What I would like to do is find out if this diff CAN hold its own in any titan. We have all seen the 6 blown diff threads so I want to post something different, because all of us even me with some knowledge and no signs of any probs are paranoid our diffs are going to grenade. So if you hard working Titans would be kind enough to chime in and answer the same questions only different than phoebios post only it would help ease everyone including me. If it isnt too much trouble just answer the question with the # and answer. This is for Titan owners who have NOT had a diff failure only thank you.
1) How many miles?
2)How much weight do you tow?
3)What % of the total mileage is towing? (Best guess)
4)B/T, O/R, or none
5)E-lock yes or no
6)04,05, or06?
7)Did you change your diff fluid if so at what mileage, and to what brand, and viscosity?
8)As best you can explain the way you truck was driven and be honest if at all possible. gentile,normal, or drive like you stole it.
I appreciate all who respond to this thread and hopefully it helps a few rest easier. Or maybe there is a major prob. either way I think we are all better off if we know for sure.
4)B/T, O/R, or none
5)E-lock yes or no
6)04,05, or06?
8)As best you can explain the way you truck was treated and be honest if at all possible. gentile,normal, or drive like you stole it. this is very important question to me as it may or may not rule out driver abuse.
Okay, I'll go. So far so good.
1. 29,400 miles
2. Most days nothing. 10-15 times a year about 3-5,000lbs on a 500+ mile round trip.
3. Wow, never did the math. About 30%
4. B/T and O/R
5. No elocker
6. 2004
7. Changed the differential oil to synthetic to Mobil 1 - 75w140 at 15,000 miles. The differential was not low on oil(I put it back in the bottles it came in).
8. I'm not a drag racer but I ocassionally stamp it down. I guess I'd fit in the normal category.
Come on Chef, spill the beans...
Born on 01/2004
K&N Filter Charger and prefilter...........Stubby antenna
Westin Bull bar.........................................Front tint
PRG leveling kit........................dss90c LED bed lights
Access tonneau cover.................Stainless bug guard
GT seat covers.........................Tailgate assist spring
Husky floor mats.............Tailgate key fob locking mod
Banks "Monster" exhaust.......................Keyless entry
AT grounding kit................................HID headlights
Grille inserts.....................295/70 R17 Nitto Grapplers
Alum. rear diff. cover...........................HID fog lights
next?
I've only owed my Titan for about two months. I have not towed anything yet but the previous owner did. The truck has about 9500 miles on it and the first 8000 or so were used for towing. No diff problems.
1) 9500
2) I'd say about 3000 lbs.
3) Guessing about 50%
4) B/T only
5) No E-Lock
6) 2004
7) Original fluid
8) I would say normal use. Probably show off occasionally.
I have also been concerned after seeing all of the diifferential failures and am curious to see how this turns out.
I've already destroyed one rear. This is a very interesting thread because it is exposing the other half of the story. I'm anxious to see a lot of hard working diffs that have stood the test of time. The info will only help in the end.
I'm just a little touchy on the 'abuse' issue, since you could say I've abused every vehicle I've owned, but never had a diff go bad. (well not including this one) It's also something some dealers are using this to fall back on to deny inferior parts. It's my opinion that I may go through another diff before warranty time is up. It's just not built strong enough for this application, or if we are lucky, just a few batches of bad parts.
Nevertheless I think Craig's poll is a great idea, I'm very interested in how some diffs will hold up well. It's his poll and I'm not out to nitpick the wording that I personally do not agree with. I'm glad he came up with it and just want to follow it.
1) How many miles?
4)B/T, O/R, or none
5)E-lock yes or no
6)04,05, or06?
So far so good smooth running and tight, but I'm keeping an eye on it for sure!
1.about 18k miles on the truck.
2.I tow a bass boat I would say about 5k lbs
3. How much do I TOW? very low just a few times a year.
4. Both BTand O/R
5. E-Lock? YES.
6.Year? 05
7. Yes I have change it 3 times sense new, first time was at 1200 then 7k then 15k all I use is the factory Syn. 75/140. The fluid has been very clean and clear looking at every change so far and little to no metal in the old fluid.
8. How do I drive? normal
This 05 titan is so much better built then my old 04 it's not even close!
I do not even have any rattles at this point, the truck is way more powerfull then my old one and drives very smooth and tight.
I hope it stays this way.
2)How much weight do you tow? ~2,000 lbs. & ~5,500 lbs.
3)What % of the total mileage is towing? (Best guess) 3%
4)B/T, O/R, or none 4x4, BT, and OR
5)E-lock yes or no Yes, May '04, (the very first month of the E-LOCK's introduction).
6)04,05, or06? '04
7)Did you change your diff fluid if so at what mileage, and to what brand, and viscosity? Yes, checked F/R at 2K miles - full and "looked good"; changed around 4K not bad looking fluid, an 1/8 " of metal debris on magnet; 12K very little debris on magnet 1/32" to 1/16" of debris; and 23K very slight debris, 1/128".
Here is the best stuff on the market. Too bad Nissan didn't choose this instead of the full synthetic crap they have all of the '05 and '06 Titans using: http://www.schaefferoil.com/datapdf/267.pdf
Check out the fourth pic down. It pretty much shows why the '05 still go out, (well 2 or 3 of them I think ). The egg beater test says it all: http://www.bobistheoilguy.com/gearoiltest.htm
I followed all break-in procedures, towing included, and things like E-LOCK not over 12 mph. 4-LO under 30 mph, and 4-HI 60 mph or less. I don't abuse it, but I paid for an Off-Road pkg. so I will off-road it, and a Big Tow package rated to around 9,000 pounds with my setup, so I will do it and not worry.
I do off-road climbing steep arsed jeep trails, river rock courses etc. and generally don't baby it. But it is basically in mint condition. Never have power-braked, but I think a truck should be able to take it, since the market is full of guys that do.
The worst abuse this truck ever gets is on a public road of my commute. It has some large roller-coaster like dips 10-12 feet deep, and the Titan comes very close to getting air on these, (while driving the legal rate of speed of course).
I plan to keep this truck forever, and I'll be very surprised if the differential ever goes out. I think a few bad parts have made it into the channel. If I am wrong, the five year 60,000 mile power-train warranty eases any paranoia, (and my 100K extended warranty helps too).
Worst thing is the poor customer service of Nissan Corporation. If their product breaks, they need to provide 4x4 owners with a 4x4 truck to use, big-tow owners with a tow-capable truck. Being cheap arses and providing malibu's and corolla's will not make me be a return Nissan customer. They need to have the parts, (rear axles if they choose), available at all of the dealers so the customer is not inconvenienced, even if you blame them. Nissan Corporation has turned some of these guys into martyrs with their bad customer service. I even feel sorry for members like FishHead even though some seem to think he/she is a troll.
31,500 miles
4,000 pounds during summer, 350 miles round trip, every other weekend from June through September, 11 or 12 times each summer. Pull trailer with equipment about ten times a year, most weight was a small backhoe, short trips over the weekend, probably around 8,000 pounds.
10 % towing percentage ?
no B/T or OR
no E-lock
2004 4x4 KC
Added PML aluminum cover last June, ran 75W-90 Mobil 1 from 5,000 miles until then 20000 miles, then switched to 75W-140.
Normal driving, 20 % of my daily trip is stop and go traffic, occasionally smoke a turd if needed.
I think driver abuse would be applicable to the couple of people who have had multiple diff's replaced, if they actually have had that many replaced. I saw one of the posts yesterday, Mikey, said he had just had his sixth diff replaced. I'm beginning to wonder if he has a Titan, and knows what a diff is. Last summer I was in to see if they could better align the bed and rear bumper (they couldn't). At that time, the service manager told me they had only replaced three diff's, one because of a guy pulling about a 15,000 pound load of horses and stuff on a fifth wheel from West Virginia to Northern KY. He got all the way here before the transmission failed and the diff also had to be replaced. The service guy had to call a friend at a Dodge dealer to get a Cummins to take the guys trailer to his house. He thought the other two were early models due to very low levels of oil in the differentials. He said at the time he had seen quite a few brake jobs though.
1. 28,000
2. Between 1500 to 9100lbs.
3. About 18%
4. BT and OR
5. Yes
6. May 04
7. First change at 5k and 9k. Used Redline 80w-90 till I put the finned cover on at around 20k, now using the Nissan 75w-140 synthetic.
8. Gentle most of the time, though a few times I have layed rubber and when I pass people I always floor it.
One thing I feel makes a difference is the break in. On page 9-22 of the owners manual there is a highlighted caution section that states for the first 500 miles that you tow, do not drive over 50mph and do not make full throttle starts. I waited until my truck had 1000 miles before I towed and then towed at only 50mph for the next 500 miles (with many a finger thrown at me!).
Now I understand that as "regardless of the miles you have on the truck, the first time you tow anything, do it at 50mph for 500 miles"..
2004 SE CC 4x4 OR Big Tow
Build Date 5/04
Purchase Date 5/04
Radiant Silver
1) How many miles?
4)B/T, O/R, or none
5)E-lock yes or no
6)04,05, or06?
Miles=22,000
Tow wieght=5000, inboard ski boat w/ski equip. and camping gear.
% tow= 3500 per year(2 yrs.) 280 mile trips(one way) on Interstate highway
@ 75-80mph in 4th gear. Some 40 mile trips(each way) 45-50mph,
stop and go(traffic lights).
B/T?= yes
E/lock?= no
Year?= 04
Fluid change?= Yes every spring and fall. 75/140 in spring. 75/90 in fall.(syn.)
Always looks good. Super-Tech brand. Did not follow towing break-
in procedure, 75 mph from the get-go.
Drive style?= Easy, but I don't baby it when towing. Checked the diff temp alot when towing, never has exceeded 170*F. Use an infra red thermometer.
04 White SE, CC, 4x4,BT,POP/Capt.,Util. Bed package,Mud Guards,Floor Mats. Born on April Fools Day. Gas Whore.
Remember; Electrical wiring is no hobby.
3)What % of the total mileage is towing? (Best guess) 10%
4)B/T, O/R, or none ~none
5)E-lock yes or no~ no
6)04,05, or06? 05
7)Did you change your diff fluid if so at what mileage, and to what brand, and viscosity? Nope
8)As best you can explain the way you truck was treated and be honest if at all possible. gentile,normal, or drive like you stole it. this is very important question to me as it may or may not rule out driver abuse. ~Drive it like I stole it. What's the point of having 305 hp if you never use it!
7.) 25 or 26,000 and went with Mobil 1 Full synthetic 75W140
8.) I run about 70 to 85mph for right at 100 miles per day. This is of course traffic permiting. I commute in Houston, and you have Go Baby, Go when you can. I drive this truck like I stole it all the time, and gas mileage be damned.
2008 Crew Cab SE Long bed 4x4
Timberline Green Exterior
Almond Interior
Mod's: LiquidMetal Wingman wheels, Parada Spec-X tires, N-Fab 6-step Nerfbars, Sliding OEM Toolbox, AVS Vent visors, Tint, CUSTOM One-Off JesHand Creations Front Stealth Bumper, Tailgate bib Cover, color matched steering wheel wrap, Chrome swap on mirrors and door handles, PRG 1.3" Level kit
Yeah, She's the Biggest One
"We stole the eagle from the Air Force, The anchor from the Navy, The Rope from the Army, And on the seventh day when GOD rested, We overran his perimeter and stole the globe, And have been protecting our shores ever since. UNITED STATES MARINE CORPS
"The dustbin of history is littered with remains of those countries that relied on diplomacy to secure their freedom. We must never forget... in the final analysis... that it is our military, industrial and economic strength that offers the best guarantee of peace for America in times of danger."
—Ronald Reagan
"The multiplication of public offices, increase of expense beyond income, growth and entailment of a public debt, are indications soliciting the employment of the pruning knife."
Thomas Jefferson
General James Mattis, USMC to Iraqi tribal leaders.
"Allies or enemies. You make the call. I come in peace. I didn't bring artillery. But I'm pleading with you, with tears in my eyes: If you Faq with me, I'll kill you all."
1) How many miles?
10K
Have not tow yet
0%
4)B/T, O/R, or none
B/T
5)E-lock yes or no
No locker
6)04,05, or06?
05
Have not change
Normal driving mostly city, treat myself to a spinout here and there. Did a burnout once.
__________________ Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
1. 28,000
3. About 18%
4. BT and OR
5. Yes
6. May 04
I did the same for my break in period. I did not go over 60 mph for the first 1k miles and did not tow anything untill about 5k miles.
And then I still stayed under 60 mph for the first few times that I towed.
Then after a few times I started to open up and get into her alittle while in tow mode.
Everything is working just great, the truck just runs awesome!
