Old 11-14-2004, 11:20 PM   #1 (permalink)
Rear Differential
I just drained the rear differential then added around two liter of valvoline 80-90. Is that enough? how do I know if its enough or not?
BIGGERSTUFF is offline   Reply With Quote
Old 11-14-2004, 11:30 PM   #2 (permalink)
I believe it sould fill to the bottom of the fill hole.....or have a little dribbling out when full...
2004 Deep Water 4x2 SE CC
Born 04/2004
Lund Interceptor Deflector
Line-X Spray in Liner
Retrax Retractable Bed Cover
More Goodies To Come
JBWilkins is offline   Reply With Quote
Old 11-15-2004, 05:19 AM   #3 (permalink)
goathead's Avatar
first of all, make sure its on level ground. secondly, fill it till its running out of the fill hole. approx 68 oz. if this is not correct, somebody correct me. its what i did to mine, w/ no probs so far.
steve
steve
Old 11-15-2004, 07:19 AM   #4 (permalink)
Mine took just over 2 Qts so 64oz sounds about right!
04 Radiant Silver SE 4X4 Crew
Popular W/Capt's
Big Tow, Banks
03 Maxima 6 speed...traded for:
06 BMW 325 6 speed manual, sport pkg and xenons.
KL99SEA is offline   Reply With Quote
Old 11-15-2004, 08:02 AM   #5 (permalink)
SupraTitan's Avatar
2 qts +4 oz, for a total of 68 oz
04 Titan CC,BT,OR,4X4, 5333lbs, 15.42@88.79mph stock
Zoomers catback, 2* timing advance
SupraTitan is offline   Reply With Quote
Old 11-15-2004, 09:38 AM   #6 (permalink)
BritGuy's Avatar
What he said. Did mine till it came out of the fill hole.........glad I did because it looked very nasty.
BritGuy is offline   Reply With Quote
Old 11-15-2004, 10:03 AM   #7 (permalink)
How is it done?
You just open botton plug, loosen upper plug and let it run? Then just simply fill through the upper plug?
emilioferrer is offline   Reply With Quote
Old 11-15-2004, 10:07 AM   #8 (permalink)
vector6's Avatar
yup... thats how..
2006 jeep RUBICON so long titan...
No News with Combat Crews
vector6 is offline   Reply With Quote
Old 11-15-2004, 11:17 AM   #9 (permalink)
azxr's Avatar
I just did mine on Saturday with about 4K on the vehicle. My level was fine, but it was nasty looking. I did the Valvoline 80-90 synthectic blend for right now since I couldn't fine any pure synthetic. I just filled until it started dripping from the fill plug. It took just a little over 2 quarts.
_________________________________________
2004 Titan SE KC 4X4 - Pearl White
Born on 7/14/2004
Purchased on 8/28/04
SE Off Road Package
SE Utility Bed Package
Rockford Fosgate with Power Captain
azxr is offline   Reply With Quote
Old 11-15-2004, 01:28 PM   #10 (permalink)
TallTexan's Avatar
cHANGED MINE AT 3000 MILES TO MOBIL 1 SYNTHETIC AND AT 7500 MILES I CHECKED IT AND STILL FULL AND OIL VERY CLEAN. I THINK THAT SOLVED MY PROBLEM.
Robert Louis Stevenson
Old 11-15-2004, 03:42 PM   #11 (permalink)
Banned
What kind exactly can we use? I'd like to switch to Mobil1 myself but I'm a little leary because I keep hearing on here that it has to be an exact type. Can someone shed a little light on the subject? Thanks!
OnebadSE is offline   Reply With Quote
Old 11-15-2004, 04:34 PM   #12 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Yep.....hi OnebadSE......I went to the dealer today.....looked at the pretty aluminum finned rear differential cover on an 05 Titan and it says.....use 75-140 wt. synthetic oil only.........so thats what Nissan appears to be doing like many other high performance manufacurers use and specify.....volvoline has synpower 75-140 Gear Oil $14.44 qt. at auto-zone...that's what I'm gonna use and get that aluminum cover that also holds more fluid.not sure how much more yet.....that's where I'm going with this......engine oil will be synthetic too!!
honeykeeper is offline   Reply With Quote
Old 11-15-2004, 05:32 PM   #13 (permalink)
Originally Posted by emilioferrer
How is it done?
Service manual says remove upper first, then bottom. Something about difficulty removing upper if remove bottom first?
billaku is offline   Reply With Quote
Old 11-15-2004, 07:11 PM   #14 (permalink)
Banned
Excellent. Thanks for the info. But my dealers 05s don't have that shiney finned diff cover. What's up whit that? Also, are the front and rear diffs the same in that they both take the same amount? And for those with the finned cover, are they front and rear?
Old 11-15-2004, 07:46 PM   #15 (permalink)
raskm's Avatar
Just wondering if the new Titans have new diff cover that states use 75-140 wt. synthetic oil only, what does the new manuals say?
2004 NISSAN TITAN SE CC*4X4*OR/BT*OEM BUG DEFLECTOR*IN-CHANNEL VENTSHADE VENT VISORS (absolute junk!!)*SMOKERS PACKAGE*CATCH ALL FLOOR MATS*NISSAN SEAT COVERS*
raskm is offline   Reply With Quote
