Originally Posted by virus
Dealer quoted me $150 to change the fluid and then informed me that Nissan only recommends drain and fill and not flush and fill. Is this correct?
If I recall correctly from the service manual, it describes disconnecting a line from the tranny fluid cooler while running, and filling until the fluid draining from the tranny cooler line appears as new.
I think if you just drain, drop the pan, and fill you only change 5 quarts.
JetTech's photos:
http://community.webshots.com/photo/...76357561HIcJjA
Hit next a few times to see all the tranny fluid change photos.
I think the price is calculated something like 5 x $13/bottle of NissanMatic J + $80 labor.
Hopefully they are dropping the pan and not just draining at the drain plug. Otherwise that would be $80 for 15 minutes.
