Old 07-26-2005, 01:23 PM   #1 (permalink)
kongmen's Avatar
Seals leaking in rear diff
Took the truck in for the brake issue (1st time) and I ask them to look at the rear diff. They said the seals where leaking so I ask if I ordered and paid for the 05 diff cover would they put it on and they said they would as well as put in the 75 140 lube. I'm also getting a new radio because the ssv (speed sensitive volume?) is not working. I had them look at the bed liner (there is an area about the size of a quarter that appears to be coming off) and they said its OK. I will have them look at the liner again when I go in for the diff seals and radio. btw the rear diff is $105.
04 Titan SE Crew Cab 4x4 Off Road Big Tow Red Brawn.
kongmen is offline   Reply With Quote
Old 07-26-2005, 02:19 PM   #2 (permalink)
SupraTitan's Avatar
Ummm, why would you volunter to pay for the aluminum cover? Are they changing seals or the rear end, either way they probably would have done the cover for free.
04 Titan CC,BT,OR,4X4, 5333lbs, 15.42@88.79mph stock
Zoomers catback, 2* timing advance
SupraTitan is offline   Reply With Quote
Old 07-26-2005, 02:30 PM   #3 (permalink)
kongmen's Avatar
I just assumed they would have put the oem cover from my truck back on. They are just changing out the seals no need to put on a different cover.
Old 07-26-2005, 02:36 PM   #4 (permalink)
rjspitz's Avatar
Is the cover starting to rust? If so, they should replace it free. And the stamped steel cover is no longer available, so that leaves only the '05 aluminum cover.
Old 07-26-2005, 02:46 PM   #5 (permalink)
kongmen's Avatar
Good thinking. I've looked briefly at the cover and I really didn't notice any rusting but I'll look closer. Thanks.
Old 07-26-2005, 03:50 PM   #6 (permalink)
kongmen's Avatar
I don't think I'll have any luck with the rust argument because all I see is a slight amount of surface rust up around the bolt holes and no paint peel.
Old 07-26-2005, 04:15 PM   #7 (permalink)
rjspitz's Avatar
Nothing a little brake fluid and salt water can't handle Just kidding.
Oh, well, it's worth shot. Make sure they don't charge you for the diff fluid. And make sure they put the new stuff in. They are not supposed to put in the old stuff.
Old 07-26-2005, 04:33 PM   #8 (permalink)
ptgarcia's Avatar
That sounds like a good idea, I may just try it...
Pauly
Old 07-26-2005, 06:07 PM   #9 (permalink)
Titank's Avatar
off topic...
ButI didn't know my radio had SSV. I guess I should read that darn owner manual instead of tossing it into the desk draw
2005 SE 4X2
- SE Popular w/ Captain Chair
- Big Tow
- Utility Bed
- Traction
MODs:
- Aries Black Nerf Bars
CarDomain Site
~Titank
Titank is offline   Reply With Quote
Old 07-26-2005, 07:05 PM   #10 (permalink)
kongmen's Avatar
About the new lube oil I was wondering how I could tell if the thicker stuff was put in. I'm getting the feeling they are going to pay for the lube oil but I can't think of any way to assure the thicker stuff was put in. Can a person tell by the feel? I can check with little finger before and after change.
Old 07-26-2005, 09:08 PM   #11 (permalink)
EPTITAN's Avatar
Location: some where between bum f&*$ Egypt and you got a pretty mouth
If you get the new finned diff cover it is stamped right on it to use only 75w-140.
EPTITAN is offline   Reply With Quote
