Old 10-12-2005, 04:56 PM   #1 (permalink)
Chaad32's Avatar
Smile Washing engine???
Is it OK to spray down the WHOLE engine?? I researched the forum before posting and saw where certain people use some of the tire cleaner on the engine but I was wondering specifically if it is OK to wash things like the altinator.....obviously not spraying it directly but even overspray.
'05 Titan CC 4X4 LE Galaxy Black
Utilitrack W/extender and gate
AVS bug deflector
AVS ventshades
Ipod mp3
Chaad32 is offline   Reply With Quote
Old 10-12-2005, 05:59 PM   #2 (permalink)
Kronos1965's Avatar
cleaning engine
First thing, disconnect your truck's negative battery cable before working on any engine or electrical system. Another important safety factor is always wear eye protection when working on an engine or using chemical cleaning compounds. The inexpensive price of a good pair of safety goggles is nothing compared to the price of a trip to the emergency room to get your eyes flushed.
First, clean the vents at the base of the windshield using a good sturdy brush, remove any debris or leaves that might obstruct the flow of water down to the base of the firewall. Before running water on your engine, cover any electrical and mechanical components with foil and/or a plastic bag to keep the water out.
If you haven't already, cover the engine's alternator using a plastic bag. Also, cover the distributor cap or coil assembly. A rubber band can be used to help form a water-resistant seal and secure the bag in place. Additionally cover the fuse box and any exposed wiring, take the time to do this right.
Clean around the battery cables, Super Dyno Cleaner is a great choice for this job.
Next, spray your engine with a professional engine cleaner and degreaser such as Red Degreaser. Follow the instructions on the cleaner, depending on how much degreasing your engine needs you may have to leave the cleaner more or less to remove all of the dirt and grime.
After the recommended time has elapsed, hose off the engine with clean water. The spray attachment on your garden hose works great for this. Be sure to rinse your engine well.
Once you've done this, take your truck for a short drive to warm up the engine and dry the water that has puddled in the low points of the engine, and you're done!
Kronos1965 is offline   Reply With Quote
Old 10-12-2005, 07:32 PM   #3 (permalink)
The link below will tell you everything you need to know.
http://www.guidetodetailing.com/arti...p?articleId=25
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 10-13-2005, 01:59 AM   #4 (permalink)
1bigtexastitan's Avatar
Nice link. 303 products are the best. They have excellent UV protectant.
2005 Galaxy Crew Cab SE 4x4 With Big Tow, Rockford Fosgate, Utilitrack System
Mods:
De-Badged
35% Front Tint
Sylvania Silverstars All Around
OEM Foglight Kit
Active Tuning Ground Kit
OEM Rubber Mats
Magnaflow True Dual Custom Exhaust with X-Pipe
1bigtexastitan is offline   Reply With Quote
Old 10-13-2005, 06:19 AM   #5 (permalink)
"If you haven't already, cover the engine's alternator using a plastic bag."
Get down on your back under the truck on the ground near the rear of the passenger side tire and look up to see the alternator way down under the engine. I was wondering about how much water the alternator takes every time you drive in the rain or go through a puddle.
For example:
http://www.titantalk.com/forums/atta...chmentid=16933
Think his alternator got wet?
Old 10-13-2005, 08:52 AM   #6 (permalink)
ptgarcia's Avatar
You don't need to cover anything. In the days of carburetors and distributors with points you needed to cover them. With todays equipment there's no worries. Spray what you want to spray.
Simple Green makes a good engine cleaner.
Pauly
Old 10-13-2005, 08:58 AM   #7 (permalink)
Yep, it got wet allright. I like to keep my engine clean and the only thing I cover is the fuse box area. In the 20 years I have been driving I have never had a problem.
Mods:
De-Badged
35% Front Tint
OEM Foglight Kit
OEM Rubber Mats
Old 10-13-2005, 09:37 AM   #8 (permalink)
Tyltan's Avatar
I used alluminum foil to cover the electrical parts. It is easier than plastic bag.
Tyltan is offline   Reply With Quote
Old 10-13-2005, 03:50 PM   #9 (permalink)
Chaad32's Avatar
thanks guys
AVS bug deflector
AVS ventshades
Ipod mp3
Old 10-25-2005, 08:04 AM   #10 (permalink)
decypher44's Avatar
Great thread. Thanks!
04 Titan 4x2 SE KC, Smoke, Magnaflow Single Exhaust, 05 Diff Cover, Stillen VKPro, AEM Brute Force w/DRYFLOW, Custom Painted Engine Cover , Sylvania Silverstars, Rhino Bedliner, Nissan Bug Smacker, XM Roady2 and iPod (AUX), Sony xplod, 2 x 10" JL 0, and a locking gas cap
decypher44 is offline   Reply With Quote
