TITAN04, it's not an axleshaft seal leaking. It's the axle popping completly out of the front diff. I've replaced 2 front diffs for the same problem. You can check by taking a pry bar, or similar tool, and pry on the axle. If the axle pops out, then you'd better order a front diff. The axle will not come completly out but it will leak front diff fluid. Sorry for the bad news.
