Old 01-01-2006, 03:37 PM   #1 (permalink)
gear ratio
Can someone give me the gear ratio's for the titan tranny ( 1-5) all I've been able to find out is that its an IK but nothing else. Thanks in advance.
RO.CO3 is offline   Reply With Quote
Old 01-01-2006, 03:39 PM   #2 (permalink)
Re: gear ratio
http://www.nissanhelp.com/Models/200...ifications.htm
Old 01-01-2006, 03:48 PM   #3 (permalink)
Re: gear ratio
Thats what I was looking for ,thanks. By the way if you look at 5th gear on the chart I bleave thats a typo. Can I remove the 2 from in front of the number and be correct.Thanks .
Old 01-01-2006, 05:11 PM   #4 (permalink)
Sammy Sandbag's Avatar
Re: gear ratio
It's correct, you are looking at the reverse ratio.
-Counsel Yourself
Old 01-01-2006, 07:18 PM   #5 (permalink)
Re: gear ratio
Thanks for the reply. But after looking at it again it still apears 5th is 2.613 and reverse is 2.937 .Are the lines not matching up.Thanks for the help.
Old 01-01-2006, 07:47 PM   #6 (permalink)
Re: gear ratio
1st 3.827
2nd 2.368
3rd 1.520
4th 1.000
5th 0.834
R 2.613
Final Drive 2.937
-Counsel Yourself
gear ratio RANDY Titan Engine, Transmission & Drivetrain 17 11-23-2005 09:27 PM
Gear Ratio RANDY Titan Engine, Transmission & Drivetrain 11 08-27-2005 02:09 AM
gear ratio bennieblunt Titan Engine, Transmission & Drivetrain 8 06-11-2005 01:12 PM
gear ratio Skeeter Titan General Discussion 8 02-24-2005 12:48 PM
Explain Gear Ratio? JohnIrish Titan General Discussion 5 03-31-2004 07:09 AM
