Did you remove the diff cover prior to changing the oil? If not take it back to the dealer to have them look at it. Oil should never seep out of the cover and is indicative of a problem. If you did remove the cover I doubt that they cover the cover leak under warranty unless you are less than truthfully with them.
2004 Titan CC 4X2 LE Canteen
"SUB out going sinker"
