Old 11-22-2005, 01:49 PM   #1 (permalink)
mopar's Avatar
Send a message via AIM to mopar
Rear Diff fluid
Changed my Rear Diff fluid went with the Mobil 1 75-140(76oz and it was oozing over a little out the check/fill hole) when I pulled the drain plug I didn't find that many metal shavings but 1/4-1/2 of sludge/grease?? Is this normal is it some type of assembly lube that just settled to the bottom of the diff housing?? I have an build date of 01/05 got it with 60miles on it (40 were mine and the wifes test drives) at the end of July now has just over 6k. It has the finned cover that say synthetic 75-140 only. Should I be worried?? Went for a trip down the block and it seemed nice and smooth(maybe smoother than before could just be in the head though).
Thanks
Sean
Sean
RLTW
05 Galaxy Black SE CC 4x4 w/Big Tow Born on 01/05
Borla Cat Back--------AVS Taillight Blackouts
ARE Z series cap------Wade InChannel Ventvisors
OEM Step Rails PC Black-----Weathertech extreme floor liners
K&N 77series CAI------Tailgate mod
Rubber Bed Mat----Custom Bed rug
PRG 4" Perfomance lift--OR Skidplate PC Black w/holes
KMC Backseats 18x9---Procomp Extreme AT 325 60 18
mopar is offline   Reply With Quote
Old 11-22-2005, 01:52 PM   #2 (permalink)
Re: Rear Diff fluid
I had what appeared to be assembly lube in mine also.
Old 11-22-2005, 01:58 PM   #3 (permalink)
Send a message via ICQ to Brons2 Send a message via AIM to Brons2 Send a message via MSN to Brons2 Send a message via Yahoo to Brons2
Re: Rear Diff fluid
me too, big glob of something that looked like Moly assembly lube.
2004 Titan XE Crew Cab 4x2 Born on 9/22/04
Purchased 10/22/04 at South Point Nissan in Austin
Options: XE Preferred Package
Floor Mats
Mud Guards
TRADED IN 9/1/06 for something more fuel efficient. My gf misses the White Titan....lol.
Brons2 is offline   Reply With Quote
Old 11-22-2005, 02:01 PM   #4 (permalink)
mopar's Avatar
Re: Rear Diff fluid
Cool just making sure I hadn't burned up my fluid and caused the sludge. Also did anyone put any sealant on the plugs?? I didn't but it looked like there had been some white sealant on it.
Sean
RLTW
Old 11-22-2005, 02:06 PM   #5 (permalink)
Re: Rear Diff fluid
Yes. I used Permatex, it was either High Temperature, or High Performance, Thread Sealant. I can't remember which. I think either would work fine.
Old 11-22-2005, 02:10 PM   #6 (permalink)
Re: Rear Diff fluid
It's the high performance. I lifted the part number right out of the service manual and went down to the parts store and picked it up.
Floor Mats
Mud Guards
Old 11-22-2005, 02:30 PM   #7 (permalink)
mopar's Avatar
Re: Rear Diff fluid
uh oh I guess better go do that tommorrow hopefully it doesn't all leak out tonight.
Sean
RLTW
Old 11-22-2005, 02:49 PM   #8 (permalink)
HudsonValleyTitan's Avatar
Re: Rear Diff fluid
I don't use anything on the plugs, nor does the dealer . Just install em' dry (and properly torqued). You'll have a helluva time getting em' off otherwise.
- Joe
Old 11-22-2005, 02:57 PM   #9 (permalink)
mopar's Avatar
Re: Rear Diff fluid
Good thing cause after tyhinking about it I wasn't sure how I'd get the drain plug off without losing my fluid.
what's the torque spec on those plugs?
Sean
RLTW
Old 11-22-2005, 03:04 PM   #10 (permalink)
Re: Rear Diff fluid
For 2004:
Torque specs (ft-lb):
Front diff drain plug: 20
Front diff fill plug: 20
Service Manual, p. FFD-13
Rear diff drain plug: 20
Rear diff fill plug: 25
Service Manual, p. RFD-11
Old 11-22-2005, 03:10 PM   #11 (permalink)
mopar's Avatar
Re: Rear Diff fluid
thanks You guys are the best!
I don't care what they say about you.
Sean
RLTW
Old 11-22-2005, 03:14 PM   #12 (permalink)
Re: Rear Diff fluid
I didn't have any problem getting mine off the 2nd time. I used the sealant and hand-tightened without a torque wrench. Note that I didn't drown it in sealant, just put enough on there to get it down in the threads.
The object really is to keep it from leaking. If your method accomplishes that, then more power to you.
Floor Mats
Mud Guards
Old 01-11-2006, 06:00 PM   #13 (permalink)
Cool Re: Rear Diff fluid
Does the 2005 come from factory with synthetic ?
steig is offline   Reply With Quote
Old 01-11-2006, 06:11 PM   #14 (permalink)
mopar's Avatar
Re: Rear Diff fluid
Yes mine did and it says it on the diff also.
Sean
RLTW
Old 01-15-2006, 09:43 AM   #15 (permalink)
Marc's Avatar
Send a message via AIM to Marc
Re: Rear Diff fluid
So all 05's had syn in the diff?
2005 Titan CC SE 4x4 Radiant silver
Big Tow Pkg
Line-X Spray in bed liner
Active Tuning Ground Kit
Chrome Tailgate Trim
Recon Line of Fire and Ice
Weathertech In-channel visors
Weathertech floorliners
Sirius Satellite Starmate Replay
www.nenoc.org
Marc is offline   Reply With Quote
Had the oil and rear diff. fluid changed today. Flight Test Titan Engine, Transmission & Drivetrain 7 08-03-2005 10:47 AM
Changed rear diff fluid GO_VOLS! Titan General Discussion 11 05-16-2005 10:39 AM
Rear Diff fluid question...HELP!! VShortt Titan General Discussion 6 03-02-2005 10:27 AM
04 Rear Diff. Fluid Changed Again 7,836 Mi. Titan XE Titan Engine, Transmission & Drivetrain 2 02-15-2005 06:38 AM
