View Poll Results: Have you had your rear differential replaced?
Yes on my 2004 Titan 15 8.29%
Yes on my 2005 Titan 0 0%
No on my 2004 Titan 148 81.77%
No on my 2005 Titan 18 9.94%
Voters: 181. You may not vote on this poll
Old 05-10-2006, 09:55 AM   #76 (permalink)
Re: Titan Rear end failures (Pic)
I was passing Naples Nissan dealership in Naples Fl, and in the back yard near the dumpster were a pile of rear ends off Titan trucks. I just had to take a picture. The tech there said they burn up alot.. See pic.
Milowilli is offline   Reply With Quote
Old 05-10-2006, 01:54 PM   #77 (permalink)
Toxman's Avatar
Send a message via ICQ to Toxman
Now here is a picture that will have Nissan $hitting gold bricks!!! I'm sure they monitor this site and you can bet there is an internal memo going out right now to all the dealerships saying "DO NOT stack worn parts in public view!!!"
How many were there? Looks like 5-6? Problem is they replace the rearend for anything that goes wrong with the axle assembly. It doesn't have to be a diff blow out. I do notice a couple aluminium diff covers. I hope those are 04's and 05's not 06 axle assemblies!!!
2004 Titan CC LE - Born 10/04
Mods:
  1. Westin Bull Bar
  2. Flowmaster Exhaust
  3. 2" leveling Kit
  4. K&N drop in filter with stock air box mod
  5. BF Goodrich 315/70/R17 T/A AT KO tires
  6. Active Tuning grounding kit
  7. Under seat storage bin
  8. Silver Star Halogen Headlights
  9. Nissan Sliding tool box
Toxman is offline   Reply With Quote
Old 05-10-2006, 07:22 PM   #78 (permalink)
CHEIF's Avatar
Re: Poll on rear end failures
A picture is worth a thousand words
If big brother Nissan IS watching, I hope they enjoyed that one.
LOL you gotta love that one
'04 TITAN CC XE 4X4
OFFROAD PKG
PREFERRED PKG
SILVER
CHEIF is offline   Reply With Quote
Old 06-09-2006, 07:25 AM   #79 (permalink)
have 2006 titan rear end was replaced at 2000miles due to whinning sound with a new complete rear end assembly . now have 500 miles on new rear end and it is being to make the same noise .
rjp06titan is offline   Reply With Quote
Old 06-09-2006, 08:09 PM   #80 (permalink)
Toxman's Avatar
Rip,
If it is the rear end then something else is causing it to fail. Is it a 4X2 or 4X4?
Go to the thread below and give WhiteLE your info. We would definately like to learn about your past failure and where the latest issue leads. We haven't had many 06 failures reported!
Nissan Titan-NHSTA REPORTED FAILURES-of powertrain:driveline:rear differential unit:
Mods:
  1. Westin Bull Bar
  3. 2" leveling Kit
Old 06-10-2006, 07:50 AM   #81 (permalink)
my titan is 4x2 it was a ring gear and pinion whine in my opinoin. dealer was real cooperative and replaced the rear assembly. i do not think i was the first with the problem. i talk to service mangerby phone yesterday about new rear end begining to make same noise but i wanted to put more miles on it to see if it get worse. whine sound only when not in a pull, just at a steady speed. let off accelerator noise goes away, apply accelerator and noise goes away. not bad but believe it will only get worse.
Old 06-10-2006, 02:06 PM   #82 (permalink)
Toxman's Avatar
Could be a bearing also. Keep us posted.
Mods:
  1. Westin Bull Bar
  3. 2" leveling Kit
Old 11-30-2007, 05:28 PM   #83 (permalink)
lhtiii's Avatar
Mine rear differential broke backing out of the driveway at 37700 miles. Just out of waranty. Nissan replaced the assembly without any problem. Now at 43000 the rear u-joint on the front drive shaft (4x4) broke while I was doing around 70 on the freeway. The spining shaft put a hole in the transmission case, the transfer case, and the exhaust, pulled out the wires to the oxygen sensor and tranmission, and pushed up the floor boards. It made for a few exciting seconds before I pulled over. When I got pulled up onto the flatbed, trans fluid poured out like water. After a talk with Nissan, they are fixing everything under waranty. Still love the truck, but don't have much faith in the reliability.
'05 Titan King 4x4 SE
born 1-12-05
Red Brawn SE Popular Captains w/Rockford, Off-Road, Side Air Bag, Big Tow, SE Utility Bed
lhtiii is offline   Reply With Quote
Old 12-01-2007, 10:55 AM   #84 (permalink)
Learjet's Avatar
Powertrain warranty is 5 yr / 60,000 miles.
2006 SE, CC, Big Tow, white
Born 5/06
Learjet is offline   Reply With Quote
Old 12-02-2007, 12:15 AM   #85 (permalink)
technorev's Avatar
Nissan amazes me in allowing this problem to continue and I've heard of quite a few that have had rear end replacements, and some having as many as 4 replacements. With many truck enthusiasts turning to the net and to groups such as this to get information and compare problems etc. and with those checking out reliability before they buy, why o why would Nissan allow this on going problem to continue year after year? Makes no sense to me. They are so close to having one of the greatest trucks out there to allow this problem to continue. And then there is talk of a diesel in 2009. Can you imagine what that will do to this rear!
I've been watching this problem for a couple of years now. I am ready to purchase a new truck and will pay cash, but I'm not laying my hard earned money down on a Titan until they address this issue. If I need a truck before then, it'll have to be something else, I know of too many who have had problems. Still waiting Nissan!
technorev is offline   Reply With Quote
Old 12-02-2007, 12:34 AM   #86 (permalink)
NorCal 4x4's Avatar
Didn't they upgrade the rear differential for the '08 model?
And, for at least the ones with the e-lock, they upgraded it from a 2 pinion to a 4 pinion spider setup back in late '05 or early '06.
We have a 5 year 60,000 mile power train warranty, and 7 year 100,000 mile warranties are available, so if you are that worried buy an extended warranty or a POS big three that is assembled in Mexico or Canada.
Old 12-02-2007, 08:18 PM   #87 (permalink)
technorev's Avatar
I believe the only upgrade on the '08 rear is a larger diameter axle to support carrying more weight. And many on this site with the late '05 as well as '06 trucks have had multiple replacements, you can check the nhtsa website to verify this fact. Also there was a thread on this site with a Dana engineer stating that the new axle design was still having trouble with axle seals and basically saying the rear end was too small for the power.
I don't believe paying for an extended warranty on a new truck is the answer. What does that say about the quality of the truck when it's highly suggested that you buy an extended warranty? I believe that kind of thinking enables the manufacturer to continue to produce a sub-par product, as long as the masses will to continue to purchase it. All I'm saying is that I am amazed at how slow they are in dealing with this problem when they are so close to having the best truck out there.
Old 12-02-2007, 09:46 PM   #88 (permalink)
gabriel c.'s Avatar
i see only 04s and 05s are the 06s exempt from the failure? ive got an 06 4x2 and at the pace im racking up the miles ( i just hit 9000 in 1.5 years) ill bee way out of warranty to take care of the problem if it ever appears.
third coast titans
gabriel c. is offline   Reply With Quote
Old 12-03-2007, 09:05 PM   #89 (permalink)
Attached is the latest rear end failure log
white
whiteLE is offline   Reply With Quote
Old 12-03-2007, 09:59 PM   #90 (permalink)
NorCal 4x4's Avatar
If they didn't fix the problem, it must be isolated, since they are the one's paying to replace the rear axles and differentials.
Multiple failure from the same owner, suggest a lemon, with something misaligned that the technicians continue to miss. And of course there are those owners that had more than one Titan, different years that had a failure. I wouldn't necessarily say they abuse their Titans, for one I feel a truck should take almost any so called abuse, but also because some people win Powerball, or get hit by lightning more than once.
Hearsay your honor, this is the internet after all.
Also axle seals have absolutely nothing to do with the rear differential failures, unless someone was so dumb, that they let their differential drain a couple of quarts of fluid onto their driveway, and then went and did some power braking at a stop light.
I would suggest an extended warranty for any new car or truck. With the complexity of new cars and trucks and the labor costs it's a smart move in my opinion. And if I was one of those that are certain most rear diffs will fail, I'd think it's an even better idea. I'll be covered. [I'm almost at 60K miles now].
I believe they have dealt with it. If it was a large percentage of Titans, it would cost them, since they offer such a long power-train warranty. I believe the average mileage of the failures on the spreadsheet that summarizes the NHTSA is less than 24K miles, so if a common issue that would mean two axle replacements during the warranty period. At probably $2000 cost to Nissan in parts and dealer labor ... a rather costly issue to ignore, especially on the '08, where they were already beefing up the axle.
Btw, if mine doesn't fail by the end of my extended warranty, at 100,000 miles or so, I will probably replace the old style 2-pinion spider on my e-lock with a 4-pinion True-Track Limited Slip Differential, (LSD), since Nissan did switch to a 4 pinion spider gear on their e-lock, as mentioned in my previous post. Mostly though because a TT LSD is more useful to me, and a 4 pinion spider gear replacement would probably cost me more.
