2005 Titan King Cab with 100K miles with vibration at highway speeds. Broken u-joint at the front propeller near the transfer case. I must have improperly seated the u-joint because when I drove the truck in four wheel drive, the ear on the yoke snapped.
Now I have a full driveshaft propeller on its way but I am not sure if it is as simple as just bolting it back into place. Does it have a certain alignment that is necessary? I did not mark the old busted shaft so I have no idea which way to line up the bolt holes.
Does it need to be balanced?
I am reluctant to screw up another driveshaft as the replacement cost me $300.00.
Thanks.
Thanks.
