Old 11-17-2005, 12:43 PM   #1 (permalink)
Removing Oil Filter <aarrghhhhh!!!!>
Bought the oil, filter, got everything ready, anticipating a pleasureable time . . . just me and my truck. Hmmm . . . there seems to be a pan in the way, . . . ok, removed that. Applied filter wrench. That's when my world turned to pure "filter-wrench" hell. Yeah, I've been down this road before, over the years. I've really screwed up some stuck oil filters in my day. But, now I'm a lot older and it's cold out there on the ground. I'm figuring some of you younger guys have come across this problem and have a better way of dealing with it. I'd rather not invest in any more tools, such as a chain wrench (I don't have trouble getting them off when I put them on ). . . but I have used those when I was in the military. But, if that's what you suggest, or any other tool, I'll gladly consider it. Thanks for your help. Gary
goxner is offline   Reply With Quote
Old 11-17-2005, 12:52 PM   #2 (permalink)
SWTXTITAN's Avatar
Re: Removing Oil Filter <aarrghhhhh!!!!>
Is this your first oil change??? i've heard 1st time oil change filter battles, but i belive that it is probably just factory over-tightned (hehehehhe even robots mess up).
" You want me? F%*&in come and find me, I'll be waiting with a gun and a pack of sandwiches " Radiohead
"Me I'm standing right down here in Texas, I know that's where I was always meant to be" Pat Green
SWTXTITAN is offline   Reply With Quote
Old 11-17-2005, 12:52 PM   #3 (permalink)
For the first time, I used one of the socket type of oil filter wrenches (metal, not plastic), an extension, and a breaker bar.
I think a few people just punched a big long screwdriver through the filter, but that gets a little messy.
Old 11-17-2005, 01:02 PM   #4 (permalink)
I guess I'm lucky then, the dealer is providing the first oil change. They also provided lifetime carwash.
Calif_Titan is offline   Reply With Quote
Old 11-17-2005, 01:04 PM   #5 (permalink)
Never mind guys (or gals!). After warming up and going back out to take another look at the offending filter, I got out my trusty 17" Channel Lock pliers and within the small operating space I had, off it came!! Reply if you wish, I'm always game to learn something new. Gary
Old 11-17-2005, 01:08 PM   #6 (permalink)
itrice's Avatar
I did the punch hole with screwdriver because at the time I did not have an filter wrench to fit it. It worked but was still a pain, not a lot of room around the filter. I would try something else if I were you.
SE King Cab 4x4 - Born on 1/04
Big Tow - Off Road / No E-Locker
Rockford Fosgate with Captains Seats
Utility Bed - Lower Tray - Tool Box
Weatherflectors
Lund Interceptor Bug Shield
Westin Bull Bar
Westin Driving Lights
AFE Stage II CAI
Bilstein 5100 adjustable front shocks - set at 1" lift
Icon Rear Shocks
SkyFi 2 XM radio
Cell phone install kit w/ SmoothTalker 3 watt booster
- almost always have a good signal now.
itrice is offline   Reply With Quote
Old 11-17-2005, 01:09 PM   #7 (permalink)
Some big arse (probably 15" long) channel locks worked great! But, I get to do my oilchanges at work in a nice heated factory and use their tools and used oil drum!
NKYTITAN is offline   Reply With Quote
Old 11-17-2005, 01:33 PM   #8 (permalink)
kartman's Avatar
I tried the socket for the filter thing but it slipped off and would not work. Went with the screwdriver and hammer method.
Rebar Wrangler
Old 11-17-2005, 02:04 PM   #9 (permalink)
Papa_D's Avatar
Cannel locks baby.
IRC VK56 Member "BIG CHIEF WANNARACEUM"
2005 XE, "Land Shark",1/4 MILE: 13.851 AT 98.52
Full Street Trim on Snow Tires Record HolderBuild date 3/05
Performance mods: UpRev, JWT cams, NISMO CAI, NISMO True Duals with Dr Gas Xpipe, NISMO Headers with Swain's White Lightning Coating, Suncoast Ram Air Hood, Tru Trac, Burnout mod
Aesthetic mods: NISMO graphics, Grillcraft, Retrax, De-badged, 2" PRG lift, Titan fog lights, 18" LE wheels 285/60/18 Dueler Alenza tires, 35% tint
Stereo mods: Pioneer Premier DEH-P880PRS head unit, Audison LRX 4/300 Amp, Boston 6x9 coaxials front & Focal 6.5 coaxial rears with JL tweeters in dash.
Papa_D is offline   Reply With Quote
Old 12-12-2005, 06:34 PM   #10 (permalink)
Save yourself a ton of trouble and use a small rubber strap wrench. You often see them sold in pairs from Allied, etc... one larger and one smaller. The smaller one will allow you to get the handle up in the tight spot and turn it enough to break the filter loose. You still have to apply correct pressure/tension to get a bite, but it will grab surprisingly well. When you replace filter, hand tighten ONLY 1-2 turns after contact. I do this on all my vehicles and have no problems. Also, point front end downhill helps oil run off drip ramp without getting too much on stabilizer bar. Good luck!
TITAN LV is offline   Reply With Quote
Old 12-12-2005, 07:08 PM   #11 (permalink)
Send a message via Yahoo to firefighter4usn
Yeah the socket with like 2 extentions and a ratchet will work every time.... even with the skid plates on! Good luck!
Scott...
US Navy
stationed in VA
firefighter4usn is offline   Reply With Quote
Old 12-12-2005, 09:36 PM   #12 (permalink)
rico387's Avatar
Phooey! take it you the dealer and let some other chump skin his knuckles for the first oil change. If you already drained it, fill it back up. Take it to the dealer, walk to, or catch a ride to the nearest pub, read the funnies and have a cold beverage while some ASE certified chap hates you. After that, change your own lube.
rico387 is offline   Reply With Quote
Old 12-12-2005, 09:58 PM   #13 (permalink)
f00dstamps's Avatar
Send a message via AIM to f00dstamps Send a message via MSN to f00dstamps
i had to do the same. i couldn't believe how tight it was.
2005 CC Titan 4x4 Blizzard White *** SE Popular Package w/ Captain's *** Utility Bed Package w/ Bed Extender *** Offroad Package *** Big Tow Package *** Valentine 1 (hardwired) *** Clifford Matrix RSX 3.5 Alarm + Remote Start *** Amsoil Synthetic motor & gear oil *** 20% Sun-Guard *** Weathertech front floor liners *** Truxedo Lo Pro *** Husky rear floor liner *** HID 4300k Denso/Koito/Philips *** Vulite LED taillights *** Luminarc yellow foglight bulbs *** Scangauge II *** overhead racks w/ kayak attachment *** DR coilovers *** DR rear 4x4 shocks
WANTING TO SELL: bed extender adapter for tonneau covers (i.e. Truxedo)
f00dstamps is offline   Reply With Quote
Old 12-13-2005, 10:53 PM   #14 (permalink)
NorCal 4x4's Avatar
Found the cross referenced oil filter at Walmart, unboxed it, tried several of the over the end octagon filter wrenches, (3/8" socket wrench drive), and found the perfect fit. Fortunately it also fits the Nissan filters that I used. Actually a very tight fit. BTW, Oil/filter change is very easy on the OR pkg. (skid plate has a filter access panel with 4 hex screws), however rear and front diff. fluid change is even easier, and transfer-case is very easy too (but messy in the wind due to the thin D-matic fluid).
Note: J-matic or equivalent is required for our automatic transmission, not compatible/interchangeable with D-matic.
NorCal 4x4 is online now   Reply With Quote
Old 01-08-2006, 08:32 PM   #15 (permalink)
Try a K&N oil filter. It has a 1" hex head on it so just use a 1" socket ( with an extension ) and it's much easier.
DaveYZ250F is offline   Reply With Quote
Ultra filter oil filter? 05dr Titan Performance Modifications 8 10-11-2005 02:38 PM
Ultra Filter (resuable oil filter) mlucero Titan Parts & Accessories 4 08-01-2005 06:10 PM
Problems removing the oil filter. tbcar Titan General Discussion 20 06-30-2005 08:07 PM
oil filter found; fuel filter??? juma Titan General Discussion 2 04-18-2004 12:06 PM
