Question.....I have a crew cab SE w/no Big Tow or Off-road Packages... I am tearing open my rear differential to install a limited slip...i figure that i may as well upgrade my gear ratio while I’m at it.....Do you think all that would be required is to change Drive pinion & the Drive gear from a 2.94 to a 3.36. And what type of specialist would i go to in order to have this work performed?
Attached diagram of my REAR FINAL DRIVE ASSEMBLY
Any idea's help or leads would be greatly appreciated..
Thanks,
Check out trutrac
http://www.tractech.com/Products.htm#slip
Joe Hige (jhige@tractech.com) w Tractech say this will be available for the titan in the 2nd Qtr of 05'
