "work truck"), TracRac,
Galaxy black.
HoneyB is offline   Reply With Quote
Advertisement
Do it yourself trans flush? T-Neck Titan Engine, Transmission & Drivetrain 4 06-11-2009 11:01 PM
trans service-flush and fill "THE KIZE" Titan Wheels, Tires & Brakes 4 02-25-2009 03:05 PM
SoCali owners - trans flush? itssr20 Titan General Discussion 12 03-20-2008 09:15 AM
DIY Trans flush how to??? itssr20 Titan Engine, Transmission & Drivetrain 2 07-07-2007 11:43 AM
Trans flush MKETASIS Titan Engine, Transmission & Drivetrain 9 10-23-2004 02:13 PM
SEO by vBSEO 3.3.2
