heavy duty rear axle? - Nissan Titan Forum
post #1 of 20 (permalink) Old 02-23-2013, 07:12 PM Thread Starter
iTrader Score: 0 reviews
I gave the forum search my best shot and couldn't come up with a thread that exactly matches this. If you know of one, send me the link.
I want to upgrade the load rating of my rear axle. I don't off road or race, but I do tow a boat and carry a camper and other beyond rating loads once in a while. The stock rear axle load rating seems pretty light, so I'm wondering what I can do for an aftermarket upgrade. I'd like to put a true-trac while I'm at it.
2004 2WD KC SE Big Tow.
Thanks--
dakunah is offline
Advertisement
post #2 of 20 (permalink) Old 02-23-2013, 08:25 PM
Shane06fl's Avatar
iTrader Score: 1 reviews
Re: heavy duty rear axle?
Increase capacity top the factory axle, nothing. If you want to help squatting and handling you can probably install air bags, very popular around here. This does not automagicly increase your payload, it only helps with what the truck was designed for.
There are some after market axles being made out there but your suspension and frame are still the weak links.
Loading a slide in camper and towing a boat you probably need to jump up to a 3/4 ton.
2005 Titan KC SE ***Sold 9/6/14***
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
2013 Chevy Silverado LT Z71 CC short bed
5.3L LC9 engine
Heavy duty tow package/cooling
4wd
loaded to the gills
mirrors sucks (for now)
2004 Keystone 24RS
Shane06fl is offline
post #3 of 20 (permalink) Old 02-23-2013, 08:34 PM
Shogunles's Avatar
iTrader Score: 4 reviews
Sorry Bro, you cannot add or increase your load. All done at the factory. Like Shane said, Air bags and a good WD Hitch is about all you can do. But it will not increase you max payload or tow rating. It will help you tow better, keep you level and brake better. Only way to increase this is to increase the size of your truck.
I just installed Firestone Ride Rite Air Helper Springs. Very easy install, beefier bag than the Air Lifts, and it is bolt on no drill. Wish I got them sooner. If you need a good WD Hitch, look at the Reese Straight Line WD Hitch. And buy the Sway Cams that are compatible with it. It is one of the best hitches you can buy. Squats the T very well. They are on sale at Camping World.
2011 Titan SV Crew Cab
Navy Blue
Airaid MXP Intake
PML Deep Transmission Pan Black Powder Coating
Mag Hytec Rear Differential Cover Black Powder Coating
Bully Dog GT
Big Tow
Firestone Ride Rite Air Bag Kit
Advent Advuv630 2 DIN Nav/CD/DVD/Backup Camera (Dealer installed not my choice)
ARE Fiberglass Tonneau
Viper Remote Start and Security System
Front Windows Tinted to Match Factory Rear Tint
Myron and Davis Headrest Monitors
Future Mods:
Gibson Dual Exhaust
Bilstein 5100's All Around
Curt Front Mount Hitch Receiver
Shogunles is offline
post #4 of 20 (permalink) Old 02-23-2013, 10:28 PM Thread Starter
I have the Firestone air bags and 10-ply tires. The weak point seems to be the rear wheel bearings, which I don't think can be upgraded in the A44 tube. The A60 will take bearings that have 50% higher rating; does anybody have experience with some of these A60 hybrid mods on this kind of application? Most of the threads I've read about this are guys running lifted rigs off road with huge wheels.
dakunah is offline
post #5 of 20 (permalink) Old 02-23-2013, 11:02 PM
goodkill365's Avatar
Garage
iTrader Score: 18 reviews
Currie rear end man, they cost a lot but worth the $$
DIRT KING FABRICATION
LEGIT LEDS
Synthetics117.com
BLACK WIDOW EXHAUST
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived." — General George S. Patton
goodkill365 is offline
post #6 of 20 (permalink) Old 02-23-2013, 11:43 PM
Anavrin351's Avatar
iTrader Score: 2 reviews
The frame isn't a weak point while towing. It's a fully boxed frame.
sent from here
06 4X4 CC
Banks Intake, Banks Monster Exhaust, UpRev
Black 18" XD Monster Wheels W/Toyo M/Ts
1.5" front level W/ bilstein 5100s on middle perch and 1.5" rear block with bilstein 5125s
[/URL]
Anavrin351 is offline
post #7 of 20 (permalink) Old 02-24-2013, 08:53 AM
wahvtec's Avatar
^I disagree id want to see some numbers before adding significantly more than suggested stress to the frame. Box is stronger than C channel frames, but at the cost of flexibility. This is why you don't see big rigs with box frames.
wahvtec is offline
post #8 of 20 (permalink) Old 02-24-2013, 10:10 AM Thread Starter
I think I agree about the frame being able to handle it-- the boat I'm towing is only about 3500 anyway, so even with the camper on i'm under the gross combined vehicle weight. It's the load in the bed and the rear wheel bearings i'm worried about. I'll check out the currie rear ends. Even if they're expensive they're a lot cheaper than buying a new pickup. Thanks.
dakunah is offline
post #9 of 20 (permalink) Old 02-24-2013, 02:18 PM
Anavrin351's Avatar
Re: Re: heavy duty rear axle?
I wasn't saying add more than suggested, I was saying it isn't a weak point on the T. It's one of the strong points.
sent from here
06 4X4 CC
[/URL]
post #10 of 20 (permalink) Old 02-24-2013, 02:31 PM
wahvtec's Avatar
True, just surpassing load ratings scares me. Why not go dana 60 swap with air springs. Seems like that's the favored route to beef up the rear.
wahvtec is offline
post #11 of 20 (permalink) Old 02-24-2013, 03:18 PM
Shane06fl's Avatar
sent from here
You increase the axle capacity but say installing a 3/4 ton axle (example) the frame and suspension become the weak link. Any way you slice it a 3/4 ton axle in a half ton truck does not make it a 3/4 truck.
The Titan's frame as it sits is probably the strongest point in stock form.
Big Tow
4x4 SE
Deep Water
2005 Titan CC
Big Tow
4x4 SE
Silver
New Ride
5.3L LC9 engine
4wd
loaded to the gills
2004 Keystone 24RS
post #12 of 20 (permalink) Old 02-24-2013, 05:31 PM
Garage
iTrader Score: 5 reviews
Send a message via AIM to JauntyBishop
If you start towing more than 10,000lbs in the titan, your gonna have transmission issues before losing the frame or the rear end.
Cory
2008.5 Crew Cab SE FFV 2wd.
Bolt ons... 377rwhp/432rwtq (Dynocom 5000)
MOD LIST with Current Projects (Custom Headers and Cylinder head build) Link Below.
http://www.titantalk.com/forums/tita...pic-heavy.html
JauntyBishop is offline
post #13 of 20 (permalink) Old 02-24-2013, 07:13 PM Thread Starter
Nowhere near 10k. 2k for the camper, 3.5k for the boat. The A60 axle upgrade sounds like the way to go. Do any of you Pacific Northwest guys know of a shop in the area that does this kind of thing, or is it just easiest to go to AZ or Currie in SoCal? I'm in the Willamette Valley.
dakunah is offline
post #14 of 20 (permalink) Old 02-25-2013, 02:50 PM
Garage
Why upgrade your axle if your not even towing anywhere near the limits of the stock one?
add a tru trac and you eliminate the weakest link in the whole rear end.
Cory
post #15 of 20 (permalink) Old 02-25-2013, 06:06 PM
Shogunles's Avatar
For Tru Trac you need to have a machine shop press it into the gear correct?
Navy Blue
Airaid MXP Intake
Bully Dog GT
Big Tow
Future Mods:
Gibson Dual Exhaust
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
Heavy Duty REAR bumper options? bucketfan Titan Parts & Accessories 4 11-10-2009 03:36 PM
FS: Heavy Duty Bed Mat scargo67 Buy/Sell 0 03-21-2009 06:31 AM
moser heavy duty jeep axle kit loudtitan Buy/Sell 0 06-09-2007 11:55 AM
First production PRG 1.5" Rear Kit with Custom Heavy Duty U-bolts! HavockWK Titan Suspension 19 03-31-2005 12:31 AM
You may post new threads
You may post replies
