Old 11-19-2005, 04:01 PM   #1 (permalink)
Titan 2006 XE 4X4 Towing
Bought a 2006 XE 4X4 no tow package. Manual says 6500 lbs max tow, dealer says 7500, and Nissan Corp with my VIN says 9600 max tow.
Will be towing around 7,000 lbs not all on flat land. What gear up hills would you use to tow this? Do I use the Tow button when towing in a lower gear?
Thanks.
Kevin
XRING600 is offline   Reply With Quote
Old 11-20-2005, 01:35 PM   #2 (permalink)
mick3643's Avatar
Re: Titan 2006 XE 4X4 Towing
use the tow mode if your climbing hills,if not kick it back into 4th and let her rumble. even with no tow package the titan is a tow beast.
2005 2wd SE Crew Cab
air bags
turbo muffler
Scan guage
Bd tuner beta
mick3643 is offline   Reply With Quote
Old 11-20-2005, 02:23 PM   #3 (permalink)
Thanks. I believe that is exactly what I will do. If anyone has had a gooseneck hitch installed I would be interested in hearing your experience with that. One large question that comes to mind is how it would affect warranty if you have problems.
Kevin
TN.
Old 11-21-2005, 09:50 PM   #4 (permalink)
You have a tow mode? I was under the impression that that only came with the Big Tow package... are you sure you don't have it (did your truck come with a Class IV hitch or the 2-piece mirrors)?
Anyways if you don't have it, your max will be around 7400 lbs (CrewCab knocks the capacity ~100 lbs for the added cab weight. 9500lb limit is only on the KC Big Tow package trucks.
-Cyrus
Vyrus is offline   Reply With Quote
Old 11-22-2005, 12:55 AM   #5 (permalink)
Mr. B's Avatar
I have a tow-mode button on my XE without BigTow package. Come to think about it, I looked at about 5 different trucks before I hung my head and bought the cheapest one and they all had that button.
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline   Reply With Quote
Old 11-22-2005, 04:02 PM   #6 (permalink)
All 2006 Titan come with the Tow button.
I am going to call Nissan one more time to verify their numbers on my max towing which they told me per my VIN was 9500 lbs.
2006 LE Titan Clint Titan General Discussion 2 08-29-2005 10:58 PM
2006 Titan changes hydrogeoman007 Titan Pictures & Media Post 16 08-22-2005 04:32 PM
2006 Changes for the Titan Bassomatic Titan General Discussion 53 08-13-2005 08:56 AM
What would you change in the Titan for 2006? markinho Titan General Discussion 41 01-28-2005 09:55 PM
2006 Titan wish list... pluckyew Titan General Discussion 0 12-01-2004 01:59 PM
