Hello everyone- I put my truck in the shop because it was having some starting issues. The engine would crank but it wouldn't turn on. If I let it rest for 5 or 10 mins after a failed start, it would start right up with no problem. Once it starts it runs like a champ. Sometimes it would happen every time I turned the truck off or sometimes it would go days with no issues. I'm about to hit 200k miles so figured it was the fuel pump. My mechanic found that the fuel pump was fine, but my injectors were not getting any power during a failed start. He said he's never seen that and is not sure of the cause. Has anyone else experienced that or any ideas on the possible fix? Thanks!!
